Question about Samsung 8000 Series UN60F8000BF 60" LED Smart TV 1920x1080, 240 Hz, HDTV, 3D
Blurry Smart TV
I recently just bought this TV at Best Buy. I was on my computer and when i went to watch some TV I saw that the antenna in cable was unplugged. So I plugged it back in and the screen was all hazy. The text on the guide was really blurry and had ghost effects. The definition of the menu in the smart hub, menus not including the cable, were all clear and high definition. Please help I don't wan't anything happening to this TV because I spent a fortune on this.
  • Justin Pinde
    Justin Pinde Dec 29, 2013
    Heh, nevermind. I put the HDMI cable in HDMI 1, and the default cable plug was HDMI 4. No need for help and have a Happy New Year!
    Genius:
  • Samsung Master
  • 2,432 Answers
If you hooked up a computer then you are watching a local tv station the video will be affected. their will be an interference on the signal. you must disconnect the cable going to the computer first.
Posted on Dec 29, 2013
  • 395 Answers
SOURCE: Samsung lcd tv le40r8
if the unit is under warranty call samsung for the nearest authorized repair place. the problem is a bad main board.
Posted on Feb 24, 2008
CAYPIANAN
  • 227 Answers
SOURCE: Please Help!! Black Screen, Red Light Flashing
is this a plasma or a dlp tv? if is a dlp a have bad news for you get rid of the tv, if is a plasma then is something different, post the model # anyway to see if we can help you.
caypianan@yahoo.com
Posted on Nov 08, 2008
SOURCE: Samsung ln t4661f picture issues.
We have the same problem. I am afraid it is a defect that is occuring in the samsung tv's
Posted on Aug 04, 2010
walesarumi
  • 6993 Answers
SOURCE: 52 in Sansung lcd tv , Model # LN52850 blurry
Basically, blurry pictures is a fundamental mismatch between the resolution capability of your TV and the resolution of the analog signal. The standard, analog signal is a low definition, 480i signal with a resolution of approximately 640 x 480. In most cases, your LCD TV is a high definition TV with a resolution capability of 1366 x 768, 1440 x 900, or 1920 x 1080. It is this mismatch between the standard signal resolution and the TV resolution that causes the picture to be stretched and scaled, blurring the image.
Fixing the Problem
There is no way to fix this mismatch in resolution besides switching to an HD signal. There are, however, three ways you may be able to minimize the blurriness problem:
* Reducing the picture size to 4:3
* Using the Sharpness function
* If you are using a cable box or some other external device, changing the connections
All three are described below.
Reducing the Picture Size to 4:3
If you are watching an analog channel or transmission, and the picture is fuzzy, you may be able to clear up the picture by reducing the size of the picture to 4:3, the native size of analog TV pictures.
To change the picture size to 4:3, press the P.Size button on your remote until 4:3 appears on the screen. The 4:3 picture has black or grey borders on the left and right.
Using the Sharpness Function
If the picture on your LCD TV is blurry, you may be able to clear it up with the Sharpness function. To use the Sharpness function on most Samsung LCD TVs, follow these steps:
1. Turn on your TV.
2. Press the MENU button on your remote. [The Main menu appears]
3. Press the Up or Down arrow button on your remote to select Picture, and then press the ENTER button. [The selection bar moves into the Picture menu]
4. Use the Up or Down button on your remote to select Sharpness.
Note: On some model LCD TVs, you use the Enter button to select Sharpness.
6. Use the Right arrow button on your remote to increase the sharpness.
7. Press the EXIT button to exit.
If You Are Using A Cable Box Or Other External Device
If you are using a cable box or other external device confirm that you are connected with Component (Pb, Pr, and Y) or HDMI connections.
Lastly, your connection cable might be failing and maybe that's the blurry picture displays at first, then goes back to normal later. So make sure cable connections to the TV are firm.
I hope you understand the above.
Good luck.
Posted on Feb 15, 2011
Geekman
  • 32281 Answers
SOURCE: How do I connect my ps3 to the Samsung smart tv
For best performance I recommend you connect a HDMI cable from the PS3 to the HDMI input on your TV.
To display the PS3 you need to select the HDMI input on your TV.
Posted on Mar 11, 2012
My Tv no longer registers a signal from the antenna. I can see a picture thruogh my smart DVR and Chromecast but no pic with TV antenna. I bought a new antenna, still no signal.
Is the TV set to air or cable? It has to be set to air/antenna and a channel search has to be done first before a picture will show.
