Question about Sony STR-DE685 Receiver
Sound only some out of 2 speakers at a time. I need all 4.
I have a Sony Receiver Model No. STR - DE685 I have 4 speakers hooked up. My problem is that only 2 work at one time. I have 2 hooked up in the "front speakers" portion, and 2 in the "surround sound" section. The connections are secure. In 2CH ST. mode only the 2 front speakers work, and in the norm.surr (normal surround) mode, only the surround speakers work. Thanks for any help
  • 863 Answers
Here you go buddy:
http://www.docs.sony.com/release/STRDE685.pdf
Posted on Nov 01, 2009
Humming sound from subwoofer
hi Eileen Beamish,
One reason you found it in ......... , is that , These unit have a problem.
Humming is the main problem.
Resolved first the humming , then it will answer your questions
when you have succeeded repairing your subwoofer system.
It is irrelivant for now.
Here is a guide , how to repair or diagnose circuits which can cause
like the symptoms your having.
Computer Speakers
you can post an image or a picture just to help you identify which
possible board or components to check, only if you need to Diy.
Oct 14, 2012 | Sony Str-de685 Receiver 5.1 Dolby W/...
My Sony STR-DE685 Receiver out of the blue now has loud hum when using the tuner only. All other inputs work great without any issues. Seems like a filter burned out. If that is the case, does...
In receivers, there are different power supplies or power supply outputs for the receiver and amplifier sections so you can have separate failures with one area not affecting the other. From your description, I think the (probably lower voltage) section for the receiver has either lost a cheap filter capacitor or a regulator IC. Neither of these are expensive parts but I can't know what labor costs in your area might be. An honest tech shouldn't ask more than ~$100 US for that kind of repair.
Apr 16, 2011 | Sony STR-DE685 Receiver
I'm trying to hook up my reciever up to my new flat screen any help as far as what cables I need, I will also be putting a dvd player on as well. I have comcast cable also, I've been told I need to get a...
This is posted under the Sony STR-DE685 heading, so I assume that's what you have. (If not, your receiver may have other hookup options available.) It might help if you download the manual if you need a copy from Sony's site here. It details all the rear panel connections.
This receiver doesn't have HDMI connections, so you'll need to make your connections using RCA cables It doesn't pay you to get an HD cable box if you're planning on connecting it through the receiver.
Output to the TV is very simple. Use a component video cable to go from the component monitor output on the receiver to the TV's component input. Then switch the TV to that input, turn off its speakers and listen to the sound through the receiver. Only one cable going to the TV that way.
Inputs will need separate audio and video connections since there are no HDMI connectors. Use the component video connection for your DVD player for the best video quality. The DVD/LD input offers those jacks. You can connect your cable box to the VIDEO 2 input using component video connections (if the box has those outputs) or composite video. Then the video and audio from the box will run through the receiver as well.
If you want to get a new HD cable box, you'll need to run a cable from its HDMI output to an input on the TV, and switch the TV to that input to watch the box. You can still run the audio signal through the receiver though. That will add one more cable to your hookup, and you'll have to remember to switch inputs.
Hope this helps. Thanks for using Fixya!
Jan 26, 2010 | Sony STR-DE685 Receiver
Heard a pop and receiver now displays "PROTECT." Is that a sign of death for this unit?
a lot ahve relays not fuses check speaker leads are not shorted,at the back make sure the spring clips (speaker wire holders) check the springs under the clip hav't shifted,check speakers(unhook all speakers,then mute
Dec 02, 2009 | Sony STR-DE685 Receiver
I have hooked by two bose 161 speakers using 14 gauge speaker wire (about 8 feet) to sony str-dg720. But I get absolutely no sound from the speakers. I have hooked the speakers to port A set of input...
You gots ta isolate the problem.  Disconnect the speakers and hook them up to a stereo you know that works.  If you don't hear sound coming out of the speakers, then you know the speakers are fu.k.d up, so you need to look on the speakers to see if there is a fuse that is blown that needs to be replaced.  If you got sound coming through, then disconnect them and hook them back to the original stereo making sure you got a good connection and all the wires are in good and tight.  Then turn your stereo on and go through the various channels like Tuner, Tape Deck, Aux, and DVD to see if you get any sound.  Also turn the volume knob up. If you don't get any sound after all this, you know there is something wrong with the stereo your using.
Oct 29, 2009 | Sony STR-DE685 Receiver
5.1 Surround sound not working
Maybe the surround processor is having a bad day... My kenwood would do similar and a reset was necessary to correct. Have you tried resetting the system? On my Sony STR DE 597 this is accomplished by powering off. Then while holding the 2 channel button down (front face plate) power on. A reset message is displayed. Your model may be similar but check your manual or download the PDF of the manual from Sony's support website. Hope this helps
Sep 05, 2009 | Sony STR-DE685 Receiver
The sound goes off and says "unprotected"
check speaker wire connections on the back of receiver
bare wires should never touch each other or the metal chassis
if all connections and speakers seem ok the problem is internal witch can go from blown power supply to shorted output devices and everything in between , and as always look for repair shop in your area, do not attempt to do it yourself, firehazard and electric shock are the things we all want to avoid ;)
Sep 02, 2009 | Sony STR-DE685 Receiver
Output
When you change the selector switch, do you hear the relays inside the unit? Is your muting button activated (found to the lower left of your volume knob)? Do you have speakers connected to A or B or both?
Dec 23, 2008 | Sony STR-DE685 Receiver
STR--DG910: no rear speaker sound, no center speaker sound
if you confirmed all connection repeat your speaker setup.
Jul 06, 2008 | Sony STR-DG800 Receiver
Hooking up these speakers with STR-DG810 receiver
ya does need a power sub out from a mini unit big sterios have sub pre outs sends signal only u could use speaker but u may blow them i would buy a kilshpsh set best buy 5.1 299 bucks to tie in sterio rock ya aaway
Jan 16, 2008 | Sony DAV-HDX500 System
Sony STR-DE685 Receiver Logo
542 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
