Smiggle jump clock how to change batteries - Audio Players & Recorders
How do I get my smiggle alarm clock to ring at a.m and not p.m
There is usually a 'PM' indicator on the alarm screen to indicate when the alarm is in pm. You hold down the alarm key to set the alarm.
Mar 31, 2015 | Audio Players & Recorders
Battery dead - car will not start or be jumped started
Change the battery. Newer batteries sometimes go all at once, and are so dead even a jump start won't work. It has happened to me twice. Once you put in the new battery check the alt output with a volt meter should read about 14.5 volts at the battery. If it does problem solved just reset the clock, radio etc.
Dec 14, 2013 | 1981 Chevrolet Corvette
How do I set the time and date for my smiggle small time clock?
If you don't have the instructions then go to the manufacturers' web site to down load one.
Mar 17, 2013 | Audio Players & Recorders
I have a 2005 potiac grad prix the car wot kick over it grids whe starti it the clock restarts itself is it the battery or starter
if the clock resets then the battery voltage to the car is going to low make sure the battery cables are tight then try and jump start it with another car if it starts when jump starting it the battery is died
Sep 11, 2012 | 2005 Pontiac Grand Prix
Battery on a 2005 Mustang went dead. Had a Jump to get the car started. Drove & speedometer & odometer worked fine. However, I had Triple AAA install a new battery & now they don't work. ...
Did AAA clean the battery cable connections when they installed your battery? Did you check the fuse for the insrument panel?
It could be just bad timing or a coincidense but I am more likely to think things are connected. If your gauges worked after jump starting your car, but not after AAA changed the battery, something changed or was left disconnected.
Jul 03, 2011 | 2005 Ford Mustang
My clock jumps an hour ahead, how do I fix it?
Make sure that you have the clock set for the correct time zone, and that the DST feature is switched ON. If those settings are correct, try replacing the batteries. Weak batteries frequently cause an atomic clock to "jump" one hour in either direction.
I hope this helps.
Bill B
Aug 04, 2010 | Honeywell RC182WR Atomic Alarm Clock - Red
Buick Rendevouz 2002 Security Sign is up Car has Start problems
have the alternator check out. A good alternator should give produce voltage 13.8v or 14.5v ,but not greater than 15 volts
Feb 23, 2009 | 2002 Buick Rendezvous
Time is behind 4 hours, wont start with new battery
I inserted new batteries, second hand would not move at all. 1 hour later I came back and clock was running with the correct time.
Jan 29, 2009 | La Crosse Radio Controlled Atomic Clock
50 people viewed this question
 Grubhead
Grubhead