Mar 07, 2016 | Zenith Z50P3 50 in. Plasma TV
Where is the antenne hookup
How to Hook Up a TV Antenna: 7 Steps (with Pictures)
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Hook Up a TV Antenna. Two Parts:Picking an AntennaConnecting the AntennaQuestions and Answers. Want to ditch your cable, but still like to watch the ...
How to Connect an Over the Air TV Antenna to a Flat Screen ...
? 6:37
https://www.youtube.com/watch?v=9Pq8e57O4zk
Sep 19, 2012 - Uploaded by All About Home Electronics.com
How to watch digital channels without cable TV or satellite for FREE? ... How To BUILD The BEST HDTV ...
How to Connect an Antenna or Cable to Your HDTV - Video ...
www.dummies.com/.../how-to-connect-an-antenna-or-cable-to-your-hdt...
The first step to connect an antenna, is to find the input port on your HDTV. Look for the VHF/UHF input. It's usually on the side or in the back of your HDTV.
Jan 24, 2016 | Televison & Video
I want to watch Netflix on my tv, not on my computer.
get a Chromecast, better than having cables laying about, you will need a spare HDMI port
Mar 01, 2015 | Netflix
My tv could not pick up any signal and it is also blurry.
sure you inserted the cable, coming from your cable company, or from the antenna? did you put in any signal at any port? If so and he TV still does nothing more, contact the deal you bought it.
Jul 23, 2014 | Sharp 21" Multi System Stereo TV
Blurry picture on my 70" vizio
As previously mentioned, try a known good DVD to the same connection (BE SURE TO USE A DIFFERENT CONNECTING CABLE,as your connect cable may be at fault) Also try any of your other inputs to the TV to eliminate 1 or more input issues.
Mar 21, 2014 | Vizio L32 32 in. LCD HDTV
Do i need a tv tuner to receive an internet tv signal?
No need,you must have only the antenna for internet,like smart broadband to watch online channel all you want to do is look only for the website that has an available online channel. It is also possible to installed a TV tuner to your computer but the antenna you will used is the antenna for TV(coaxial cable). The Antenna for internet and the TV tuner is separated, it is not the same antenna.
Hope this simple information could help you to solve your problem. Mam/Sir don't forget me to rate me up I really appreciate what grade will you given to me. Thanks a lot and God Bless.
Jul 14, 2011 | Computers & Internet
Do i need to set my lap top to be able to watch tv.if so what ?
you can watch tv tuner its USB device for laptop allow to watch or install softwarefor more information refer to http://laptoplogic.com/resources/detail.php?id=46 you can getinformation about tv tuners
Nov 18, 2009 | Compaq Presario CQ60-220US PC Laptop
Finds no channels
It is meant for Rabbit Ears or Outside Antenna Only.....
Jul 24, 2009 | Insignia Digital-to-Analog Converter for...
Need a smart antenna to go with the Digital TV converter box
First, you don't need a Smart Antenna, the manual is simply stating that your converter will use one if you have it. Any standard antenna will work, so there is no need for a coupon to pay for a new one, whether indoor or outdoor depending on your location and distance from each channel transmission tower. Since you don't give details of what antenna you are using, I will assume you have rabbit ears for each converter. Rabbit ears are notorious for poor reception and any metal or persons nearby will change the reception quality. I would recommend a roof mounted external antenna with splitters for the 3 converters if you have the option. If not, use an amplified internal antenna and mount it closest to the channel towers you will watch most and as high as possible. If you can find a smart antenna, which is an amplified indoor/outdoor antenna with a control cable for changing the direction of reception, for a decent price, you can use that but keep in mind that to use the control feature you will need one for each converter. Also, check antennaweb.org for information on digital channels in your area and their direction and distance. Antennaweb.org will also tell you if any digital channel in your area uses VHF frequencies. If they don't then a UHF only antenna will work fine.
Jul 16, 2008 | RCA Universal Remote Control
My new tv only gets some channels and not others
Have you tried an amplified antenna? It's basically a regular antenna but includes an amplifier to help bring in weak stations. An out door antenna may also help. I live about 3 miles from a TV station and can't pick them up due to the insanely old apartment I live in.
Jun 03, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Samsung 8000 Series UN60F8000BF 60" LED Smart TV 1920x1080, 240 Hz, HDTV, 3D Logo
104 people viewed this question
Henry  Thomas
Henry Thomas
