Question about Maxent MX-42V1 42 in. Plasma Television
Maxent plasma tv is showing only vertical lines.
When I turn on my maxent plasma tv is showing only vertical lines. what could be the problem? my tv is hooked to cable
  • Anonymous Mar 20, 2014
    What cause the tv to show vertical line
  • 39 Answers
Common problem on these sets are many many bad caps on the digital board. Repair kits are available for these containing the necessary parts if you're savvy with a soldering iron. Otherwise, replacement of the digital board is necessary and you'll have to contact either Maxent or a local repair shop. Tracking down which caps are bad can be difficult even with the right equipment as some tend to check good while in circuit when they are actually bad.
Posted on May 19, 2009
How do i hook regular cable to Maxent MX-42EPM20 42 in. EDTV Plasma Television
Your Maxent MX-42EPM20 is not a TV (Television) it is a Plasma panel. The difference being your Panel does not a TV Tuner (no Coax jack or electronics relating to a tuner) Below is the spec sheet that shows this
http://reviews.cnet.com/flat-panel-tvs/maxent-mx-42epm20/4507-6482_7-32139310.html?tag=mncol;subnav
You can use a cable box or a cheap Digital TV receiver. You can buy them at walmart, You need one with A/V out puts such as Component. Here is a link to one. This will give you a tuner.
http://www.walmart.com/ip/RCA-Digital-TV-Converter-Box-DTA800/8343230
Feb 18, 2012 | Maxent MX-42EPM20 42 in. Plasma EDTV
Maxent P420142x3 model no. No cable or sat box only coax how do you hook up to TV. no attenna port on back of TV
take your cable line and put adaptor on it going from cable to RCA. They have them at radio shack for $2.49 ea.
Jan 28, 2011 | Maxent MX-42VM10 42 in. HD-Ready Plasma...
I can her the volume but no picture is showing as it the tv is off.
No video , the screen is all blue and vertical white lines on the rigth side, audio is ok. How i fix this?
May 21, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
Maxent tv has a line about 2 inchs wide and half way down the tv
Vertical scan board needs servicing and ground needs to be re-established through solder re-flow........
Nov 03, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Vertical black lines appear intermitently
Does the line appear on just one input(cable,hdmi,video1,video2,ect) or on all of them? The reason why I ask is it may be just an issue with one input setting on the television and you may be able to use a different input for a temporary fix of the problem. Plasma telivisions run very hot and it may be overheating. Try using a small mountable fan above the TV pointed into the back heat vents and see if keeping it cooler keeps the issue from happening. These TVs are repairable but usually cost more to repair than what it is worth due to plasma TVs are very in-expensive now.
Sep 04, 2009 | Maxent MX-42V1 42 in. Plasma Television
VERTICAL LINES ON SCREEN
So it's no longer under warranty.... right? The problem you describe is control by a 'digital' driver IC (integrated circuit chip) which has apparently developed temperature problems.
Jun 30, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Plasma TV with vertical lines
chake to make sure it is hooked up right and not lose
Feb 02, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
How to Hook up without HD or Cable box
no place to fit the black cable from the wall
Nov 02, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Hooking up a Mac to tv
I ran into the same problem with my "50 maxent. The manual clearly states that mac resolutions are not supported. We won't let that stop us. Step one is to download switchresx. It's a simple utility that should allow you to define custom resolutions. http://www.madrau.com/ .
Step 2 is to download chicken of the VNC. http://www.macupdate.com/info.php/id/9517 . Once this is installed on a separate mac from the one you are trying to connect to the maxent take your mini and hook it up to the RGB port on the maxent and boot it up. Once this is done use chicken of the vnc to take control of of the mini with the other mac. Now you can change the resolution on the mini using switchresx which you installed on the mini earlier. In the case of the maxent you will need to set it to 1366x768 at 60 hz. If using another flat panel consult your user manual for the correct resolution. In my opinion there is no flat paned tv this should not work for.
Sep 30, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Maxent MX-42V1 42 in. Plasma Television Logo
821 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
