Re: stays on for a second then automatically shuts off
If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. If you wish to get more details about this, try the sites linked here. It has set-up code list, and set-up procedure to many popular brand universal remote controls. http://electrohelponline.blogspot.com/ http://electro-medical.blogspot.com/
Try removing the batteries in your remote and switch it on manually. If not OK. Try unplugging it for 1 day and connect it again. That usually resets its electronics. If it fails then the power supply electronics needs repair.
For my universal remote control's manual, all of the VIZIO codes are:
11758
13758
12757
Also, remember that you can have the remote scan for codes on its own. On the remote just hold the "TV" control button (should be at the top near the power button) and the power button turns on. Then hold the power button too, and it shuts back off; keep holding until it turns back on and then it will stay on. Then, point the remote at the TV (it should be on) and press the power button every three seconds. It will test a code every two or three seconds. When your TV finally shuts itself off in response, you've got the right code and the remote should work.
What happens before it shutting off itself?
Are you sure that the timer off isn't on?
Normally, the self off may happen because the TV goes into Protection Mode due to a failed circuit board.
Not sure what your question is, but dodge had no factory remote start system on any vehicle in that year. I assume you did not purchase the truck new and the previous owner had the system installed. Let me know if you're still experiencing the problem and I can help you resolve it.
some tvs have a menu where you can controll that there should be a menu button on your remote try doing that and switching the automatic shutoff to off
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER
INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER
INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off,
the code was entered correctly. If the device does not shut off, repeat steps
3-4, using a different code.
Automatic Programming With automatic
programming, the remote control tests all the codes available on the Code List and assigns the correct
code for the selected device. 1.Turn
off the device with which you want to use the remote control. 2. Press and
hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or
AUD) until the POWER INDICATOR illuminates. The remote control is in
programming mode. 3.Press and
release power button. The POWER INDICATOR flashes once and stays on indicating the
unit is in Power Scan mode. 3.Press
CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on. 4.When the device turns on, press OK
to store the code. 5. Press any
other button. If the device responds, the remote control has been programmed.
If the device does not respond, repeat steps 2-5.
3. Press and hold the corresponding button on the remote control (TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Automatic Programming With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. 1.Turn off the device with which you want to use the remote control. 2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode. 3.Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode. 3.Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on. 4.When the device turns on, press OK to store the code. 5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5. Thanx
Automatic Programming With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. 1.Turn off the device with which you want to use the remote control. 2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode. 3.Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode. 3.Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on. 4.When the device turns on, press OK to store the code. 5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5. Codes for orion TV are 096,10,146 Thanx
Power on your TV and press the INPUT button on the side of the TV repeatedly and rapidly until you can change it to a different input, such as AV.
If this does not work. Try this: With the TV off, press and hold the input button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. Let me know if either of these work.
