Question about Toshiba 46HM95 46" HDTV
Grinding noise tv is on or off After turn off tv still light is on, please repond asap thank you
Re: Grinding noise tv is on or off After turn off tv...
It is possible that the Fan make the noise. However, if you whant to find out, just remove some screws of the lower portion of your tv (bottom right) and then you can see the fan an point out if this is your problem.
I had a noise but is was coming from the lamp.
Posted on Dec 16, 2007
  • 375 Answers
Re: Grinding noise tv is on or off After turn off tv still light is on, please repond asap thank you - Toshiba 46HM95...
Psooible cooling fan noise
Posted on Oct 24, 2007
0 characters
3 Points
Its a WD-52631 Rear projection TV. I have sound but no picture. The lamp is still good the problem is somewhere in projecting the picture onto the screen. I have done all the resets i can do and sometimes...
Hi Mark,
First of all thank you for posting your question here at Fixya.
You've mentioned that you can hear a slight grinding noise. This noise came from either a faulty color wheel or fans. To isolate where the fault came from, first I would advice you to access the "error code operational check". This is a built-in software that log and give an equivalent error code by means of blinking LED to determine the exact caused of the symptoms.
How to access the "Error Code Operational Check".
1. Turn on the TV and wait until it automatically shutsdown.
2. Pressing the front panel "Input" and "Menu" buttons at the same time, and holding for 5 seconds, activates the Error Code Mode. The Timer LED flashses denoting a two digit Error Code.Example, if the error code is "42" the led will flash 4 times pause and flash 2 times and it will cycle for a total of 5 times.
Please let me know what is the error code.
If you can't access the error code mode because the TV didn't gone to shutdown. I would advice you to open the rear panel of the TV to pinpoint where the grinding noise came from.
1. Remove 8 screws (A) from the external input frame.
2. Remove 10 screws (B) form the rear cover.
3. Pull the rear cover from the TV.
Tape the lamp cover switch to closed position like on the picture above or else the unit will not turn on.
Your TV has a 3 fans :
1. DMD fan
2. Lamp fan
3. chassis fan
If the grinding noise came from the fan(s) you have to replaced it. All fans have the same part no. 299P312010
However if the noise came from the optical engine assembly, you have to replaced it part no.938P059050
Dec 19, 2011 | Mitsubishi WD-52525 52" Rear Projection...
My tv made a loud pop and the screen flickered like an old projector then nothing and the lamp light is red. Bought a new lamp and same probelm. Red light on the lamp and no picture on the tv. Makes a...
You have a damaged sustain board or color engine. All 3 boards should be replaced and retuned. This is not a DIY, although many do try it they end up paying more than having it fixed right the first time. Take the tip, call in a professional and save money.
parts $400 + 2 hrs labour But swapping boards does not fix it and in fact can blow them again.
Please rate my help++++Thanks for using FIXYA
Jun 10, 2010 | Mitsubishi WD-62525 62" Rear Projection...
RCA HD50LPW164 turned on TV made a pop
the loud pop you heard was probably a capacitor blowing its top. The grinding noise is likely high voltage arching that was occuring due to rising voltage since capacitor isn't there to smooth it out.
Nov 02, 2009 | RCA HD50LPW164 50" Rear Projection HDTV
When turning on the TV, I hear a banging/grinding sound.
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;
Please keep us posted.
Jun 14, 2009 | Samsung HL-S5087W DLP TV
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
Mar 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Grinding Noise
sounds like you have a problem with the cooling fan
Dec 31, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
TV grinding noise
A grinding noise in that model usaully means the light engine is defective or it could be the color wheel. But light engine is most suspect as there have been some issues with the light engine assemblies
May 11, 2008 | Projection Televisions
Grinding Noise
sounds like the light engine there are alot of problems with the light engines and quite a few have had a grinding noise. The only other possibility would be the color wheel. But I would lean heavier toward the light engine being the fault.
Apr 09, 2008 | Projection Televisions
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Toshiba 46HM95 46" HDTV Logo
152 people viewed this question
Top Toshiba Projection Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Toshiba Projection Television Expert? Answer questions, earn points and help others
