Question about Xerox Phaser 6130 Laser Printer
Fuser error insert fuser 010-317
We were getting fuser error 59. We have tried to get a new fuser assembly but all they send us is the film. Is that what we need for this error? How do you replace it.
Fuser Error means that the device has experienced an internal hardware error.
1.Turn the device off and disconnect the power cord
2.Remove the fuser and then wait at least 20 minutes
3.Rotate the locks on the fuser to the unlocked position,grab the fuser handle and pull the fuser assembly from the device.
4.Using both hands, slow and steadily remove any paper or print media from the device and carefully re-insert the fuser and secure the locks.
CAUTION: The Parts on the internal surface of the fuser are very hot, so to avoid burning yourself,please do not touch those parts.
Reconnect the power cable, turn on your device and wait for it to initialize. If the error persist, Change the fuser assembly or contact HP Customer care. This instructions can also be found n your user manual. i hopes this helps.
Thanks
Sep 13, 2011 | HP LaserJet 2840 All-In-One Printer
It just says fuser error and I don't know what to do?!
Remove the fuser unit from the laser printer, check the two spring contacts are clean and insert it back into the printer. The fuser unit will be very hot if it is working.
If the printer still gives this error message then the fuser unit may be faulty and needs replacing.
Mar 23, 2011 | Office Equipment & Supplies
Low Heat error...Cycle Power Samsung ML-2855ND printer
There is a problem with the fuser unit. This unit fuses the toner powder to the paper and if it is not hot enough the toner powder won't bond onto the paper.
Try removing the fuser unit, check the two fuser power spring contacts, and insert it back in the printer. If the error still occurs then you may need a new fuser unit.
You may need to get the printer checked out by a technician.
Mar 19, 2011 | Samsung CLP-600N Laser Printer
Engine fuser error
The fuser unit may not be seated or inserted properly.
Try removing the fuser unit and insert it back into the printer. Make sure the two spring contacts in the fuser unit are seated firmly.
Mar 12, 2011 | HP LASERJET P1005 Printer
Fuser error 50.1
turn off printer and unplug it.
remove the fuser
wait 20 minutes
reinstall fuser
insert power cord, power on.
If error comes back...you've got a bad fuser or power supply
Jan 27, 2010 | HP LaserJet 2840 Printer
Hp 4m shows service error 50
The service 50 error indicates a bad fuser assembly. You can get one on Ebay for less than $50. To replace the fuser just open the door on the back of the printer, inside you will see the fuser, unscrew the 2 screws and pull the old one out. Insert the new fuser and screw it down, power on the printer and you should be good to go.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 13, 2009 | HP : HP4 Laserjet Printer
Hp laserjet 2840 all in one gives FUSER ERROR
For any fuser error, the first thing that should be done is replacing the fuser. If the error still shows up after wards, it could be the LVPS (Low voltage power supply) or a board.
May 26, 2008 | HP LaserJet 2840 All-In-One Printer
Xerox Phaser 6130 Laser Printer Logo
37 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
