Question about SanDisk Sansa Clip MP3 Player
It will not turn on any longer
It was working when I went for a walk, turned it off and when I tried turning it back on it wouldn't work. Not sure what happenned, can anyone help?
  • Anonymous May 21, 2009
    it won't turn on and has a line down the scren
The problem lies within the mp3 all you got to do is fisrt.becarefull and take it apart once you have the other layer taken off then take the back off then at te top where the power button was there should be a lil square take something small and push in the lil square and it should come on the reason it wont cut on any more is due to the power button. the lil hole at the end of it is missing the part that normally pushes inside the square button is missing you will have to figure something from there to turn it on.i had to rig mines and your welcome.for further information you can call me at 771-3337
yours truly C.3.C
Posted on May 19, 2009
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
My 98 Sentra does not turn over
Has the battery been load tested? do that first.
Apr 30, 2017 | 1998 Nissan Sentra
I can't turn the key to my ignition switch and the power steering is lock too. The position of the front tires are not straight.
Turning the wheel back and forth while trying the key should work. In the future try not to lock the ignition with the wheel turned hard.
Aug 30, 2017 | 2005 Hyundai Santa Fe
Wii stopped working
Make sure your cord is plugged in all the way and do other electronics work in the same power plug?
Dec 17, 2011 | Nintendo Wii Console
Frigidaire dryer not working drum won't spin,
Hi How old is it , ? and dose it soun like the motor is running but not turnning the drum ? this would be a bad belt , you will need to do some more investagating for me to help you
Dec 06, 2011 | Frigidaire Dryers
Water pump and ignitor do not work
took coleman away for weekend wouldn't work. Very dissapointed, was cold would have loved a hot shower. Had charged battery, when I went to start it. It wouldn't go, light come up as battery low tried it on car charger still no luck. Got home and looked up this site told me to try taking filter off pump and putting a long nail inside to turn pump to make sure it wasn't seized. And guess what every thing works well thank god, water temp was dodgy as well but now all good. Thanks to people that do reply to these sites, it has saved me a lot of money and frustration.
May 23, 2011 | Coleman Hot Water On Demand
2004 Sante fe 3.5L 2WD went out to go to work and wouldn't turn over, (assumed dead battery), went down and got new battery and installed, still wouldn't turn over, (assumed starter shot),removed...
TEST POWER LEADS TO STARTER FOR POWER
AT STARTER (BATTERY POSITIVE TO STARTER BATTERY NEGATIVE TO ENGINE BLOCK)
THEN TEST FOR SIGNAL POWER TO SELENOIDE ON STARTER
(KEY TURNED TO START POWER SHOULD GO TO SELENOIDE)
IF NO POWER TO SIGNAL WIRE CHECK FUSES AND RELAYS
ON STARTER CIRCUIT
IF THIS CHECKS OUT MAY BE AUTO TRANSMISSION NUTRAL PARK SWITCH
TRY TO START IN NUTRAL OR WHILE SHIFTING TRUE GEARS SLOWLY WITH SHIFTER
IF STANDARED CHECK NUTRAL SAFETY SWITCH
May 08, 2011 | 2004 Hyundai Santa Fe
Bike Died - No Power
i would check if you have a short somewhere.....but first make sure your battery connections are tight....gauges turning off and on while riding is usually a sign of a loose connection meaning you hit a bump or something and it briefly clips out...did the bike actually turn off??? i dunno....but that seems to be a very odd problem....take out the battery, put it on a trickle and let it charge to full cap....then reconnect making sure the terminal connections are secure and see what happens.... if that works, we''ll have to start diagnosing further, but like they always say, check the obvious first !
Nov 20, 2008 | 2006 Honda CBF 600 S ABS
Won`t turn on
Try leaving it unplugged for longer period of time. Look on the remote for any possible reset function. Try power button without the remote. If any ot these doesn't work there is a power supply module inside that malfunctioned. If under warranty contact where you purchased it. If not under warranty if you can get the module it is a simple plug up procedure.
Dec 31, 2007 | LG 42LC7D-UB Television
SanDisk Sansa Clip MP3 Player Logo
372 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
