Question about Vizio Televison & Video
Color problems with my vizio vw37L tv
Image looks like it is a negative, color is messed up
Tech4lfe
  • 42 Answers
SOURCE: Picture looks like a color negative
I would return it and get a brand name. It either has a bad lcd panel or digital board. If it breaks with no warranty you will be SOL.
Posted on Mar 06, 2009
SOURCE: Vizio LCD Green Pixels
Our Vizio started doing the same thing after only three weeks, except it was also showing green pixel when we watched DVDs.  After checking this site and others and trying all the "tweaking" advised, I finally called Vizio's customer support.  They were extremely polite and tried to help over the phone, but had to send someone to the house to make the repair (anything 40 inches or larger earns a house call). The tech arrived on time and was extremely professional and pleasant -- he had to replace the daughter board and LVDS cables.  So far, so good.
Posted on Jun 29, 2009
Sparko1
  • 167 Answers
SOURCE: The picture on my Vizio 42
This is the fix for the Main board repair :
Locate IC 32 small 8 pin surface mount near top of Main Board and remove. Short pin 2 to pin 5. (pin 5 through 8 are together and pin 2 and 4 are together)
You will need a good TV Tech to do this for you.
Posted on Aug 04, 2009
  • 92 Answers
SOURCE: Negative type images in pink & lime green
I had the same problem....turned out it was the "lvds" cable that runs from the mainboard to the lcd controller board. Simply remove the tape that holds it to the back of the backlight housing and also remove the foil shielding tape from the connector on the lcd controller board.
Posted on Dec 04, 2009
budmrtn
  • 11361 Answers
SOURCE: problems with ltv-32w3 hd
You need to replace the LCD controller board, there are two versions (V320B1-C, 35D003848) you need to open up the tv and remove the shield cover to get to the LCD controller board, this is a common problem with this model. Look here parts (make sure to get the part number of the LCD panel sticker to match wit the LCD controller): http://www.shopjimmy.com/catalogsearch/result/index/?q=LTV-32W3HD&stock=all
You cam see the one I fixed here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Notes: be real careful when you remove the back cover, the side switch assembly is attached to the back panel, so do not pull it off too far, or you will damage the switch assembly!
Posted on Dec 28, 2009
Color problems vizio lcd hdtv
If your tv has a custom settings area, first turn all color down on set so picture looks black and white. Now in color settings look for red blue and green color bars. Use the bars until the picture looks as true to black and white as possible. Also, try changing color temp.
Dec 21, 2013 | Vizio VW37L 37 in. LCD HDTV
Vizio p50hdtv10a Has inverted colors wen you turn the TV on, the image shows like the colors have been inverted, the picture looks like a negative. Havent cracked the case yet, would like to know where to...
may be a faulty lead to the screen driver or the screen drive has a fault. would need to check the cables to the screen driver board on the back of the screen
Oct 01, 2013 | Vizio P50HDTV10A 50 in. Plasma HDTV
How do i connect internet to a vizio vw37L tv
Yes, if after you checked all the connections source then your main board is defective. The Wifi/B in the tv could be on the main board or close to the main board but have a tech come out and replace it.
Feb 11, 2013 | Vizio VW37L 37 in. LCD TV
I have a vizio model vw37l hdtv 10a, got a hit on front panel that made a small crack which messed up the picture in that area,what part needs replacing?
The set is finished- sets like this use a display panel- it is the entire front screen unit and a sealed unit at that.
Cost of the entire panel unit even if available will cost more than the set did when new ( not counting labor to remove and replace it).
Buy a new set and note all LCD and Plasma like sets have this issue as the display panel is very fragile.
May 25, 2012 | Vizio VW37L 37 in. LCD TV
Vizio VW37L no power
Check for bad capacitors in power supply, check voltages coming out of the power supply, if voltages are good, bad main board.. Vizio's are notorious for bad main boards.
Nov 23, 2011 | Vizio VW37L 37 in. LCD HDTV
I have a Vizio 37" TV (VW37L HDTV 10A) bought in
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ ///
Sep 03, 2017 | Vizio VW37L 37 in. LCD TV
Vizio vw37l tv with a lost remote. i have a panasonic universal one is it possible to program it?
Try 1-800-Remotes Factory original.Buy an exact remote.Finding unversial remote codes like pulling teeth i'm telling u.
Jan 19, 2010 | Vizio VW37L 37 in. LCD TV
Vizio Tv Proplem
Contact Vizio and inquire about if there are any firmware updates needed on your model of TV.
Jan 09, 2010 | Vizio VW37L 37 in. LCD HDTV
The picture on my Vizio 42" flat screen suddenly shifted to a whitish pale color with ghostly looking images that look like negative film.
Aug 04, 2009 | Vizio VO42L 42 in. LCD TV
Vizio VW37L
720p & 1080P are what you want, the vizio has a higher repair rate than most, check out the toshiba or the samsung
Jul 17, 2009 | Vizio VW37L 37 in. LCD TV
Televison & Video Logo
51 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
