Question about Daewoo Washing Machines
How to replace tub bearing daewoo dwd f1222 - Daewoo Washing Machines
2 Suggested Answers
SOURCE: daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Posted on Dec 19, 2011
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
My dwd f1222 front loader goes through cycle but wont spin on any part. I tried moving by hand and its very loose and wont go all way around. Any ideas on how to fix please?
There is a door switch that usually goes bad. Stops the machine from going into spin cycle. Easy to replace. If you find it on the machine(plastic pointed piece on door) push the switch with your finger or a pencil. If you do nor hear a clicking sound it needs to be replaced
Apr 01, 2016 | Washing Machines
My dwd m 12c6 daewoo washing machine will not spin
Blocked drain pump and or drain outlet hose. Check the inside of the pump as well. Daewoo are common to get coins etc stuck in the tub to pump hose and foreign material stuck around the impellor in the pump. If it cant pump out, it wont spin.
Jan 05, 2015 | Daewoo Washing Machines
E9 message and machine stops
Jayshree, E9 error, pressure sensor error/water sensor error.
Replace water level sensor. The error display disappears if power button is turned off and on.This is what the service manual states.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Daewoo DWD M103 Service Manual Page 15 of 16
Daewoo CV701PC Service Manual Page 26 of 52
Daewoo Washing Machine Error Fault Codes
Washing Machine pressure switch
Apr 20, 2014 | Daewoo DWD M1031
I believe the EO code means the pump is blocked, and you will have to clear the pump for it to work again.
Oct 12, 2013 | Daewoo Washing Machines
Daewoo DWD L142kc wont spin
Dwd-L142KC has a direct drive motor. A very common fault on this machine is that the drum shaft seal fails, letting water into the bearings which then starts to rust and then develope severe play between the drum and the tub. As the stator is mounted onto the tub and the rotor is mounted onto the drum shaft the rotor can then, due to the worn bearing, move too far away from the stator. Because the sensor that detects the actual speed of the motor is mounted onto the stator assembly, the control PCB then no longer gets the feedback signal from the sensor hence the motor not running correct. You'll most probably see the motor only moving in short bursts, a the missing feedback prevents it from accelerating further. A bearing and seal repair will in this case resolve this problem. It did on my machine. If the shaft is heavily worn below the shaft seal, this will need sorted in order to prevent the new seal from getting damaged or wearing out to soon.
Jun 08, 2012 | Washing Machines
Where is daewoo's company in cairo, egypt? I have any problem with my washing machine.
I have DAEWOO Washing machine DWD F1011. Whithin few years water started leaking through the drive shaft and ball bearing damaged. I need service manual for how to change the ball bearing or is there any repairer in Heliopolis, Cairo area?
How many year the machine is guaranteed??
Thanks lot.
Panchal
Aug 19, 2010 | Washing Machines
Daewoo DWD-F1011 PFE error code
Nov 16, 2009 | Daewoo Washing Machines
Washing Machines Logo
Top Daewoo Washing Machines Experts
Owen Barnes
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
