Question about Epson EPSC11CB35201 - Stylus Photo R2000 Wireless 13 Large-Format Inkjet Printer
Epson stylus r2000 paper and ink light flashing power light off
SOURCE: Epson stylus photo R1800 printer
http://www.fixyourownprinter.com/forums/printer/35608
this website will answer all your problems
Posted on May 27, 2008
SOURCE: repairing
I have a epson stylus c65 printer. My printer is keep flashing the two red light. The out of paper and the out of ink. what do I have to do to stop the problem. The two red light is keep on flashing alternately
Posted on Sep 18, 2008
Dipu007
  • 2110 Answers
SOURCE: Epson Stylus D88 Plus paper jam
1. Unplug the power and USB cables from the printer. I pried open my C42UX printer, careful not to break anything. I use a flat blade screwdriver to pry it apart; there are two-three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
2. Next I removed the two (2) waste ink pads. They are located at the back on the left hand side. I used the flat blade screwdriver to lift up the ink pads (they were soaked). Please use rubber gloves as it gets very messy.
3. Next I took the pads to the kitchen skin and washed them with just plain hot water until they were white again. I just let the hot water run on them (the pads are about three inches long).
4. Once washed I dried them using a hair drier. (you could place it the sun for a few hours or on top of your heater or maybe in a heated oven; (make sure you do not set it on fire with too much heat).
5. Once dried I placed the pads back in the ink waste bin at the back of the printer.
6. I closed the printer cover and put back all the pieces and plugged in the USB & power cable and turned it on. (Yes the lights are still flashing).
7. Go to this link and download this software: http://inkjetprinterhelp.us/epsonSSC.html
8. Install the software and run it.
9. Select your printer and model number ( It only says C42 there is no UX, choose it anyway).It will ask if you replaced with new pads; say “YES”. Then close the window.
10. Now right click on the SSC service utility, it looks like a printer icon near your clock in the task bar.
11. Then click on reset counters. You can do all other stuff with this utility too.
12. Turn off the printer power and then turn it on again. If necessary un-plug the power cord from the back of the printer, wait 20 seconds. Plug it back in.
13. THERE YOU GO! IT WORKS AGAIN.
14. By the way I use generic ink and I fill my own cartridges. I use ink from www.atlanticinkjet.com. Great stuff.
try this and let me know it worked or not ...
Posted on Dec 12, 2008
SOURCE: epson stylus photo 950 printer flashing lights
I had the same Problem and checked the solution:
This is a Printer Maintenance request.
Ink Overflow -
you sould change the waste ink pads under the printer mechanic.
Solution:
Posted on Feb 16, 2009
aicaxz
  • 511 Answers
SOURCE: alternate flashing red lights on epson stylus photo 900
Flashing alternately? Need reset waste ink. SSc ver 4.3 support this model. Find at indoreset.blogspot.com.
Posted on Jun 26, 2009
Tip
Manual Counter Reset Method
To manually reset the Ink Jet Counter that compels you to clean your waste pads. For the tip on how to clean your ink waste pads go here.
Please Note: In some cases, your printer may be leaking ink so much and so often that not only does your ink pads need cleaning, but you may need to replace the ink reservoir on your printer or you will have a leaking mess on your hands. This is a decision and judgment only you can make. If your printer is leaking quite of lot of ink, you may have to take it to an authorized Epson Repair Shop or Person. Find an authorized location by starting at Epson.com
The solution below is valid for most of the following printer models listed below this solution, some listed may not work, some not listed may also work it varies as this method is listed below is illegal for an authorized Epson Tech to release.
Thanks to the many user boards on the Internet for this solution that I know has worked for people I've helped here on FixYa.
Don't be discouraged if it doesn't work the first time. The key is in pressing the buttons exactly at the same time. So if this doesn't work the first time, try again and try again. Most people state they get it eventually.
[thanks to fixyourownprinter.com for the crux of this particular solution]
"Printer Onboard Control Panel Key Sequence"
"Press and hold the paper feed, paper switch and the power switch.
Once the power light and paper light flashes twice and the other lights are flashing release the paper feed and paper switch "and then press the paper feed switch".
The power, paper and ink lights will flash twice. At this point the protection counter has been reset."
Don't give up, if it does not reset the first time. The timing is tricky for some people.
Supported Epson Models that I am aware of, others not listed may work and some listed also may not work, it varies but don't be discouraged to try and try again.
You can also try the software download solution listed in this tip I posted.
