Question about Konica Minolta Bizhub C220 Color Copier
Konica minolta c220 cyan color print is not cleared how to solve
  • Konica Minolta Master
  • 6,161 Answers
Replace the cyan image unit
Posted on Jul 04, 2016
osiriscompu
  • 16 Answers
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Posted on Jul 19, 2008
Kevin Hayes
  • 167 Answers
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Posted on Feb 17, 2009
  • 52 Answers
SOURCE: "Can't Detect Genuine Toner Cartridge"
minolta printers work on "chips" if the chip atached to the cartridge is not original minolta you better change it.
Posted on Jun 18, 2009
SOURCE: I am getting cyan toner cartridge not installed on
I found a solution on here that said clean the contacts on the toner cartridge on both ends with an eraser and I did and that stopped it. On the right side you will see some shiny contacts that appear brass color, just use the eraser and clean them off and on the other side you will see copper colored contacts on the bottom and side, clean those as well. That did it for me hope this helps you.
Posted on Jan 17, 2010
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Posted on Mar 08, 2010
Bizhub c 220 gives white streaks on prints. How could it be solved.
Try cleaning the print head windows using the cleaning tool inside the front door or alternatively take the print head unit out and clean the windows using some glass cleaner
Mar 22, 2017 | Konica Minolta Bizhub C220 Color...
While doing printing after 6 or 7 print, the error code c2552 appear in konica Minolta c220, I have open the front door, after that error gone, Again same problem coming after 6 or 7 print.
C2552 Abnormally high toner density
detected Cyan TCR Sensor
• TC ratio in the developing machine, which is
determined by Toner replenishing amount control
mechanism, is 12 % or more for a given number
of times consecutively.
1Clean the TCR Sensor window on the
underside of the Imaging Unit if dirty
2 Reinstall Imaging Unit
3 Change Imaging Unit
4 Change PWB-M
5 Change PWB-MFP
Jan 24, 2017 | Konica Minolta Office Equipment & Supplies
Devloper unit problems?
Here is the service manual
in section 4.4.1 shows you how to change devloper and how many counts/copies when need change.
Konica Minolta bizhub C220 Service Manual
May 15, 2014 | Konica Minolta bizhub Office Equipment &...
Printing black ground in konica minolta bizhub c220
have a tech come out clean the machine run require procedures to determine problem
Apr 26, 2014 | Konica Minolta Bizhub C220 Color Copier
Could not run motor c/k
Color print not coming to proper on all surface of 300 gsm card may we know the reasons
Mar 02, 2014 | Konica Minolta Bizhub C220 Color Copier
Error code 2551 of c220
It is a problem with your cyan image unit, see if you have put it ok other way you should change it your cyan developer is dead. change image unit, cyan
Dec 08, 2013 | Konica Minolta Bizhub-200 Minolta Printer
I have konica minolta bizhub c550,it showing me P21 and P6,what is the causes?and the black is not printing well
P6 : cyan image unit problem. P21 come after P6, and it's also too a cyan unit image problem. replace the cyan image unit.
Nov 18, 2013 | Konica Minolta Bizhub C550 Color...
Konica Minolta Bizhub C220 Color Copier Logo
21 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
