Question about Onkyo TX-DS838 Receiver
Only 1 surround - Onkyo TX-DS838 Receiver
I have rca DVD surround can I hook up so reg TV and DVD is surround sound both
you have to start with surround sound to get surround sound so no,but if you want sound out of the speakers on the surround sound from your tv,you can do that.
May 10, 2015 | RCA Televison & Video
How do I switch my surround from off to on Harmon avr347
Surround modes are selected using either the front panel controls or the remote.To select a new surround mode from the front panel,first press the Surround Mode Group Selector Button5until the desired major surround mode group such as Dolby,DTS or Logic 7 is selected.Next,press the Surround Mode Selector Button9to choose the specific individual surround mode.
Aug 19, 2014 | Audio Players & Recorders
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
Jun 22, 2011 | Technics Audio Players & Recorders
How i can unlock htc 7 surround from at&t?
Hey,
Call your service provider to ask your HTC 7 Surround Network Unlock Code. when you change your current network provider you must need to Unlock your HTC 7 Surround first. after unlocking you can use your HTC 7 Surround to any network.but network provider take time to give your imei unlock code.
second option is, you can buy your HTC 7 Surround Imei Unlock Code from third party . this is safe way to Unlock your HTC 7 Surround. they will charge little amount but they give your HTC 7 Surround Imei unlock code immediately. i hope this information is help you.
May 18, 2011 | HTC 7 Surround Cell Phone
No surround sound coming from tv. surround sound
It all depends on the TV transmission. If it is stereo, you will get the surround sound. If it is not then you have to listen to ordinary sound.
Dec 20, 2009 | Audiovox 150W DVD Home Theater System -...
I have a JVC DVD player that doesnt come with surround sound but i have surround sound speakers is there something I can buy so that I am able to use the speakers
If you have surround speakers with a surround system, then connect the Player to the surround system using for example RCA cables (White and Red).
If you have speakers only, connecting many speakers to a non-surround system won't give you surround.
In surround systems the sound is controlled, elaborated and distributed through the speakers by a circuit.
If you wnt surround sound the alternatives are :
  1. Connecting a surround system (eg.Home theater, receiver) to the player (amp+speakers)
  2. Upgrading the DVD to one with surround.
Let me know if you need more help.
bye.
G.
Jul 17, 2009 | JVC KD-DV7300 Car DVD Player
Have surround sound only when play dvd..
if you have a sat/cable box it may have audio outputs that you can connect to the input of the surround unit or if your tv has an audio uotput it can be connected to the surround unit. The audio outs of the tv may or may not adjust with the tv volume. This will not produce a true surround signal because th tv does not output a true surround signal. But yo can adjust the surround unit to get a nice sound.
Jun 26, 2009 | Philips SoundBar DVD Home Theater with...
Surround sound doesn't work, display reads 2CH IN
Make sure surround speakers enabled in menu, select surround mode on receiver from a media source that is recorded in surround sound or the receiver can produce surround from.
Jun 14, 2009 | Pioneer VSX-818V-K Receiver
Unable to get surround in dvd mode but can hear thru tv speakers?
Is your DVD player hooked up to a surround sound receiver, or directly to your television?
Mar 18, 2009 | Mitsubishi M-VR600 Receiver
Canoot get surround sound from back speakers
MAKE SURE YOU HAVE THE SPEAKERS WIRED INTO THE SURROUND NOT THE SURROUND BACK. IFF YOU HAVE SPEAKERS WIRED TO SURROUND MAKE SURE THE VOLUME FOR YOUR REARS IS TURNED UP.ALSO CHECK THAT YOU HAVE AMP SET FOR SURROUND SOUND,IE DOLBY DIGITAL OR PRO LOGIC TWO.
HOPE THIS HELPS.
Jun 01, 2008 | Audio Players & Recorders
Onkyo TX-DS838 Receiver Logo
12 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
