Question about Garden
Whipper snipper revs but head doesn't turn
My Honda whipper snipper revs fine but the head is not turning. It sounds like something is turning inside the shaft but perhaps there's something broken before it meets the head - what's the most likely problem?
    Sergeant:
  • 340 Answers
Englebert the most common thing would be that the inner shaft has sheared off. Remove the head and see if it spins then.
Posted on Dec 29, 2013
evwood
  • 50 Answers
SOURCE: pretensioning starter cord on ryobi whipper snipper.
This was answered in a previous solution
Posted on Jan 03, 2009
  • 86 Answers
SOURCE: operating manual for Honda whipper snipper
If you have the UMK 425 model....
http://campaigns.hondampe.com.au/Power%20Equipment/ownersmanuals/brushcutter/umk425own01.pdf
Posted on Mar 22, 2009
bbreton
  • 437 Answers
SOURCE: how do i replace a shaft for ryobi whipper snipper
I never heard it called a whipper snipper before but I am on this side of the ocean. you should be able to go to www.ryobiuk.com. Put in your model number and you should find a parts list for it.
HTH
Good Day. mate
Posted on Oct 28, 2009
SOURCE: my whipper snipper starts well but has no power to
Battery is NO GOOD.... need new ones, these quickly go bad, if not religiously charged and discharged. You must charge a long time when first get them, and then as soon as flat must go back on charger, for at least 4hours... regardless what is said. If ever removed before properly charged, then it will "remain" at that level, next charge and so on... All batteries MUST be flat before recharge, and full before used again, no exceptions.
Posted on Mar 01, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Hi, I have a Victa Tornado Plus Whipper Snipper
Hi and welcome to FixYa, I am Kelly. I know this is a 26 cc petrol engine on your trimmer but do not know if it is a 2 or 4 stroke engine. If you are in AU then it would be a 2 stroke. There are a few things that can cause this.
If you engine has a primer bulb.... Hold it depressed hard while trying to increase engine speed. What your trying to do by doing this is prevent air introduction via the primer bulb if it has a pin hole in it. If you can get normal speeds bu holding the primer bulb depressed HARD the primer bulb has a pin hole in it and must be replaced.
Also look inside the fuel tank at the fuel collection tube end. Usually there is a screen inside the tank. Some times the screen becomes coated with gunk and it has to be removed from inside the tank for cleaning.
If your carb has a fuel shut off on the side of it... unbolt the fuel manifold and pull the bolt out of the manifold. Models with this type of fuel shut off have a screen inside the manifold that has to be pushed out of the manifold and cleaned.
If after checking all of the above you still have the problem then it is time to remove the "L" fuel mixture screw on the side of the carb. BEFORE removal... rotate the screw clockwise counting turns until it JUST barely closes. Do not turn it tightly closed as the end of the mixture screw needle will break off inside the carb and you will have to replace the carb.
Then rotate the mixture screw ccw and remove it. Spray carb cleaner into the mixture screw hole to remove any debris.
IF your carb only has an "H" screw perform the same procedure above but for sure clean both the "H" and "L" mixture holes with carb cleaner. Wipe off the needles too.
Install both screws CW until closed and then reverse the number of turns CCW you counted before removal for EACH of the 2 mixture screws.
Make sure the FOAM Air Filter is NOT clogged with debris. Clean as necessary.
Start the engine and let it warm up briefly. Attempt to increase speed slowly to full speed. If the engine hesitates open the "L" mixture screw less than 1/8 th turn and try again. You should note a change in performance after rotating the "L" Mixture screw ccw. Begin rapidly throttling up the engine after EACH adjustment until the engine no longer hesitates or tries to stall upon acceleration from idle.
RUN the engine at TOP SPEED. Adjust the "H" Mixture screw until you get maximum engine rpm. You will NOT hurt the engine but it must run at MAX speed smoothly.
CHECK acceleration from idle to MAX again. re-adjust "L" mixture if necessary.
One last thing to check is make sure the gas cap is vented. Without a vented gas cap the engine will run briefly then perfromace will degrade substantially. Many times on trimmers I see people place plastic over the fuel tank fill hole and install a damaged cap. Replacing the cap has fixed many many trimmers with tank vent problems due to a bad fuel cap!
This should get you going again. If you need any more assistance or you still have the problem after performing the aboe please respond here with any updates.
Thanks for choosing FixYa,
Kelly
Posted on Jan 03, 2011
My stihl whipper snipper loses power and cuts out when i try to rev and apply throttle.
With 2 strokes I always start with 'AIR' 'FUEL' 'SPARK' from the sounds of it the choke might be stuck on (choking the motor ha ha) also check the air filter, You have fuel and its moving through but the fuel filter might be slightly clogged. As its starting and going on low your spark unit is ok but you might need a new spark plug.
Dec 21, 2015 | Stihl Garden
Where can I buy replacement line spools for this whipper snipper??
I think that might be a K-Mart line of products
Mar 31, 2015 | Garden
Restringing a talon hawk whipper snipper
There may be a latch that has to be released in order to rotate it.
Jul 19, 2014 | whipper snipper Garden
Pope whipper snipper starter cord problem
The first thing you need to do is take the recoil cover off. There are several parts to a recoil and one or more parts may be worn and coming out of place then jamming.Replace worn parts if this is the case. If the cord pulls freely when removed then you may have a problem in the engine, try turning the flywheel by hand with the spark plug out. If it does not rotate there is something inside the cylinder or broken in the crankcase. If it is a 4 stroke engine you may have fluid above the piston,you will find this out when you remove the spark plug. drain the fluid from the cylinder and replace the plug you will be good to go. Good luck
Feb 09, 2014 | Garden
Honda instructions
I need to take the head off of a 1999 honda vtec xhnvo2.3 pa3 how do i do it
Jan 01, 2014 | whipper snipper Garden
Sthil whipper snipper fs38 won't engage the starting pull mechanism, it turns but won't grab drive coupling
remove the recoil cover and check the dogs that engauge the starter to the flywheel
Jul 28, 2012 | whipper snipper stihl fs 38
Ryobi Whipper Snipper starts, runs but doesn't like to rev, as if it's either flooding or sucking too much air
you've answered your question i would be inclined to be looking at adjusting the high low idle mixture settings and checking for a good spark also check the exhaust is free of obstruction may have a blockage
Jul 18, 2012 | Ryobi Garden
Unable to get head of whipper snipper
After much mucking around I noticed a hole in the top shroud of the shaft. I placed a narrow screw driver through the hole until it made contact with the rotating part of the head and pushed until the head would not turn. I thern applied pressure clockwise until the head became loose. I did the reverse to tighten. The head of the unit will rotate anti clockwise to tighten as the shaft rotates clockwise during operation. I hope this explains the method.
Thank you any way for your interest.
Greg
Dec 21, 2008 | Echo Garden
Garden Logo
237 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
