Question about Android Apps
Asus how to connect
Connect to USB fails
  • Tim Laporte
    Tim Laporte Dec 29, 2013
    Due to multiple issues following the update to Android 4.3, I ended up rooting my phone and flashing the firmare with custom ROM of Kitkat 4.4
  • Tim Laporte
    Now I'm attempting to connect to a new notebook (Asus Vivobook V550C), using USB. I have Kies installed and running on the notebook. Plug phone into USB. Kies detects it and starts trying to connect. Each time it fails. No error message other than Kies saying to check the phone to make sure the debugging is turned on. I've confirmed several times, it is on.
Mouse Cursor
Check in power options and the CMOS settings for anything USB related and disable anything that would cause USB to sleep or power save, make sure legacy USB is on, then check your Windows power options for the same, disable anything to do with USB power saving. If all else fails, go to ASUS website and go to the drivers and downloads section, download the latest BIOS revision for your model and update your BIOS.
Dec 20, 2013 | ASUS ET2300INTI All-in-one PC
Usb not working
You can try to do a system restore back to when it was working. If you still have no luck, I would look in the device manager and check the devices under USB. You can actually uninstall all of them and when the computer restarts, it will reinstall them so if there is a corrupt driver it will reinstall correctly.
If all of that fails, I would say that your USB port has gone bad. I'm always leary of the rest of the board in one component suddenly fails. There is a possibility that a soldered connection has come apart and if you're good with a soldering iron you can re-solder the connection.
Feb 29, 2012 | ASUS K42F A1 Notebook
I installed the Asus mini Bluetooth USB - BT211 and I see the icon Local Area Connection - A network cable is unplugged . When I go to the Bluetooth Suit and click on the configuration task that IE fails...
bluetooth does not connect to the internet, it connects to other bluetooth devices such as bluetooth mobile phones.
the network cable shows unplugged if there is no cable plugged into it and going into your internet router
Apr 09, 2011 | ASUS USB-BT211 Mini Bluetooth Dongle -...
I have an asus k501. everytime i use the keyboard say a certain letter a couple of letters and numbers come up in pairs of threes or fours. My kids did something help
Start by reinstalling the mouse with the software located for free direct download from hp.com If it fails, then check to ensure your USB drivers are up to date, still fails, change the usb/ps2 port to a different one, still fails, then try a different mouse DO THIS PROCESS FOR ASUS MOUSE FIRST THEN KEYBOAD
Jan 28, 2011 | ASUS 90-A4C1K1000 Keyboard
I have a asus Mb Klv dont remember the name how do i connect the front panel usb on the port do you have any diagram
you need to have your model name to get the right technical documentation.
Please check how to find your model name on the asus support page
http://support.asus.com/repair/repair.aspx?root=110&SLanguage=en-us
having the model name go to support menu and look up the technical documents entering your model name in the search box.
Hoping this informations was helpfull
Aug 31, 2009 | ASUS P4S800-MX Motherboard
Usb front panel connection
it depends on weither the case and the motherboard are the same usb connection . make sure that there both usb 2.0 or 1.1 not one or the other as the connections or not compatible .
May 01, 2009 | ASUS P4SGX-MX Motherboard
USB port does not recognize 1Mb flash drive
try connecting the card directly to your computer usb port. unplug other usb devices. if that fails, try the card in a different computer.
May 17, 2008 | ASUS P5P800-VM Motherboard
Android Apps Logo
684 people viewed this question
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
