Question about Sony Grand WEGA KF60WE610 60" Rear Projection Television
KF60WE10 SOLY Dlp with a Gray screen
I have a 60 inch KF60WE10 Sony Dlp and when I turn the TV on it goes Gray, I still get sound but the screen is Gray. After 4 or 5 minutes sometimes the picture comes back but after 2 or 3 minutes it goes out again. I have replaced the bulb with a new Phillips bulb but no change.
  • 3,230 Answers
Yep, your problem is a relatively easy one to repair if you know how to solder. You better repair it before it blows the fuse though. There are two capacitors in the main power supply that are coming loose and need to be re soldered.
post further comments for more help..
Thanks
Posted on May 19, 2009
Philips tv 50pl9126d/37 help
Hello your problem is you have a bad color wheel that needs replacing.
Nov 09, 2011 | Philips 50PL9126D/37B 50" DLP TV
This gray box won't go away on my uncle's TV. It says "Video 5 Cable Box" and appears at the upper left-hand corner and won't go away. It has been there for a few days. It's a first. The TV has...
hello my name is rico, you have bad main board, and it needs to replace it, for the square box to go away. if you need more help, call me anytime. 602-810-7149.
Jan 07, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
Signs that the bulb in a dlp is going out
A DLP Lamp will fail in two ways. 1.The glass tube housing the filament will shatter and the TV will not turn on. 2. The lamp has many hours of use on it and will gradually grow dimmer. At no time will the lamp cause any picture defect. Check your Cable or Sat box for the correct aspect ratio as well as the TV aspect ratio. Chances are the aspect ratio in either system is set incorrectly. If the gray borders are uniform then the aspect ratio is not set properly. If this occurs on certain channels but not others then the particular channel is broadcasting in the 4:3 aspect ratio and there is nothing wrong with your set.
Apr 12, 2010 | Samsung HL-67A510 67" DLP HDTV
Sony 60 inch tv. Sound & picture goes out after turning on. What's wrong with it.
my tv powers up for about 1 minute and then shuts off what could be the problem,
Apr 06, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My sony wega 60 inch tv will not turn on. The
I bought a new blub for it and the light still goes green then red.Anybody know?? mg
Sep 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Gray box on screen with sound.
It sounds like you need to turn off the text mode in the closed captioning menu,
Jul 23, 2009 | Samsung HLT6187SAX 61" DLP HDTV
Multi color stripes on 60 inch sony wega, no picture
it sounds like the projection unit went out. if it is still under waranty then i would take back and get it fixed for free. if anything i would contact sony and tell them what is wrong with the tv.
Dec 19, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Toshiba 52HMX95 DLP has weird gray think line
DLP TVs work projecting light throught a tube covered with mirrors, called the light tunnel.
The gray shadow it is something in the middle of the light tunnel, probably a mirror that has gone out of place when you moved the TV.
Sep 01, 2008 | Toshiba 52HMX94 52" Rear Projection HDTV
Sony grand wega kdf-60 won't power up
It's likely to be the lamp Sony p/n# A-1052-675-A which is a generic Xl2100 which you can purchase from companies like DLP Lamp Source. http://www.dlplampsource.com/
If you're not real sure about doing this have a tech come out and do it, it's an in-home repair.
Bill
Nov 21, 2007 | Sony Grand WEGA KF60WE610 60" Rear...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Grand WEGA KF60WE610 60" Rear Projection Television Logo
76 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
