Question about Hayward H-series Electronic Gas Pool Heater H400
I'm trying to start-up a Hayward H400 natural gas heater for my pool. It was brand new last season and worked perfectly. It keeps firing up for a little while (maybe 10 seconds on average) and then shuts off and re-tries. After that, I get an "IF" failure light. I'm thinking maybe my gas line needs to be purged? Any help would be appreciated since Blue Haven pools support really sucks. Thanks.
    Problem Solver:
  • 10 Answers
If means ignition failure check that gas is on, check for fauilty igniter wiring or connections, inspect gas valve wiring measure voltage across gas valve during trial to ignition if 24 volt replace gas valve if no 24 volt replace control module
Posted on May 19, 2009
Have a bo code heater keeps cycling on and off
BO code is bypass operation. It means that it is set to operate with an external controller. Things like Aqualink, Aqualogic, Intellitouch, EZ-Touch are all types of automation / external controllers. They have their own temperature sensor and allow remote control operation. To truly find the nature of your issue. I'd start by taking it out of bypass operation and see if the unit fires by itself ( without automation hooked up to it ). The fault may lie with the automation system. You never know.
May 24, 2014 | Hayward H-series Electronic Gas Pool...
My Hayward H400 will not turn on
Does the heater sound like it is trying to fire? (Fan on, clicking sound). Check your filter pressure. If it is high, it may be causing the heater not to fire because the heater doesn't know the pump is running.
Apr 12, 2014 | Hayward H Series Pool & Spa Heater 400k...
IF error code when trying to start
Error IF is ignition failure.
Last page shows troubleshoot walk through ranging from low gas pressure to bad gas control valve to failed wiring etc
http://waterheatertimer.org/pdf/Hayward-error-codes.pdf
Oct 28, 2012 | Hayward H-series Electronic Gas Pool...
CAN A OLD STYLE H400 NATURAL GAS BE CONVERTED TO A LP GAS I HAVE A H400PED2 IT DIED IT IS NOT MAKE ANY MORE IF I FIND A H400 NATURAL GAS CAN IT BE CONVERTED
The last I checked a kit was available for this conversion.
I recommendyou call the Hayward technical support at 908-355-7995and they might be able to help you figure this issue out. Ihope this helps.
Sep 17, 2011 | Hayward H-series Electronic Gas Pool...
Can an H150PI pool heater be converted from propane to natural gas
On this heater, the conversion may be a kit that replaces all the orifices. In any case if you call Hayward technical support they should be able to provide the correct solution. I hope this helps.
Jul 27, 2011 | Hayward H-series Electronic Gas Pool...
Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Hayward H400 will not ignite
Gas valve.
Gas valves will often stick in the closed position especially after sitting dormant for a period of time.
if you want the posibility of one more season, You can try to tap on the bottom ans side of the valve with handle of a screw driver while it tries to ignite. Note: This is a technician trick, most manufacturers will not approve in fear you are so lacking in common sense you will go out and beat the valve with a hammer, then sue them when it cracks the metal valve leaking gas while you smoke a cigar ultimately relocating your heater on top of the neighbors Buick..so please don't do that. BUT, If the valve opens and heater fires with a few love taps try it a couple more times to see if it will work on its own. It will likely continue to work if so.
You will likely need that gas valve next year anyway.
Apr 25, 2017 | Hayward H Series Pool & Spa Heater 400k...
Hayward H-series Electronic Gas Pool Heater H400 Logo
1,031 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
