Question about Jensen's VM9312 Car DVD Player
Screen hi i need help my screen just stop working on my jensen vm9312 car radio i can't see it and i cant touch it i need help it just stop all in one day put it well play everthing and everthing work just not the screen HELP YOU CAN EMAIL ME BACK THANK U CRAPUUP@GMAIL.COM
SOURCE: JENSEN VM9312 CAR DVD PLAYER HOW
go to am/fm
then open the settings screen
next on your remote type 5,4,3,2,1,0 listening for each beep
a new screen should come up
after that look for brake override
Posted on Mar 20, 2008
SOURCE: no sound except for receiver
disconect the blue wire from the wireing harness and conect it with the blue with white u will not need the all blue wire
Posted on Jun 30, 2008
djsyco
  • 71 Answers
SOURCE: emergency brake wire connection
Here's a Bypass to solve that. Turn your 9312 on and set to radio then Using your remote enter 543210 and make sure you hear a beep each time, a new menu screen will pop up, click the hammer and screwdriver on the upper left side,Next press the menu line for brake override, a sub menu will appear, select ON,Press the X at the lower left of the screen and you're done enjoy and be safe.
Posted on May 15, 2009
SOURCE: do you know the bypass for this radio vm9312
hook the light pink wirk up to any ground
Posted on Jan 14, 2010
barbu51
  • 566 Answers
SOURCE: how do i by pass parking brake wire for indash dvd
Hi jason
To answer your question;
You do not need to connect that wire but you need to bypass the parking brake function in the menu.
Here`s the parking brake bypass procedure:
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number
entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
Hope this help Cheers
Posted on Apr 20, 2010
Testimonial: "good to have a sight that help's get the thing's you buy usable after you leave the store"
Have a Jensen VM9312 DVD/CD player - ribbon cable to display/touch screen is broken. Is this cable a purcahse item?
not that i know of. Might try to call manufacturer for the cable but as for online there isn't any available
Jul 14, 2011 | Jensen's VM9312 Car DVD Player
Manual for the jensen vm9312
You can download and print the instruction manual for the jensen vm9312 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Nov 03, 2010 | Jensen's VM9312 Car DVD Player
Radio will no longer flip out. Only after resetting car system
you have a bad drive gear, it may cost more to fix then getting a new unit, sorry
May 12, 2010 | Jensen's VM9312 Car DVD Player
Do you know the bypass for this radio vm9312
You can try the procedure for the VM9311TS model (the one I have) - I don't know if it'll work but it's worth trying. Put in a DVD, and let it start playing. Then hit STOP on the remote twice, and enter the code 1264. If you were able to see the actual movie at this point, you'd see a menu pop up. Push down twice, then ENTER. At this point the blue screen should clear and you should see the movie itself. You'll have other options on that menu, like a macrovision option to allow you to see burned DVDs. Set what you like, then on the remote, hit SYS SETUP twice to lock in your choices.
Nov 13, 2009 | Jensen's VM9312 Car DVD Player
IPOD not being reconize by VM9312
I have the VM9312 and my screen keep going in and out, and it wont stop I cant even go back into the setup to try fixing it. What can or should I do
Jul 18, 2008 | Jensen's VM9312 Car DVD Player
Just installed vm9312
go to the radio press setup on your remote then press 543210, a secret screen will pop up press the hammer and skrewdriver,u will see brake overide put it on the on position,thenpress the X at the bottom of the screen,then your all set.
Jul 08, 2008 | Jensen's VM9312 Car DVD Player
go to am/fm
Mar 19, 2008 | Jensen's VM9312 Car DVD Player
Ipod touch problem with jensen vm9312
My iphone works fine, it is a firmware version 1.1.2, maybe you have a different firmware version. you might have to upgrade or downgrade.
Mar 17, 2008 | Jensen VM9510 Car DVD Player
Jensen VM9312 - Touchscreen Stopped Working
ya i get that same problem with the radio playing in the background. But i did notice as far as buttons to push the for a second or to that helps
Jun 28, 2007 | Jensen VM9510 Car DVD Player
Vm9312
That is the code for the older jensen's The parking brake bypass procedure is as follows: 1: Go into AM/FM mode 2: Hit "setup" on the remote control 3: Enter 543210 on the remote, listening for the beep for each number entered 4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen. 5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
May 25, 2007 | Jensen VM9510 Car DVD Player
Jensen's VM9312 Car DVD Player Logo
27 people viewed this question
Top Jensen's Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
Tre Elkins
Are you a Jensen's Car Audio and Video Expert? Answer questions, earn points and help others
