Question about HP Scanjet 4670
HP4670 won't scan at higher dpi than 600, (even though it worked flawless the last time I used it)
A few months ago, I got this old scanner working with my windows 7 computer, it was working perfectly, no issues at all. Now, when I try to scan at 1200 dpi or 2400 dpi, the scan head seems like it's stuck and makes a clicking noise. I can scan at 300 and 600 dpi, and the preview mode works, so the head doesn't seem to get stuck under those modes If I scan at 600 dpi, the image appears to have waves in it. I'm wondering how something that works fine a few months ago, just magically stops functioning properly? I'm thinking of pulling it apart and looking at it. (it's out of warranty anyway)
4 Suggested Answers
SOURCE: scanner saying there's no disk space
Photoshop's scratch discs needed adjusting. I went to Edit-->Preferences-->Plug-ins and Scratch-discs and selected one of my drives as "first" (none was selected before). That's it! :)
Posted on Feb 26, 2010
yammy_alf
  • 666 Answers
SOURCE: The scanner is not scanning in photo scan mode and
that's hardware related problem, you need to open the machine and lubricate all moving parts specially in bulb image receiver side.
Posted on Mar 23, 2010
aviral_srms
  • 1216 Answers
SOURCE: i have a hp scanjetb
hp released 2 patches for this . download the patch and install them.
get the patch from here
Posted on Aug 04, 2011
My Canon P-150 keeps giving me a "double feed" error and won't scan.
Uninstall all drivers and scanning software. Switch off the comp and Scanner, restart the scanner first and then the computer. Then reinstall software again
Jun 07, 2012 | Canon imageFORMULA P-150 Personal Document...
Scans are taking a long time to scan.
1) Your scanning image resolution may be too higher set 300 dpi / 400 dpi / 600 dpi. Scanning now fast.... not ok look step 2
2) Re-Install Scanner driver / down load new driver. not ok look step 3
2) Replace USB cable.
Mar 28, 2011 | Canon CanoScan 8600F Flatbed Scanner
My sahara Flatbed Scanner works fine except that I cannot find how to print without a "grey:" background. What should I do to print with a clear white background? Eric Schafer. Cape Town RSA.
you will find if you reduce the dpi the scanner is scanning the pictures or documents in, that you will not get a grey background , as you describe, what it is printing is actually the paper itself, if you have it set for say 1200 dpi then reduce it to 600 dpi or even 300 dpi and you will see the difference when you print it
or only select the exact area you want to scan in the document, click preview then move the scan area selection box to exactly fit the picture you want to scan
Mar 27, 2011 | Office Equipment & Supplies
How to adjust the resolution to 300 DPI on an
If you are scanning, you should be able to set the resolution (DPI x DPI) in the scanner configuration. If it is blurry, it could be that the default scan resolution is lower (10 dpi or even 75 dpi).
Settings location will depend on the scanner and software used.
Best scan at an equal (300 dpi) or even higher resolution, so you can scale the image afterwards without quality loss.
Apr 23, 2010 | Microsoft Windows XP Home Edition
Scanner saying there's no disk space
Feb 25, 2010 | HP ScanJet 2200C Flatbed Scanner
I have recently purchased HP SCANJET G4050 , before the purchasing of device HP executives said that it has 3-D effect and it takes same time to scan for any resolution means higher resolution also but now...
when you scan at 1200 dpi its usually over 100 mb which is a waste of time but it is great to use when you want something to be outstanding but the best resolution is at 600 dpi which is what my scanner is set to its good resolution but requires alot less data around 4-5 mb so it save time but its good to have the 1200 dpi for project that you want to impress or scan pictures but you dont have to use 1200 everytime hope my opinion was helpful:)
Nov 16, 2009 | HP PSC 2355 All-In-One InkJet Printer
Scanning siezes computer and scanner
I believe that what you are having a power issue on the USB port. This port is limited to a certain total amount of power and if you are using other devices on the usb ports they each take away from the total amount available for use. The fix for this issue would be for you to buy a Powered USB Hub, as it has a transformer that plugs into the wall and will avoid using any of the computer's usb power to run the scanner.
Good Luck
Rich Lilja
Nov 26, 2008 | Canon CanoScan 8400F Flatbed Scanner
Scanning is bad, but copy text crisp!
Use Higher DPI settings on scanned text for OCR, than for copying,
in copies the printer does not know what it is looking at
in OCR machine logic has to determine what each shape is,
and translate it to a character.
at small DPI each letter may be too few dots high to easily differentiate between similar letters
compare the quality of 10pt text from a 9pin dot matrix printer, to 10pt text from a 1200dpi linotype or laser printer
higher dpi is easier to read, it is easier to OCR, the scan may take longer, the error rate needing correction will likewise be lower
A long time ago was scanning Telecom Australia paper bills into the first online service they had
My workstation, scanned at 1200 dpi, had no retyping
others were using 300 dpi then retyping all the errors
was paid by the page
I made way more money
even though the scans were about 5 times slower
Nov 06, 2008 | HP PSC 2210 All-In-One InkJet Printer
Help
Download firmware and Driver from Umax.com
Feb 03, 2008 | Umax (861002990000)
HP Scanjet 4670 Logo
21 people viewed this question
Seeker5211
Seeker5211
