Question about Boss Music
Boss GT-10 has essential buttons that don't work. Enter/category, exit, display mode and right directional pad button all not working. Please help!
No other problems with unit.
5 Suggested Answers
  • 4 Answers
SOURCE: boss micro br
are you unpluging you guitar or whatever.My fiend has one .Ill ask him tommorrow.Iv got a boss 1600 and love it.It been great.I have to hold my button for about 2 seconds before shutdown.Thats to collect its memory.Might try that.I love those little micros though.they sound killer just with built-in mic.Im thinking about getting one myself so i can record lyrics and melodies any time work or whatever.Hope it straightns up.I check back with you tommorrow.Praisehim316
Posted on Sep 27, 2008
  • 5603 Answers
SOURCE: br8...the enter button has become harder and
The button is obviously bad... The next thing is to determine what type button is used, It may be a small module or it may be a conductive rubber one. The latter, you take apart and clean with 99% isoprophyl alcohol and QTips. The module type you unsolder and replace the little module.
Posted on May 28, 2010
  • 5603 Answers
SOURCE: will the Behringer fcv100
Put it between the GT10 and your amp and it should work fine.
Posted on Jun 19, 2011
SOURCE: buttons are not working
Long Back I had the same problem I just reloaded the OS and every problem went off try this
Posted on Jun 27, 2012
My Boss ME-70 han only two dots when i power on ,pedals dont lit when i press it down, is there a solution with this?
PDF]BOSS ME-70 Training Guide - Roland
cdn.roland.com/assets/media/pdf/ME-70_Training_Guide.pdf
AC adaptor. • $418.50 List, $299 MAP ... Connect the ME-70 to power using a BOSSPSA-120S AC Adaptor. 4. Plug a guitar into the ... For illustration only ). 4. Press the ...1. Turn the MODULATION TYPE knob to select a Modulation effect. Do not ... 2. Pressboth pedals down again or press EXIT to return to Manual Mode.Missing: han ‎dots
ME-25 Guitar Multiple Effects Review ' Boss ' Guitar Effects ...
https://www.ultimate-guitar.com/.../boss/me-25_...
Ultimate Guitar Archive
Rating: 8.6/10 - ‎135 votes
Sep 16, 2015 - Overall the effects are very very full sounding and don't sound too digital by any means. ... With 2 selector pedals, up and down, its a pain in the ? ... Editing the patch is as simple as press 2 buttons at the same time and turning ... If this was stolen I would probably get the ME-70 just because it pretty much ...
Tom Scholz's Guitar Sound - Van Halen Links.com
Jan 06, 2016 | Roland Boss ME-70 Guitar Multiple Effects...
Patch not saving,write button is not working from the day i bought.i bought is 2nd hand.plez help
If you buy a second hand, it may have been damaged in mini switch (tact switch) under the WRITE button. You need to replace the tact switch. Easy and inexpensive, you can do yourself, only with a little knowledge of soldering
Tact Switch:patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-1.jpeg
You may also try the FACTORY RESET.
Restoring the GT-10 to the settings made at the factory is referred to as a "Factory Reset."
Not only can you return all of the settings to the values in effect when the GT-10 was shipped from the factory, you can also specify the range of settings to be reset.
If you do this"Factory Reset", all the setting on user memory (that you create) will be erased, so backup your setting before doing this steps.
patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-3.jpgpatch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-6.jpg
For more detail on "Factory Reset", read the GT10 user manual:
roland.com/support/article/?q=manuals&p=GT-10&id=1810803
Sep 16, 2015 | Roland Boss Gt-10 Guitar Effects Processor...
Enter buttion not working
Hello, that seems to be a bad contact on the enter button, the solution is to take a part the key and clean it, otherwise you need to replace the under key switch.
Thanks
Nov 22, 2013 | Roland Boss BR 900cd Digital Recorder BR...
Boss br900cd factory defaults re install
Here is the newest updates for it, http://www.bossus.com/gear/productdetails.php?ProductId=718
1. Press [UTILITY].
2. Press CURSOR [ ] [ ] to move the cursor to "INI,"
and press [ENTER].
3. Press PARAMETER CURSOR [ ] [ ] to move the
cursor to "ALL," and press [ENTER].
The confirmation message "Are you sure?" appears in
the display.
4. To continue the initialization, press [ENTER] (YES).
To cancel, press [EXIT] (NO) (or [UTILITY]).
When [ENTER] is pressed, initialization begins.
After the initialization has been completed, you are
returned to the Play screen.
You can perform the same initialization with "INIT
ALL," by holding down INPUT SELECT [GUITAR/
BASS/MIC2], [MIC], and [LINE] while turning the
POWER switch ON, then pressing [ENTER].
Mar 03, 2013 | Roland Boss BR900CD Digital Recording...
Fix a Boss GT-10 broken input jack
what is your question?
if not working, you have to open the device and find out where it is not connecting (broken solder joint? bent or worn out contacts? wire off?) and repair. or if beyond repair, order a new part.
Feb 22, 2013 | Roland Boss Gt-10 Guitar Effects Processor...
When I turn on my BOSS RC-20XL Loop Station the reverse, tap tempo, write, exit and one shot phase start to blink rapidly and I cannot get them back to normal. Therefore, I am unable to use my loop...
Hi. I had the same problem and fixed it by clearing all the phrases. An explanation of how to do this is below (written by someone else, not me) But, expect your guide beat to now sound like a fuzz instead of a drum. This really sucks and there is apparantly no fix for the guide sound except to send it back to Boss. Good luck.
1. Start by selecting Phrase 1.
(if the 'REVERSE' or 'AUTO START' are lit press them off.)
2. Select 'INST & MIC' by pressing 'MODE'
3. Hold down 'EXIT' and 'AUTO START' together - at the same time, this should light up the green LED for 'LOOP PHASE'
4. Hold down 'WRITE' and 'EXIT' together
then hold 'WRITE' on its own
then 'WRITE' and 'EXIT' together again...as if you were clearing a phrase.
they should light up in red and flash, if not try a combo of section 4.
5. Repeat on all Phrases 1 - 11.
Mar 24, 2011 | Roland BOSS RC-20XL Loop Station Phrase...
Br8...the enter button has become harder and harder to make activate...now nothing. Everything in the unit works fine...except the enter button...which means that I cant record anything at all.
May 28, 2010 | Boss Micro BR Digital Recorder
What are the exact steps to bounce tracks on the Boss Micro BR
It’s necessary to bounce all of your tracks to a stereo pair of tracks before you can export your song to a computer as a WAV or MP3 file for burning onto a CD.
1. In normal mode, push EXIT and UTILITY until you see BOUNCE on the display.
Note: The upper right corner of the display shows the track you’re bouncing to. By default, “12V2”—Tracks 1 and 2, Virtual Track 2—is selected.
2. Press STOP and REWIND together to go back to the beginning of the song.
3. Press RECORD, and then press PLAY.
4.When the song’s finished playing, press STOP.
i read some stuff online and this should help.
Apr 15, 2010 | Boss Micro BR Digital Recorder
Boss micro br
Sep 23, 2008 | Boss Micro BR Digital Recorder
Music Logo
71 people viewed this question
Top Boss Music Experts
Matthew Spark
Matthew Spark
shaun taylor
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Boss Music Expert? Answer questions, earn points and help others
