Hi my yamaha fzr 400 keeps dying after like 10-15min of driveing i installed a new regulator and did strip the carb and cleaned it out now i drive for like 10-15min and then it just stops and doesnt wanna drive any further it starts but when i put it in 1st gear it jerks all the way and then dies any help pls
SOURCE: motorcycle dies after 5min
If it's dying that quick because the battery went dead, it might be a charging problem.
Get a MultiMeter:
http://www.harborfreight.com/7-function-multimeter-98025.html
Make sure the battery is charged, and start the bike.
Put the multimeter leads across the battery terminals (red to +, black to -)
You should be getting 13-14 volts, with the voltage increasing as you rev the motor.
If not, either an alternator or voltage regulator problem.
IF the battery is going flat in that time WITHOUT the motor running, you have a "parasitic" drain somewhere, that is draining the battery when it's off.
also i thought it might be flooding so i stripped the carb again and bend the plates a little bit but after tht it didnt wanna start so i thought oki well the carb aint getting fuel took it off again but there was fuel in the carbs
