Question about LG Optimus L9
Keyboard Not Working
Whenever I go to press on the messaging box for the keyboard to come up, it doesn't. And this has never happened before. This is a brand new phone, I just bought it not even a month ago. I've tried taking the battery out and resetting it and checking my settings but nothing's working. The keyboard just doesn't come up anywhere, and this happened out of nowhere it was working perfectly fine before.
SOURCE: Won't Turn On/Charge
when that happened to me it could have been caused by two possible problems:
1) water damage. If you know it's not water damage, it still could be because if you had your phone in the bathroom while having a shower, steam can seep in and if it's one thing I noticed about chocolate flips they get water damage really easily.
------>>> If that is the case then you have to take your battery off and take a really fine ground sand paper and rub along the contacts (like the copper that is on the battery and the phone that touch when you put ur battery in) and that will rub off any kind of oxidization (rust) and possibly make your phone work. It happened to mine and I did that and it was successful
2) you could not be turning your phone off regularly enough. Technically, you are supposed to turn your phone off every night when you go to bed to give your battery time to re-vamp. Also, I was speaking with a rep from telus and they were saying that you should also turn your phone off during the day, just for a minute then turn it back on again and apparently it recharges the battery as well.
Hope this helps!! It only comes from personal experience so it all depends on the reason why it's doing that.
Posted on Dec 09, 2007
SOURCE: My KE970 lost service, & won't turn on.
the best solution is to reflash is with Original GO firmware which is v10a version. it should solve the problem. google to find the flash file. remember one thing if it doesn't solve your problem its definitely a hardware problem.. hope this might help.
Posted on Aug 22, 2008
  • 89 Answers
SOURCE: LG Rumour QWERTY keyboard doesn't work.
You can try to hard reset the phone, however, this most likely won't work. You will probably need to take it in to be repaired. :(
Posted on Apr 21, 2009
  • 20 Answers
SOURCE: the qwerty keyboard on my LG Xenon stopped working when texting
well wen mine stopped working wen i slid the screen out it wouldnt switch. i was told to use a magnet and run it on the back of the touchscreen and BAM! it worked
Posted on Oct 29, 2009
SOURCE: same problem!
i know how to fix it... HAHA i just figured it out you got to hit it =/ sounds weird but it works just slide it and close it fast
Posted on Feb 07, 2010
When i press my enter key to send a message on my chat box, it wont send it. what do i do??
Problems with keyboards are common. If you are using a laptob just use a regular keyboard by plugging it in the usb port if your using an older laptop then you can get an adapter or keyboard with the ps2 port.
If you are using a regular desktop just get another keyboard
Sep 30, 2012 | Computers & Internet
On my vaio 5 r t f5 f6 keys not working
With regard to your Vaio keyboard that some of the keys are not working, there are some possibility it is happening, 2 common things are the keys are defective or there might be some obstructions like dust, dirt or something that might be blocking the connection of the keys whenever you presses it. You can try cleaning the keyboard with a air can to blow anything that might be blocking it, however if that didnt work, most probably you will need to get a new keyboard replacement.
Try contacting Sony for replacement.
Sep 17, 2011 | Toshiba Satellite A105 Notebook
Keyboard don't work. It happens 2 weeks ago, now
Is the keyboard working in bios mode? if Still not working. Go to the nearest service center. Tnx
Aug 18, 2011 | Computers & Internet
When i press ctrl alt del nothing happens
Please ensure your keyboard is working by unplugging it and replugging it back in and restarting your computer.
If that doesn't work please try a different keyboard.
May 07, 2011 | Computers & Internet
Back Button (on physical keyboard) Malfunction
The same thing happens to my cliq except it happens every time i hit the space bar on the physical keyboard its inserts random text and then sends it either on via text message for search bar... Tmobile has sent me a new one each time i am on my third one good luck wih warrenty
Feb 09, 2010 | Motorola Mobility CLIQ Cell Phone
The keyboard works when it wants to.
the keyboard is bad since it has start malfuctioning. The best solution is to change the keyboard
Aug 10, 2009 | Ideazon MERC Stealth Keyboard
My keyboard is glitchy.
If you don't want to buy a new keyboard, you can open your keyboard and leave it to dry for a couple of days. There's still some moisture in the keyboard that's why this is happening. As soon as all moisture has been removed from the keyboard, it should work fine. But there's no guarantee since the board might have short circuited already.
Jun 17, 2009 | Computers & Internet
LX 500 Keyboard not working mouse fine
Normal 0 Assuming that you have good batteries installed, turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard.
Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps. Bud
Dec 29, 2008 | Logitech LX 700 9674180101
Stoped functioning
Normal 0 Turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard.
If your having trouble with the mouse also,
turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Dec 03, 2008 | Microsoft K5100141 Keyboard
Asus eee keyboard
It's an internal problem. If ocurring after messing with the keyboard the solution is to turn off the asus, unplug the battery, plug it again and turn on. It happens in both 700 and 900 models.
May 14, 2008 | Computers & Internet
LG Optimus L9 Logo
138 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
