Question about LG Washing Machines
LG toploader WTR801 stops mid cycle. No lights, no error codes, just like you turned off the power.ping.
I've tried it in a different power point, taken it all apart; can't see any broken/damaged wires. Unplugged all connectors - look good. Circuit board looks good. Intermittent fault in a 12 YO washer.
    Top Expert:
  • LG Master
  • 35,654 Answers
If the washer is 12 years old, it may be time for a replacement.
Posted on Dec 29, 2013
natengel
  • 19 Answers
SOURCE: Washer stopped in mid-cycle and is full of water. I can restart the cycle, but
if it stops at #6 u need to change timer and motor
Posted on Oct 31, 2007
MNTECH
  • 1543 Answers
SOURCE: LG Tromm washer LE code
I shouldn't even respond to this if you have had 5 or 6 tech look at it because I don't want a Thanks for Trying, but it sounds like you are at the end of your rope. The pump motor should not have anything to do with the problem. If you did not have anything in the tub, including suds, doing the QC test, and you have checked and replaced all you have said, the only thing left is the main PCB part number 6871ER1078T
Posted on Oct 26, 2008
  • 73 Answers
SOURCE: My LG Clothes Washer has
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Posted on Apr 29, 2009
  • 3741 Answers
SOURCE: Washer stops with F11 code; door won't open
F-11 ERROR CODE MEANS :
Serial Communication Error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
TO RESOLVE THE PROBLEM:
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Posted on May 05, 2009
  • 72 Answers
SOURCE: LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Posted on Jun 19, 2009
LG WT5101HW - Machine won't turn on. Just plays the tune softly when pressing power button. Also, machine have not been draining properly lately. Turns off by itself mid-drain with DR error code.
DR is a drain error. Have a look to see if the drain filter is blocked (if fitted) or if there is an obstruction or blockage in the pump or drain hose. If it cant pump out, the machine will stop during the cycle.
Mar 29, 2016 | LG Washing Machines
AE ERROR PROBLEMS
AE error code : base sensor has sensed water.
Dec 07, 2015 | LG WT4801CW 27" Top Load Washer with 3.7...
What does half 6 E error code mean on LG washer
make sure the drain hose is higher than the back of the washer, has to be to function the draining of the unit.
Jan 02, 2015 | LG Washing Machines
Washer stops mid cycle and all lights flash and door is locked. no error code. We have to stop power off the washer turn power on and run through another full cycle
Reset the unit by unplugging for 40 minutes.
otherwise the ECU is at fault.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 10, 2009 | Kenmore 46462 Front Load Washer
My LG Clothes Washer has stopped mid cycle and is displaying an "OE" error code. How do I get the machine to finish the cycle?
Poss causes:
drain hose kinked,
filter blocked,
Hope that Helped
Please Rate Me
George
Apr 29, 2009 | LG WM2688HWM TROMM SteamWasher
Reset whirlpool front loader
Power shd be on. Right side of control panel, "end of cycle", hold this down for 3 seconds.
Mar 21, 2009 | Whirlpool Washing Machines
Washing Machines Logo
71 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
