Question about IBM ThinkPad T40 2373 Notebook
QUESTON I HAVE A FRIEND THAT HAS A IBM T-40 NOTEBOOK AND HE SAID IT WILL NOT TURN ON. DOES IT NEED A NEW BATTERY OR IS IT SOMETHING ELSE?
    Sergeant:
  • 324 Answers
Remove the battery. Check for voltage at the connector of the AC adapter. Plug adapter into the lap top and turn on. If it runs, yes, a new battery is needed.
When power up is attempted, does it make any sounds, can you hear the fan running or do any of the indicators light up? If so, you are getting power to the laptop. If not, you probably have an internal power supply problem.
Posted on Nov 03, 2007
Replace battery on ibm g21e
Click HERE to find your Replacement Battery if you need one.
Turn off your Laptop/Notebook PC.
Disconnect the Power Cord (AC adapter), close the display, and gently turn the laptop over, top-down.
slide the battery slider (it unlocks the battery, allowint you to easily lift the battery out of the PC) The new one goes in the same way the old one came out.
Simplen as that!
Again, your battery can be found HERE......... CLICK HERE!
Jul 06, 2010 | IBM Computers & Internet
Ibm t30 bios shows 512 megs of memory i have 1024 installed
Hello my friend if is not something visual(like unconnected soldering pins on the motherboard)then you can not do anything else than change your motherboard.But if you compare the two slots and you see difference then you can connect this tire or pins with soldering gun.
Feb 06, 2010 | IBM ThinkPad T30 2366 Notebook
Laptop
Both of them are NO rockets but if I got to choose I should take the Dell computer.
reason
because it has more RAM. the IBM had better processor and 10gb bigger disk. but only 256 RAM.
If you take the IBM buy more RAM to it and then the IBM is a better choice,
Sep 04, 2009 | Dell Latitude D600 Notebook
My IBM Thinkpad T22's battery doesnt last. can i fix that?
Basically you need a new battery. Recharageable batteries have a finite number of charge and discharge cycles and they lose their full charge capacity as the get older. The batteries will have less capacity over time ie less available battery time, and when it is worn out, it won't charge at all.
May 15, 2009 | IBM ThinkPad T22 2647 Notebook
My ibm laptop contionusly beeps and says power scource is battery,when i press esc, it boots normally and shuts down in about 15 mins to half an hour
Either:
A. Bad battery
Or
B Bad power supply.
Sounds like the battery isnt charging correctly , the beeping is warning you it is running out of power.
Take the battery out , and boot normally with the ac adapter.
Does it work?
If yes, Get new battery. about 70-90 dollars.
If no. Get new ac adapter. 20-40 dollars.
links to parts
http://www.nextag.com/ibm-a21m-battery/search-html
http://www.nextag.com/serv/main/buyer/OutPDir.jsp?search=ibm+a21m+ac+adapter&x=0&y=0
http://www.laptopuniverse.com/product/02K6496-Laptop-Notebook-Power-Supply-AC-Adapter-For-IBM-Lenovo-Thinkpad-A21M-16V-60W-Part-02K6496/LU/36124/productDetails.html
Mar 03, 2009 | IBM ThinkPad A21m 2628 Notebook
IBM thinkpad R-40
Remove the battery of your laptop, wait for about 10 minutes, reconnect the battery and try again
Nov 22, 2008 | IBM ThinkPad R40 2897 Notebook
IBM Thinkpad T22 Battery
pls first check your adapter may be problem with your adapter.
thank you
Sep 28, 2008 | IBM ThinkPad T22 2647 Notebook
Ac adapter problem
Buy a new T30 adapter off ebay, they are cheap enough and you could probably get OEM if you know where to look.
Mar 10, 2008 | IBM ThinkPad T30 2366 Notebook
My IBM do not turn on.. IBM A21M..
check power ac adapter and batery if the batery is ok or charge do a test to the hard drive and memory ram loock on BIOS
Jan 03, 2008 | IBM ThinkPad A21m 2628 Notebook
IBM ThinkPad T40 2373 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
