Question about Galileo Thermometer
Repair galileo thermometer. Had for weeks and the balls have never moved
The balls in the thermometer have been at different temperatures but they never change position
My Vegas hot tub keeps showing eo3 can you give me some advice please
looks like it's got a bad thermister or thermostat
E03 The pump's thermometer reads the water temperature below 4°C (40°F)
1. The water temperature is lower than 4°C (40°F).1. The spa is not designed to operate with water temperatures lower than 4?C (40°F). Please unplug the pump and move to a warmer ambient temperature. The pump should only be restarted when the water temperature reaches 6°C (43°F).
» 2. The pump's thermometer is broken.
Hot Tub Ireland
Feb 24, 2018 | Pool & Spa
How do I change my thermometer from celcius to fahrenhet
Depending on what kind you are referring to there should be a button that you press to change it to different measurements of temperature.
Jan 16, 2018 | Thermometer Health & Beauty
How long do you cook a turkey in a Hamilton Beach roaster oven and what temperature
Hello Angela Couch,
You treat the Roaster like any other oven...
Off the TOP OF MY HEAD...
More importantly... The TURKEY must be thawed properly to be cooked properly.
I FIGURE 23 to 25 minutes per pound at
325° F... If Stuffed add a of pound of cooking time for each pound added by stuffing
Monitor closely with your MEAT THERMOMETER...!!
Your turkey is done when the temperature with a meat thermometer is 180° F in thigh and 165° F in chest or stuffing.
Take your instructions from the TURKEY...
(Altered appropriately by STUFFED or NOT
STUFFED) and backed up with a good
QUALITY meat thermometer...!!
BUTTER-BALL has one of the very best
on-line cooking calculators...
How To Roast Turkey Butterball
Proper left-over handling is also very important
Bon appetite & Merry Christmas!
Carnac the Magnificent
Dec 20, 2017 | Hamilton Beach Kitchen Appliances - Others
My fridge keeps freezing everything what is the best temp to have it set at. It is an aurora model RB411M3
I recommend moving the thermostat to the exact center position, unplug, then plug in the refrigerator. Wait 24 hours for the fridge thermostat to reset and to thaw automatically. Then, I recommend a fridge thermometer, available at most grocers or kitchen supply stores. If you can't find one, use a digital thermometer with a probe. Place the thermometer hanging from the center of the center shelf. Keep the refrigerator temperature at or below 40° F (4° C). The freezer temperature should be 0° F (-18° C). Allow 24 hours for any thermostat changes.
Apr 08, 2017 | Refrigerators
Hi. I have a Dihl WF-21SS Reviews and the temperature LEDs doesn't display correctly. Can it be fixed???
Here are the possible solutions if they don't fix it, you will want to find the authorized repair company as it is a control board issue.
1. Remove all your wine and beer and place it in your regular refrigerator.
2. Unplug this refrigerator and leave it alone for 24 - 48 hours.
3. Go purchase a refrigerator thermometer and put in in the refrigerator.
3. Plug the refrigerator back in and set it to the temp you like to keep it at. Do not put anything back into the refrigerator yet.
4. Check the temp of the refrigerator against the refrigerator thermometer - it is not unusual for the thermometers to be a couple of degrees in difference. If everything is acceptable, only place the wine back on the racks, leave the beer in the other refrigerator. Let it run for a week and see if it stays balanced.
Or - if upon initial check you find the two thermometers not agreeing you can do one of two things.
A. Best option - contact authorized repair and have them come fix it.
B. Leave the refrigerator thermometer in the fridge and adjust the display panel until the temp in the refrigerator is where you want it on the refrigerator thermometer.
C. Dispose or replace the refrigerator.
Note: I don't suggest overloading your refrigerator.
The original owner's manual is available here (I believe the last two letters designate the finish for example SS = stainless steel).
DIHL WF 21BD Instruction Manual
Best wishes,
Joe
Aug 25, 2016 | Washing Machines
Change temperature setting on Forehead Thermometer
no I contacted customer service, this thermometer reading ONLY in F, there is no option to change it to C
Jan 25, 2014 | Braun Home
Kenmore 700 series dryer little temperature difference between delicate and high
Using that thermometer I am guessing that the readings are close to what they should be. Typically there is not as big a temperature change between the two settings. What made her first think there was a big problem in the temperature settings?
Jan 22, 2013 | Kenmore Dryers
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
I cannot adjust the fridge/freezer temperature
Hi, there
Purchase an appliance thermometer that is specifically made for refrigerators and freezers. These special thermometers were made to withstand cold temperatures and provide an accurate reading when exposed to such temperatures.
2Place the appliance thermometer in a glass of water.
3Set the glass of water with the thermometer in the refrigerator on the middle shelf.
4Check the temperature on the appliance thermometer after 24 hours.
The temperature should register between 37 and 40 degrees Fahrenheit (2 and 4 degrees Celsius) in order to store food safely.
Only barely above freezing -- say 34 degrees Fahrenheit (1 degree Celsius) is even better for food storage at the cost of slightly higher electricity consumption. But check that food is not slowly freezing in any part of the refrigerator, which could make it less palatable.
5Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
If you can't easily see the control dial, check the owner's manual for a diagram that shows the location.
When looking at the refrigerator temperature dial, you may see numbers rather than degrees. The majority of refrigerators use a set of numbers, with the lower numbers representing cooler temperatures and the higher numbers representing warmer temperatures.
6Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
7Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
8Wait at least 24 hours, and then check the refrigerator temperature again.
9Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
10Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
11Repeat the steps as necessary until the temperature is within the safe range.
12Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
Hope that helps in solving the problem...
May 07, 2011 | Refrigerators
Galileo Thermometer Logo
109 people viewed this question
Top Galileo Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Galileo Toy Expert? Answer questions, earn points and help others
