Pulse media single drive - Computers & Internet
1993 gt legacy ignition pulse problem
hi could you confirm the firing order you have? witch pulse signals are being received. thanks
May 23, 2017 | 1993 Subaru Legacy
Change from pulse dial to tone dial.
You will find a small switch on side of phone that says Pulse - Tone, choose Tone..
Jan 26, 2010 | Lucent 9110 Single Line Telephone
I need a driver for my tangent pulse 1gb mp3 player ?! can u help ??
de unde iau si eu draivarul pentru acest mp3 tangent pulse?
Jan 20, 2010 | Tangent PULSE MP3 Player
Capacity of the inbuild optiarc dvd
Here the recording spec for the drive
It quotes double layer so it should be able to do up to 8.8 GB which is way way way way bigger than 4.37 mb.
DVD+R (DVD+R Part 1 Single Layer, Basic Format Spec Ver 1.3) / DVD+RW (Single Layer, Volume1: 4X Basic Format Spec Ver 1.3 and Single Layer, Volume2: 8X Basic Format Spec Ver 1.0) / DVD+R DL (DVD+R Part 2, Double Layer: Basic Format Spec Ver 1.0) / DVD-R General (Ver 2.0 and 2.1) / DVD-RW (Ver 1.1 and 1.2) /DVD-R DL (Ver 3.0)/ DVD-RAM (Ver V2.0 and 2.1 and 2.2 Class 0 ; Single side :4.7 GB/1.4 GB ; Double side :9.4 GB/2.8 GB) and CD-R/CD-RW media
Oct 29, 2009 | Compaq Presario 700 Series DVD-Rom Drive...
How to install a turbocharger on a single cylinder 4 cycle engine
While it is certainly possible, it is not really sensible to fit a turbo charger to a single cylinder engine.
The power pulses driving the turbine are just too far apart (one each two revolutions). To stop the turbine constantly speeding up slowing down - with pretty unspectacular intake pressures - will take sophisticated knowledge of pressure wave propagation, resonace chamber design, reed valve chambers etc.
Because of all that, you would also get intolerable turbo lag.
I suggest you get a bigger bike instead :)
Sep 04, 2009 | 1972 Honda CB 250
My G4 Power Book won't start up.
myhotspot,
I think you are experienceing the same problem I had with my Powerbook G4. I would get the single beep, followed by the pulsing white light (2 flashes). The single beep indicates no memory is detected by the machine and the double flash with the white light is related. Apple eventually replaced my memory banks even though I was past the 1 year warranty period because it was a "known" problem with some of the G4s.
As a short term solution, you may want to try swapping your installed memory to the unused slot.
Aug 10, 2009 | Apple PowerBook G4 Mac Notebook
Xbox freezes
This is usually because some games are on DVD media and some are on CD media. CD's are single layer media while DVD's are multi layer media. This means it is easier to read a CD than it is to read a DVD. The concept of a DVD is to have several semi transparent layers of data. It is sort of like taking a few CD's stacking them together and smooshing them into a single disc. To read the 2-4 layers of data you must ignore the previous layers and pay attention to ones deeper in the disc. DVD drive might be going out 360 dvd drives do go out more then they should.
Feb 12, 2009 | Microsoft Xbox 360 Console
Sony media box
found a dry joint on the digital output socket,thanks anyway
Dec 01, 2008 | Sony (DL4TK88WW) Single Unit DLT Storage...
Hp invent p dvd940i does not see dvd disk
1. check your system meets the requirements for your device:
• Minimum system requirements: 800 MHz Intel® Pentium® III
processor or equivalent, 1.6 GHz Intel® Pentium® IV processor or
equivalent recommended (Actual drive performance depends on PC
configuration)
• 128 MB RAM (256 MB RAM recommended for video editing)
• 1024 x 768 video resolution with a minimum of 16-bit color required
for DVD authoring and editing
• Video capture: IEEE 1394 interface or analog video capture device
required
• Minimum hard disk space requirements: 1 GB free for included
software installation, 10 GB free for DVD video disc creation (18 GB
free for double layer). Internet connectivity recommended for software
updates
• Operating system compatibility: Microsoft Windows XP/2000
Professional SP4, Windows XP Professional x64 edition, and
Windows Server 2003
2. Have you install the sowftware that came with your device?
3. is your system recognizing the hard drive (go to start>run>type devmgmt.msc and press enter> and look under cd/dvd rom drives... is your device listed? is it showing with a ? unknown device or a ! next to it's name?
a. if the device is not listed chances are you didn't set up the jumper correcly when installing the device or the device may not be powered or there's an issue with the data cable connectd to the device and the motherboard, check your physical setup.
4. check the removable media is in fact compatible with your drive: this is the compatibility list
• Device write media compatibility: CD-R, CD-RW, DVD+R, DVD+R DL,
DVD+RW, DVD-R, DVD-R DL, DVD-RW, LightScribe CD-R,
LightScribe DVD+R, LightScribe DVD-R, 4.7 GB single-sided/9.4 GB
double-sided DVD-RAM (2.6 GB single-sided/5.2 GB double-sided
media not supported)
• Device read media compatibility: DVD-ROM, DVD+R, DVD+R DL,
DVD+RW, DVD-R, DVD-R DL, DVD-RW, DVD-Video, 4.7 GB
single-sided/9.4 GB double-sided DVD-RAM (2.6 GB
single-sided/5.2 GB double-sided media not supported), CD-R,
CD-RW, CD-DA, CD Extra, CD-ROM (Mode 1 - Yellow Book),
CD-ROM/XA & CD-I Ready (Mode 2/Form 2 – Green Book),
Photo-CD (single and multi-session), VCD, CD-Text
data taken from http://h20426.www2.hp.com/product/opticaldevices/sg/en/pdf/dvd940i_dataSheet.pdf
Sep 28, 2008 | HP Computers & Internet
Driwers for "Virgin Pulse VP-01"
Virgin Pulse  =  MPIO FY100
all soft seach on "http://www.mpio.com/downloads/index.php?search_part=FY100"
Jan 21, 2007 | Virgin Pulse VP-01 (64 MB) MP3 Player
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
