-   The printer could not print anymore because the port is in use-   Guest
Jul 30, 2008
-   not able to print using samsung scx-4x16 series printer. This happens only when our application is being used. Outside the application the printer prints fine. what could be the reason -   Guest
May 21, 2008
-   not connecting to computers and states paper jam when there is one not there
-   Guest
getting an error while printing from a particular application. Error Printer could not print any more because the port is in use. Printer is Samsung Samsung SCX-4x16 ver 5.56. please help!!
Had the same problem and was ready to throw out the printer when it was suggested to reload the software. Now it works again. Hope the results will be the same for you.
it says i have to download a high speed usb controller for my wireless usb adapter for it to be...
(More)
it says i have to download a high speed usb controller for my wireless usb adapter for it to be faster. i have a dell where do i get this download
On IMac OS 10.4 The printer gave me the choice of printing both sides.
On )S 10.6 that choice has...
(More)
On )S 10.6 that choice has disappeared.
Canon PIXMA MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL...
(More)
Canon PIXMA MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL PROBLEM paper jam problem began when a dangling telephone wire got caught in paper intake. it was removed very gently. no error message. Tried to print, got error message at ejection slot turned machine off and on. after being turned on, a sheet of paper will pass through the machine but paper jam message continues. WHAT I HAVE TRIED, FOLLOWING EARLIER FIXYA SUGGESTIONS since then. I have. 1. turned printer upside down 2. gently cleaned out paper dust on either side of the paper rollers 3. checked that paper roller is still rough 4. tried to change to feed from lower cassette. will not accept feed switch command 5. removed and reinstalled print head (which was replaced last month) PROBLEM REMAINS. turned machine off and on. after being turned on, a sheet of paper will pass through the machine but paper jam message continues. QUESTION: WHAT TO DO? Background: we have in past two months cleaned the WASTE TANK following the instructions here and reprogrammed it and, after the print head refused to print from the smaller of the black cartridges, replaced the print head. We get a flashing light when printer is turned on and a small grind, but then the light disappears.
Canon MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL...
(More)
Canon MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL PROBLEM paper jam problem began when a dangling telephone wire got caught in paper intake. it was removed very gently. no error message. Tried to print, got error message at ejection slot turned machine off and on. after being turned on, a sheet of paper will
pass through the machine but paper jam message continues. QUESTION: Background: we have in past two months cleaned the WASTE TANK following the instructions here and reprogrammed it and, after the print head refused to print from the smaller of the black cartridges, replaced the print head. We get a flashing light when printer is turned on and a small grind, but then the light disappears.
when i try sending fax it says low memory on display and the fax doesn't go through it stops.-- low...
(More)
when i try sending fax it says low memory on display and the fax doesn't go through it stops.-- low memory
