Question about Philips Mc235b Micro Size Stereo Audio System
How do you get the equalizer off jazz
The stereo has a DBB button to boost the bass but doesn't seam to have any button to change the equalizer from jazz to anything like rock, rap, clasical or anything. Just seems like it'll have to stay stuck on jazz cuz I'm pretty sure I tried everything and it made me very very irritated, so if someone could let me know how or if you can I'd appreciate it, also what is the white button type thing on the left side below the open-close button, the remote censor?
  • Rob Cross
    Rob Cross Dec 29, 2013
    pluss I don't have the remote for it...
  • 794 Answers
Digital Sound Control
Digital Sound Control offers you a choice of pre-set
Jazz, Rock, Pop and Classic controls you can use to
optimise the frequency ranges for different musical
styles. Each mode uses graphic equalizing technology
to automatically adjust the sound balance and
enhance the most important sound frequencies in
your chosen music style. Ultimately, Digital Sound
Control makes it easy for you get the most out of
your music by precisely adjusting the sound balance
to match the type of music you are playing.
You'll find the Digital Sound Control button on the remote- it is marked "DSC" (without the quotations). If you go to page 3 of your user's manual, there's a diagram detailing your remote control buttons. In case you lost the manual; you can get a pdf version of it at : http://download.p4c.philips.com/files/m/mc235b_05/mc235b_05_dfu_eng.pdf
Enjoy your new sound system!
Posted on Dec 29, 2013
Sony how to change the bass on my sony mex bt3100u stereo
Hello Tom,
You may have to adjust the EQ7 Preset to XPLOD and then listen to the jam. Here are the instructions from the bt3100u manual:
Selecting the sound quality
- EQ7 Preset
You can select an equalizer curve from 7 equalizer curves ("XPLOD," "VOCAL," "EDGE," "CRUISE," "SPACE," "GRAVITY," "CUSTOM" or "OFF").
1 During reception/playback, press the select button.
2 Rotate the control dial until "EQ7 PRESET" appears, then press it.
3 Rotate the control dial until the desired equalizer curve appears, then press it.
4 Press (BACK).
The display returns to normal reception/play mode. To cancel the equalizer curve, repeat the first 2 steps then select "OFF" in step 3.
Tip
The equalizer curve setting can be memorized for each source.
We hope that this helps. If not please return and post how this went.
Nov 24, 2013 | Computers & Internet
How do i calibrate my powered subwoofer for my car
OK assuming you are referring to after market sub and amp whether or not added to factory head unit (stereo). #1 start your engine, and have your amp adjusting knobs accessible #2 insert a CD of the most listened to type of music (Rock,rap,classic) #3 adjust your stereo volume to YOUR max preferred db level with your amp levels at the lowest settings possible #4 start by increasing your freq. rang by 2 bands at a time then the same with gain, once you have gotten your bass to the level you like with out distorting or popping try increasing your bass boost (if available) till your preferred sound(may need to back off gain and freq. add bass boost accordingly until you like what you hear.play around with it for a while make sure you do this at the peak volume in which YOU listen to music because if you do it at a low volume and then turn it up you can blow your equipment . side not 8''in is for very fast bass reps, 10''in is for average rock and 12''s 15''s 22''s are for your low long deep bass reps such as rap and R&B anything else just e-mail me
Jan 10, 2012 | Mazda MAZDA3 Cars & Trucks
How do I set the equalizer to my own custom settings on my RCA RS2635?
Hello
Press "Preset EQ" on the main unit, or "EQ" on the remote control to toggle among FLAT,ROCK,POP,JAZZ, CLASS. The display show the selection briefly. Press "Bass Boost" to turn ON/OFF boosting the bass frequency. OK.
Dec 03, 2010 | RCA RS2635 CD Shelf System
My screen broke and I am unable to change my settings. Is there any way ui can get a picture of the mode settings?
holding the MODE button will return you to the main screen. They are Music-Movie-Picture-Setting. You should be on the Music screen first. Pressing down will take you through these in order. Under Setting is LCD set, Language, online device, memory info, firmware, remove mtp info, default, exit.
While in Music (as long as you are not playing a song) tapping the MODE button will give you the option of going to the local folder or exit.
If you play a song and press MODE you are given the following options Play Mode, Equalizer, SRS WOW Mode, and exit.
Under Play mode are the options, Normal, repeat one, folder, repeat folder, repeat all, random, and intro.
Under Equalizer is flat, rock, pop, classic, soft, jazz, DBB
Under RS WOW mode is srswow, user setting, disable srs wow and exit.
I hope this is what you were looking for.
Jun 26, 2010 | GPX ML648B MP3 Player
DBB (Dynamic Bass Boost) is allways on :-(
It doesn't mention it in the manual. However maybe it stores the DBB position when you first set up the radio. If so try resetting the radio. But make certain the DBB is off before you do.
This is how to reset:
In standby mode, press and hold?? on the
system until "AUTO INSTALL - PRESS PLAY"
is displayed.
Press ?? again to start installation.
All previously stored radio stations will be
replaced
Jun 08, 2017 | Philips Audio Players & Recorders
Its working only in direct & stereo mode
maybe you need to replace a fuse?
is it hooked up correctly
Apr 23, 2009 | Denon AVR-1508 Receiver
Sound Quality Issue
Try the DBB button - it has several different bass boost settings that will change the osund quality/power.
-Tha Mp3 Doctor
Nov 11, 2007 | Philips FWM587 CD Shelf System
FWM587
Press the DBB button for Dynamic Bass Boost
Nov 11, 2007 | Philips FWC579 5-Disc CD Changer
Bass volume
Press the DBB button on the original remote to deactivate the Dynamic Bass Boost
Nov 03, 2007 | Philips FWC527 CD Shelf System
Philips Mc235b Micro Size Stereo Audio System Logo
172 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