Epson Stylus Сolor 400
Epson Stylus Сolor 440
Epson Stylus Color 480 LPT
Epson Stylus Color 480SXU / 580
Epson Stylus Сolor 600
Epson Stylus Сolor 640
Epson Stylus Сolor 660
Epson Stylus Сolor 670
Epson Stylus Color 680 / 777
Epson Stylus Сolor 740
Epson Stylus Сolor 760
Epson Stylus Сolor 800 / 850
Epson Stylus Сolor 860
Epson Stylus Color 880
Epson Stylus Color 900 / EM-900C
Epson Stylus Color 980
Epson Stylus Сolor 1160
Epson Stylus Color 1520
Epson Stylus Color 3000
Epson Stylus C20 / C40 / CL-750
Epson Stylus C41 / C42 / C43 / C44 / C45 / C46 / C47 / C48 **
Epson Stylus C50
Epson Stylus C60
Epson Stylus C61 / C62 **
Epson Stylus C63 / C64 **
Epson Stylus C65 / C66 and PE **
Epson Stylus C67 / C68 / D68 and PE **
Epson Stylus C70 **
Epson Stylus C80 **
Epson Stylus C82 **
Epson Stylus C83 / C84 **
Epson Stylus C85 / C86 and PE **
Epson Stylus C87 / C88 / D88 and PE **
Epson Stylus Photo RX420 / RX425 / RX430 **
Epson Stylus Photo RX500 / RX510**
Epson Stylus Photo RX520 **
Epson Stylus Photo RX600 / RX610 **
Epson Stylus Photo RX620 **
Epson Stylus Photo RX700 **
Epson Stylus CX3100 / CX3200 **
Epson Stylus CX3500 / CX3600 / CX3650 **
Epson Stylus CX3700 **
Epson Stylus CX3800 / CX3810 / DX3800 **
Epson Stylus CX4500 **
Epson Stylus CX4600 **
Epson Stylus CX4100 / CX4200 **
Epson Stylus CX4700 / CX4800 **
Epson Stylus DX4200 / DX4800 **
Epson Stylus CX5100 / CX5200 **
Epson Stylus CX5300 / CX5400 **
Epson Stylus CX6400 / CX6600 **
Epson Stylus CX6300 / CX6500 **
Epson Stylus CX7800 **
Epson PictureMate
Epson Stylus Photo
Epson Stylus Photo EX
Epson Stylus Photo 700 / IP-100
Epson Stylus Photo 750 / PM-770C
Epson Stylus Photo 780 / 790 / PM-780C
Epson Stylus Photo 810 / 820
Epson Stylus Photo 820 **
Epson Stylus Photo 825 / 915
Epson Stylus Photo 830 / 830U **
Epson Stylus Photo 870 / PM-875DC
Epson Stylus Photo R200 / R210 **
Epson Stylus Photo R220 / R230 **
Epson Stylus Photo R300 / R310 **
Epson Stylus Photo R320 **
Epson Stylus Photo R800 / PX-G900 **
Epson Stylus Photo R1800 **
Epson Stylus Photo R2400 **
Epson Stylus Photo 890
Epson Stylus Photo PM-890C
Epson Stylus Photo PM-A700 **
Epson Stylus Photo PM-G720 **
Epson Stylus Photo PM-970C **
Epson Stylus Photo 895/ 785EPX
Epson Stylus Photo 900 **
Epson Stylus Photo 925 / 935 **
Epson Stylus Photo 950 / 960 / PM-950C **
Epson Stylus Photo 1200 / PM-3000C
Epson Stylus Photo 1270 / PM-3300C
Epson Stylus Photo 1280 / PM-3500C
Epson Stylus Photo 1290
Epson Stylus Photo 2000P
Epson Stylus Photo 2100 **
Epson Stylus Photo 2200 / PM-4000EPX **
Epson Stylus Pro 5000 / PM-5000C
on Sep 17, 2008 | Epson RX620 All-In-One InkJet Photo...
Flashing paper and power buttons
This error means jammed paper or a foreign object is blocking print head movement. Turn off the printer, press the adjust lever down to the lowest position, and pull out the jammed paper. Open the cover and remove any jammed or torn paper, or foreign objects. Then do one of the following:
Sheet Feeder: Return the adjust lever to the position. Turn on the printer, reload paper, and press the paper button.
Manual Feed Slot: See page 15 of your manual for loading instructions.
Roll Paper: Cut off the printed portion with scissors, then remove and reload the roll paper
Mar 08, 2014 | Unknown Epson Stylus Photo R2000 Ink Jet...
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
My epson stylus 740 has lights flashing
You can try and turn if off at the mains overnight or all day.
See what it does when it turns back on
Sep 17, 2009 | Epson Stylus Color 740 InkJet Printer
Alternate flashing red lights on epson stylus photo 900
Jun 26, 2009 | Epson Stylus Photo 900 InkJet Printer
Alternate flashing lights on epson stylus photo 900
Reset waste ink using SSC ver 4.3. Find at indoreset.blogspot.com.
Jun 26, 2009 | Epson RX620 All-In-One InkJet Photo...
Epson won't print and all lights flash
"Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons", then hold down the ink button for approx. half a minute until the printer lights flash again then release it. That resets the printer.”
Mar 15, 2008 | Epson Stylus 880 InkJet Color Printer
Repairing
Jan 19, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson stylus 880 printer
Oct 08, 2007 | Epson Stylus 880 InkJet Color Printer
Epson EPSC11CB35201 - Stylus Photo R2000 Wireless 13 Large-Format Inkjet Printer Logo
109 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
