Question about MSI Computers & Internet
Fan on full speed and than switxh off msi cx700
At start-up, fan goes on full speed about one minut, than shuts down. (windows starts up)
  • Hans
    Hans Dec 29, 2013
    System starts up normally, CPU and GPU are not hot. Cleaned cooling system and put new paste.
  • Hans
    Hans Dec 29, 2013
    Despite the abovem the fan keeps on full speed and system shuts down after about a minute or 2
You will need to disassemble the fan and clean off dust accumulated. also check for any obstruction of the fan slot.
Posted on Dec 29, 2013
Testimonial: "Thanks for your reply. Did that already, se my 2 comments."
check your graphics cards control pannel if you have one and you may have a manual fan adjust their, if not try a utility called speedfan which lets you manually adjust your fan speed.
Dec 29, 2013 | MSI Computers & Internet
Blower start up problem
The motor is bad. It is overheating and shutting down on thermal overload. You need a new motor
Jun 24, 2017 | LG LWHD1200FR Wall/Window Air Conditioner
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
Laptop goes on some few minutes after being shut down.
you cannot blame windows xp because according to me it is such OS that it removes many problems of windows 7 and vista.windows 7 and vista makes your pc much slow and many features dont work but windows xp is free from these errors.actually you hear the sound but nothing appears on the screen.this is because your cpu fan is running which takes somes time to stop.may be some problem of the hardware especially the mainboard.go to any repair shop and just get it checked.
Apr 02, 2012 | Toshiba Satellite Pro L300 Notebook
My msi cr600 keeps hanging for 3-10 minutes and it works fine after and does it at anytime it wants. Sometimes I could be closing a tab, sometimes I could be clicking the start button. In fact, typing in...
Make sure you are using it on a hard flay surface, the fans underneath need to pull in air to keep the cpu cool. Also make sure the fan is working underneath. Make sure you do not have a lot of applications running at the same time as it will bog down your system. There is a free software called speedfan that can let you see the temp and fan speeds of your machine, google it. "DO NOT CHANGE YOUR FAN SETTINGS!!!" This program is good for seeing the temp of your cpu , but if you go and start changing settings you can damage your system. I would watch speedfan to make sure the temp stays constant and that the fan doesn't intermittently stop.
Jan 11, 2011 | MSI CR600-001US Notebook
The system doesn't boot, more excatly the PC tries to boot. Just as windows is about to load two short beep's is heard, and the board reboots (System fan slows down in speed and then bios is loaded...
Your computer registry is damaged and windows shuts this down to avoid further damage, the only thing to do is use a recovery disc on start up.
Oct 03, 2010 | MSI K9VGM-V Motherboard
I have a EMachine T6534 which won't start. I shut
I agree...sounds like a power supply problem. Typically a bad power supply will not damage the motherboard. It should still be functional.
Sep 02, 2009 | Computers & Internet
Computer shutting down
  1. Be sure your power supply is working and charging battery
  2. Allow battery to full charge
  3. Be sure PC is cold not hot or warm
  4. check if before shutting down PC fan is starting: if not starting PC thermal protection can be triggered and your fan out of service.
Jan 14, 2009 | Acer Aspire 3000 Notebook
The power light keeps flashing orange
I had my Optiplex GX520 at work shut down abruptly every time I turned it on it in the morning. This would always happen within the first 30 minutes. I would then get the flashing amber light. After starting the PC again, it would stay on all day (over 8 hours) without shutting down again. I found that the power supply was over-heating.
Two things need to be done. First, in order to get the amber light to stop flashing, un-plug the computer from the wall for 30 seconds then plug it back in. OR hold down the power button for 10 seconds or so. The light should stop flashing. Then press the power button again and the PC should start.
But why did it abruptly shut down in the first place? The power supply has a fan-speed-control circuit in it to keep it running slow and quiet when the power supply is cool. It gives the power supply lower voltage when the power supply is cold and higher voltage as the power supply gets warmer. This circuit either is not working correctly or the fan getting sticky over the years and needing more voltage to get it moving when it is cold. I found that the fan was not starting at all and causing the power supply to over-heat.
To keep the fan moving at full speed, I cut the wire to it and wired it to the +12v output directly. Not the fan goes at full speed all the time. And yes, it is nosier. But at work it doesn’t matter.
The best solution would be to just get another power supply from Dell if possible. Or buy a +12v, 70mm fan from Digi-Key and replace the original.
Jun 27, 2008 | Computers & Internet
MSI K8TNeo2-F v2.0
This is not too uncommon scorcher63.
From what you stated, when windows does start it only goes so far & than re-starts it's self, like loading in a loop. Than at times it loads the start up options.
For reasons unknown, your windows (startup files) are corrupted. Easyest way to fix this is. Put you windows CD in the cdrom, shut down the system. Start the PC & press the F8 key every 2 seconds. A boot menue will load. Use the up & down arror keys & choose the cdrom drive. You will see (to boot from cd press any key), press the space bar. The cdrom will startup. Windows will start to load. You want to repair windows. This option will re-install windows but will leave most of your personal data alone. Like My Documents your username. Some programs "may" need to be re-installed. After installation is complete remove the windows cd & shut off the PC. Start the Pc, windows should load. Run Windows Update. If you have a antivirus program please do a full system scan. Run windows Defrag program.
scorcher63, if you have more question just post them here.
Feb 21, 2008 | MSI K8T Neo2-F Motherboard
Computers & Internet Logo
67 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
