Question about Covercraft 2000 Chrysler Sebring - Fits All Submodels - Ultratect Convertible Interior Cover
When doors are locked battery goes dead - Covercraft 2000 Chrysler Sebring - Fits All Submodels - Ultratect Convertible Interior Cover
Dead battery on 2004 mountaineer and can't open doors.
I thought this vehicle has an actual key (not just a fob) that goes in the ignition switch. So the same key should manually open the doors also...
If you cannot open the door with the key for some reason ... there is always the coat hanger trick ... or call AAA:
HOW TO OPEN OWN CAR IF DOORS ARE LOCKED AND BATTERY IS DEAD
Feb 16, 2018 | Cars & Trucks
Key problem, I don't have a spare key and the key is not opening the door. The opening button on the key is very dead, please help me
First, the key"fob" has a battery inside. Any parts store should be able to help you replace it. Second, you should be able to insert the key into the door lock to manually unlock door. If car's battery is dead, most doors will let you insert the key and turn as far as it goes, Then operate the door handle and turn the key a bit more to unlock it.
Apr 06, 2016 | Cars & Trucks
How to open doors on 2000chevy malibu battery dead?
The outside door locks/trunk lock will most likely not work due to the key not being able to be inserted/turned in the lock cylinder due to lack of use. Spray WD40 into door lock cylinder using supplied straw and insert key until it goes all the way in using sawing motion. If lock cylinder still will not turn continue sawing motion with key while holding gentle turning pressure on the key. This will usually free up any sticky/seized lock cylinder wafers and allow the cylinder to turn
Nov 29, 2015 | Cars & Trucks
2011 ford fusion se Car dead locked out key won't work please help
replace batteries in remote & charge battery on car, you will need to "Break" into your car you can do this by wedging the door from the top back corner & using a wire coat hanger to activate the door locking mechanism on the inside, once open, unlock all doors manually then remove battery for recharging,
Nov 12, 2014 | 2011 Ford Fusion
What would cause my automatic door locks to lock and unlock and my emergency flashers to flash with the engine turned off and the key removed until the battery goes dead?
You did not post the year make and model but two things that can cause this are the push button for the door locks are bad or the body control module is bad.
Aug 30, 2014 | Cars & Trucks
Remote door locks keep engaging and disengaging until battery goes dead.
There is either a short in the receiver logic board for the remote, its wires or a relay chattering in the fuse box...Pull the door lock relay in the fuse box to prevent the battery from being drained and begin troubleshooting.
Jan 22, 2013 | Ford F-150 Cars & Trucks
Everything is dead in my vehicle. There were no symptoms or indicatior lights prior to this. The key fob won't engage
this is due to a dead battery, the problem is getting into the car to connect jumper cables to try and start the car, alot of these cars are all eclectronic controllled and the key fob is what controls door locks and starting but with a dead battery it cant communicate with computer, if the doors are locked and theres no lock on the door to unlock it then you will need to have AAA unlock it with a tool that goes inside to release lock and then gain acess to battery and replace it or jump it, and go from there, it may just be a bad battery or something was left on like a light but most of these cars have an anti drain module which will shut power down if something is left on until the engine is started. good luck and hope this helps.
Apr 10, 2011 | 2006 BMW 3 Series
97 Jaguar XJ6 No Start (good battery- no click)
when you battery goes dead, the security system locks the car. When you charge the bathery, use the key to lock the door and hold until the alarm activates. open your door and you can now start your car...dmakia@gmail.com
Mar 16, 2009 | 1997 Jaguar XJ6
Covercraft 2000 Chrysler Sebring - Fits All Submodels - Ultratect Convertible Interior Cover Logo
69 people viewed this question
Top Covercraft Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Covercraft Garden Expert? Answer questions, earn points and help others
