Question about Samsung SCX-4100 All-In-One Laser Printer
Open Heat Error
First it had Low Heat Error, I unplugged it and then reconnected it, now it has come up with Open Heat Error. Pleeeease Heelp.
  • 97 Answers
The fuser unit is most probably faulty, you will need to have it replaced.
Posted on May 20, 2009
Low Heat Or Open Heat
Dear
low heat error means the temp. of fusser assy. was not achieved during the specified time. some times occur during low voltage supply and reset after s/w OFF-ON.
Open heat error means there is no electrical connection to the heater heater of the fusser assy. It has tob either repaired or replaced with new one. mostly the thermostat is responsible.
Thanks.
Aug 18, 2014 | Samsung ML-3471ND Network Mono Laser...
Dell 1600n low heat error
Remove the fuser lamp and put it back in place, it is not heating properly.
Apr 02, 2008 | Dell 1600n All-In-One Laser Printer
Low cpu battery how do i fix it on alarm system
Open the system, unplug the transformer, disconnect one lead of your battery, reconnect the battery first, then the Ac if it says low battery still, then you need a new battery take the one you have go to battery plus get a new one, and reconnect it, it may still say low battery, wait for an hour for the battery to charge, disconnect the AC and battery again, reconnect the battery first then the transformer. It should clear the low battery.That battery is a
6 VDC 1,.9 Ah.
Mar 11, 2013 | GE Security Simon 3 Wireless Home Security...
What does low heat error mean?
Pls do the following
[Low Heat Error]
There is a problem in the fuser
unit.
Unplug the power cord and plug it back
in. If the problem persists, please
contact a service representative.
Thank you.........
Jul 26, 2011 | Samsung SF-560 All-In-One Laser Printer
The fax shows a messages saying "open heat error"
On this machine, you may have a fuser assembly that is bad. Replace the fuser modual.
If this doesnt work, then the main board needs to be replaced.
Also what most people forget is the fuser fan. Sometimes it turns slow and you will not even notice it. It might not even turn at all.
Replacing the fan will solve most problems, but if it still does not turn on, Look on there to see if it has a small circuit board on the fuser fan, replace it too.
if all else fails the main board needs to be replaced.
Good luck
Jul 29, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Whirlpool Duet Washer error code A10
Motor Control Unit (MCU)
Heat Sink Thermal Trip
If the thermal protector on the MCU heat sink gets too hot, it will open
the thermal protector on the heat sink which will stop motor functions
and an “F/10” will be displayed.
1. Check for proper installation, verify the unit is not located
near a source of heat and has proper ventilation.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the MCU, the motor,
and Central Control Unit (CCU).
4. Check the drive system for any worn or failed components.
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Feb 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Low heat error display
You will need to replace the fuser. There is a fillimant type heater in the fuser roller that goes bad.
Google a business called "The Parts Drop".
They will have what you need. It is very easy to change. All you need is a phillips screw driver.
You open the right side door as if you were removing a jam. You will see 4 silver phillips screws, one with a thin plastic cover . Remove those 4 screws, unplug the one plug, slide the new one in and plug it in. It will warm up and be ready. I looked it up, the fuser is $160 and should be good for 40 thousand pages or more.
Dec 29, 2009 | Xerox CopyCentre C20 Black and White...
FAX ERROR MESSAGE
It sounds like the fuser rollers are not at the proper temperature to work.
They should be inspected by a technician.
Jun 19, 2008 | Xerox WorkCentre M20i All-In-One Laser...
"Low Heat Error"
You have a fuser error. Try unplugging the power for a minute and plug it back in. If that doesn't work then the fuser unit has a problem.
Feb 03, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Open Heat Error
the thermal switch on the fuser are damaged. my problem is that I don't know the temperature of activation to this. And do not buy a replacement under this conditions. somebody help me.
Sep 27, 2006 | Dell 1600n All-In-One Laser Printer
Samsung SCX-4100 All-In-One Laser Printer Logo
517 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
