Msh 30tv airconditioner compressor doesn't start. 5 flashes tells me to check if compressor is locked or not. How do I do this please?
  • 10,291 Answers
You'll need a clamp on style ammeter to check it. On the data plate of the unit, look for the "LRA" Locked Rotor Amps value. Clamp the jaws of the ammeter around just one of the large black wires connected to the compressor and try starting the unit while observing the reading on the meter. If it's close to the value on the data plate, then your compressor is indeed locked. A bad start capacitor could be the culprit too
Posted on Jan 05, 2014
How much 'gas' does the MSH-30TV air con require?
gas is put in according to pressure and suction readings on a combination gauge
it is not a diy job
Jan 11, 2017 | Cars & Trucks
Replacement part for Omron G3J-S245BL-MS Soft start relay for Mitsubishi MSH A30WV Airconditioner
Go to parts dept at dealer, if they don't carry it find an electronics store like Digi-key or Allied on-line, they probably carry Omron relays or can order it.
Nov 22, 2014 | Mitsubishi Cars & Trucks
2003 Toyota Echo Power Surge When Airconditioner is on
Air conditioner compressors take up to 5 hp to run that is why when to unit cuts in the engfine revs drop until the computer compensates for the rev drop Can be as much as 700 rpm. conversly when the compressor disengages the engine will over rev until the computer compensates. If you didn't have a problem before but do now it is possible that too much gas was put in the a/c system meaning the compressor is almost locking uo. Have the system pressure rechecked
Jan 07, 2013 | 2003 Toyota ECHO
My older window whirlpool airconditioner just quit working, the air doesn't work but the fresh air fan is working. I can't find my book to check problems, what could it be, plus is there a number...
It sounds like the compressor is failing to start which could be a number of things. It could be a contactor that starts the compressor is not closing and hence no start, it could be a bad capacitor or even a faulty switch. It needs to be taken apart to properly troubleshoot it. Hope this helps somewhat. If so please give me a rating. Thank you. Any questions please send them my way and I will try and help you.
Aug 03, 2011 | Whirlpool CA24WCR Thru-Wall/Window Air...
Our LG Art cool Airconditioner displays the error code CH 21. The unit turns on BUT after about 5 minutes the unit turns its self off. Please Help
Inverter compressor run current high. Check compressor windings all equal 1 to 4 OhmsCheck to earth 50 MOhm minimum, check run current. If high, winding is weak. Solution: Replace compressor.
Jan 11, 2011 | LG LSC183VMA Split System Air Conditioner
My airconditioner works for about 5 mins then stops and cant turn back on
First of all check your timer setting. Secondly, check your indoor coil sensor, may be weak, replace it.
Please clear one doubt that is your compressor working within that 5 minutes?
Dec 16, 2010 | Haier HWR12XC5 Air Conditioner
My unit turns on and after a couple of minutes starts blinking and no cooling
I'd say you have a problem with your compressor. The blinking is a fault code but usually you need a service manual to tell you what is wrong.
TBH, you would most likely need to get someone to come look at it.
Feb 20, 2010 | Comfort-Aire MSH-024 Air Conditioner
TURNED OFF AND 5 WAY LIGHTS ON AIRCONDITIONER FLASHING, WON'T TURN ON
1.check selector switch.
2.wiring.
3. check cirkit board of aircondition
Jan 29, 2008 | Heating & Cooling
Hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Oct 26, 2007 | Heating & Cooling
Heating & Cooling Logo
120 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
