Question about Do All Traps Do All Outdoors Aerial Assault Black 3.0 Automatic Trap Thrower
Breaking clay every other throw, the clay targets are not dropping properly and it seems to be getting worse. is there too much pressure on the clay target above the one being dropped?
White wing thrower, will not stop throwing clays as soon as you turn it on.
[PDF]TROUBLESHOOTING AUTO TRAPS - kivelaoutdoor.com
www.kivelaoutdoor.com/.../TROUBLE%20SHOOTING%20AUTO%20T...
Is the throwing arm stalled while motor/gears are turning? ... "The Trap worked well at first but after a box of targets it started breaking a lot of .... Throwing Arm when to stopin the cocked position by killing the power to the motor when ... Arm doesn't move to the Disarm position when the unit is switch to Disarm, it could be that.
Sep 14, 2015 | Mtm EZ Throw II
The arm on my clayhawk full **** clay target thrower won't throw!
Anything with this much force in it is dangerous to work on unless you are totally knowledgeable. Seek help from a shop/dealer.
Dec 14, 2013 | Do All Traps Clayhawk Full Cock Clay...
Concrete tile or Clay tile
clay tiles have little more lifespan than that of concrete. While clay tile is only popular in its red color, concrete tiles are available in wide range of colors.
Clay tiles break easily but concretes do not. But both concrete and clay tiles are the pinnacles of beauty.
Dec 09, 2013 | Washing Machines
What are the best chokes to use for a beginner on clay pigeon shooting?
To increase your odds of hitting targets - use the most "open" choke that will maintain good density at the distance you're shooting - exactly the same as most experienced shooters do... Skeet choke for shooting Skeet, Mod to Full for Trap, Cyl to Light Mod will handle 95% of shots on the sporting clays courses around here.
To increase your skill - occasionally use your full choke for everything until you learn proper gun mount, swing, and lead and follow through. When you start getting frustrated, switch back to the open chokes to get a little positive feedback on some close targets, then move back to the full choke.
Jan 17, 2013 | Sport & Outdoor - Others
Sculpey and firm sculpey tend to crumble even after kneeding
Found this on the Sculpey website- Hope it helps :)
"If your clay is just a little dry or firm, it may only require the addition of Sculpey Clay Softener to reconstitute it (about 6 - 8 drops per 4 oz clay or 2 - 4 drops per 2 oz clay).The Clay Softener will not restore clay once it has become very hard or after it has been baked. If the clay is already crumbly, it has either had too much exposure to heat or old enough to have already undergone some chemical changes. At this stage, it cannot be reconstituted satisfactorily. Adding a pinch of Sculpey MoldMaker to clay that is a little dry or firm will also help reconstitute it."
http://www.sculpey.com/faq-new/209#
Sep 21, 2011 | Sculpey Crafts & Hobbies
My 2004 ford ranger v6 3.0L suddenly started ideling hard and poor acceleration(loss of power) we have discovered that a couple of the pistons aren't firing properly but don't know how to fix it! we...
your timing belt/ chain could be out of time, could have a clogged cat/ could be bad o2 sensor throwing off the air/ fuel mixture. any combo of those also.
have you done a cylinder pressure test?, that will determine if you have a blown head gasket or not. cuz if its a gasket, the pressure would just go to another cylinder and no pressure = no power.
Jan 12, 2011 | 2004 Ford Ranger
OIL PRESSURE SEEMS TO BE GETTING ALITTLE WORSE IN BETWEEN OIL CHA
this all sounds normal the reason your pressure drops is because the oil breaks down between oil changes with that kind of mileage all is good
Apr 07, 2009 | 1998 Buick LeSabre
Do All Traps Do All Outdoors Aerial Assault Black 3.0 Automatic Trap Thrower Logo
369 people viewed this question
Top Do All Traps Sport & Outdoor - Others Experts
Are you a Do All Traps Sport and Outdoor - Other Expert? Answer questions, earn points and help others
