Question about Philips Televison & Video
Tv go on and off several time until warmer up
When go off i have to play with remote control turn on until the picture be steady or tv be warmer up
  • 36 Answers
I am assuming it is a VCR combo not a DVD combo..if so, It is likely there is a timing fault with the VCR, the unit has to be dismantled and the VCR serviced, new belts especially the timing belt...Phil
Posted on May 19, 2009
Need remote code for an RCA television
I have had several remotes; 1 was RCA. Resetting the remote was the same on all - 1. turn TV on, 2. press and hold code search button until light goes on (some flash, others stay on), then release 3. press TV button, release once light goes on 4. press on button every 10 seconds or until TV turns off - up to 100 times pressing button!! 4. press enter . Now the test... turn TV on - good luck
Jan 02, 2013 | Televison & Video
I have a jumbo remote, lost my manual. I would like to program it to operate a sanyo tv. I need instructions please.
First, make sure the device you want to connect with your remote is turned on, whether that's the television, DVD player, VCR player, etc. Now aim the Innovage remote at the device. Press the button on the remote control that corresponds to the device (TV, DVD, etc.). Now, press and hold the SET button on the remote control until the LED light on the remote control holds a steady red.
Enter the 4-digit code for your device by pressing the number keys on the remote control (see list below). When you press the fourth digit, the LED light should turn off. This means the remote and the device are "speaking" to each other. Press the OK button to store the code.
If the LED light blinks three times and then remains a solid red, the Innovage remote doesn't recognize the code for your device. Verify the correct code, then go through the programming steps again.
Test the function by using your remote to cycle through all programmed devices (TV, VCR, etc.).
If your device code isn't listed, try the Code Search function:
Turn on the device you wish to match with your remote. Aim the remote at the device and press and hold the Code Search button in the upper left of your remote for at least 3 seconds until the LED light on the remote turns a solid red. Press the button on the remote for the item you want to program (TV, DVD, etc.). The LED light should blink once and then remain a solid red.
Press the On/Off button slowly until the device you want to program turns off. The LED light will blink once each time you depress the On/Off button. When the device you want to program turns off, press the ENTER button. The LED button will turn off and the code for that device will be stored in your remote.
The codes to various devices are listed at:
www.remotecentral.com
Please note that there are often several codes for one particular device. It may take several programming attempts until you find the code that works with your device.
May 20, 2011 | Innovage Jumbo Remote Control
I have a remote that i have had for a while and it stopped working. I changed the batteries but it still doesn't work. I have the codes for it but i missed placed the instructions on how to set the code....
turn on manually your set (tv), push the code button on your remote control until led light, release the button, the led still ligth. push the tv button one pulse, push the power button several times until tv turn off. when this happen push enter button... try turn on the tv with remote control.
Mar 20, 2010 | RCA Universal Remote Control
Hello
1. Turn on the device you want to control (vcr, satellite receiver, etc.)
2. Press and hold the button you want to program. While holding the device button, press and hold ON-OFF until the LED on the remote control turns on, then release both buttons.
Note that the AUX button can only be programmed using direct code entry.
3. Point the remote control at the device and press and release PLAY, then wait five seconds or until the LED stops flashing.
At this point the remote control is searching for the correct code to program. If, after five seconds, the device you want to control does not turn off, press and release PLAY again to tell the remote to search the next set of codes.
Continue pressing and releasing PLAY until the device turns off or you have searched through all of the codes. There are 20 total sets of codes. If the device does not turn off after pressing PLAY 20 times, then the remote cannot control that particular device.
If the device you want to control does turn off:
1. Press and release REVERSE, then wait two seconds. Repeat this step until the device turns back on.
2. To finish, press and hold STOP until the LED on the remote control turns off.
Oct 17, 2009 | Panasonic PV-C2023 20 in. TV/VCR Combo
The picture will go black and the sound will go out. At the same time, the green power inicator will flash. Then the picture and sound will come back on for several seconds and then it will go out again....
My TV had the same problem. I called Sony yesterday and they told me to reset the TV. I did so yesterday, and it seemed to work. Here is the transcript with instructions:
Please turn ON the TV. While holding down the RESET button on the Remote control, press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button.The TV will go thru the initial setup, and should work normal.
Aug 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
I need instructions for a jumbo universal remote
im going to tell you automatic searching to operate your tv.... turn the tv on..
push the tv button and the on off switch at same time and watch if the led is steady ,leave the buttons., push play button and wait 5 seconds til the led finishes flashing you have to do this about 20 times to be complete secure your remote control doesnt control your tv....but if the control found the code the tv turn it off push reverse button and leave it and wait two seconds to turn the tv on and that set push stop. ........test all functions on your remote control to the tv.....saludos.
Nov 15, 2008 | Universal Remote Control Remote Control
21" Panasonic TV W?DVR
Hi : if you're having problem programing the philips remote, you can you used the search option to find the right code for your Panasonic TV. In order to search by auto without a user guide please follow the step below.
1.Turn the panasonic tv on.
2. On the univercial remote control there a button mark code search or search.
Pressand hold down the code search button until the LED light come on steady.
3. Press the TV button onthe univercial remote one time.
4.Press the power button on the univercial remote severail time until the tv turn off
When tv turn off press the OK or ENTER button on the univercial remote control to save the setting.
Good luck.
Dec 13, 2007 | Televison & Video
Philips universal codes
If you dont have the codes for a philips universal remote you have to press code search and TV at the same time till the led light stays on. Then press the power button a few times untill the power turns your TV off, then press the OK button. After that the code should be in the remote.
Dec 07, 2007 | Philips Magnavox Learning Universal Remote
Remote code
Magnavox 0054, 0706, 0030, 1454, 1254
How do I program my remote control?
For remotes that have blue arrow and Select buttons and 4 separate mode buttons (SAT TV VCR AUX):
*If you start this procedure and at any time do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again.
  • Press and hold the desired mode button (about three seconds) until all mode keys light up, then release.
  • Use the number pad buttons to enter the three-digit number corresponding to the equipment (click here to view remote codes). The light will blink off after each digit is entered and then return to a steady light.
  • Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
  • To verify the code works, try several functions for that equipment.
For remotes that have one Mode button at the top:
*If you start this procedure and at any time do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over.
  • With the desired equipment on, press and release the Mode button until the light flashes behind the correct mode.
  • Using the tip of a pen or the eraser on a pencil, press the address button.
  • Enter the code (see links to find your code below) on the remote's numbered keypad for the equipment.
  • Press the Address button. If the code entered is valid for the remote, the mode light flashes three times.
  • To verify the code works, try several functions for that equipment. Some codes may provide partial functions or respond differently than the button's titled function. Try the other codes listed for that device until you find one that offers more complete functionality.
Click here for codes for remotes with blue buttons.
Click here for codes for remotes with gray buttons.
Click here for codes for platinum (DVR) remotes.
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Nov 22, 2007 | One For All URC-3021 Remote Control
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
