Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
TV won't turn on
Tv wouldn't turn on right away and gradually got worse. Now it won't turn on at all. acts likes it trying to come on but keeps "clicking" and the red light goes on and off.
  • 39 Answers
This is certainly a power supply problem and definitely sounds like bad filter capacitors. According to the service information the power supply part number is 1-869-027-12. You should be able to find this part used on the internet if you google that model number but if you're savvy with a soldering iron simply replace and capacitors on the board that have a top on them that appear even slightly 'puffed up.' Capacitors are usually a matter of cents to replace.
Posted on May 19, 2009
Net flix won`t come up on my tv
connect the internet to your tv
Apr 01, 2014 | Netflix
Visio VP504 fhdtv10a - When I plug it in, it has an amber logo light and makes a click noise (like a relay). When I press the power button nothing happens.
These are problems gradually developed in TV over the years. You may have to look for any dry solder, change the capacitors that look 'puffy' and try.
Jul 30, 2012 | Televison & Video
I have a 2006 Pontiac GT G6 Coup. When we first bought it back in Nov. 2010, it was fine. After a month or two, the clock would reset almost everytime the car was started, radio stations would NOT get...
sounds like a problem with the ignition barrel.the wiring is loose or the connectors are loose or the barrel is faulty,unless thse are all run from the onboard computer.
May 31, 2011 | 2006 Pontiac G6
I have a red glow in the middle of the screen and the color is dim. It has been gradually getting worse as the year has gone on. Is this a bulb issue or a convergence issue?
This is light engine issue, light engine produce image and project it front screen of TV.
I'm afraid light engine replacement would cost you much, $1000 plus, check with local tech for estimate.
Thanks.
Dec 05, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Have lamp cooling fan noise on Samsung HLP5063W - 50 when I turn on TV and screen is distorted. Noise on TV is gradually getting worse and now does not go away and I essentially have no picture. Do I need...
the problem with your tv is the color wheel
not the fan let me know if you need help to take it apart...
I do repairs for samsung tv and I fixed a lot of them before..
Jul 29, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Acer 32 lcd seems to be frozen
Hi
You will need to visit acer website to see if their is an upgrade for the software some manufacturers do this some dont, it would be a matter of downloading and installing on flash memory card to insert in USB on tv,if not it will have to go into an approved acer service centre
Jun 04, 2009 | Acer AT3220B 32 in. LCD TV
Zenith 27inch B28A11Z keeps powering itself off
Hi Pswglaw,
From the way you describe the problem, it seems you have a high voltage leak. To check this, make the room dark and look into the back of the TV while turning it on. If you see something like lighting jumping around you have this high voltage problem. The TV will eventually destroy itself under this condition. I would suggest not using it until you get it repaired. The repair cost will be much lower if the TV is still working when you take it in. The high voltage leak will destroy more parts and cause the TV to stop working. Then it will blow a fuse.
MyTvGuy
Jan 23, 2008 | Zenith B27A11Z 27" TV
Flickers on cold startup after 5 min then goes away in 2-3 min.
I had same problem. Tech's said the power was noisy. I cleaned up the power but the TV still did exactly as you describe. Problem will progressively get worse with longer bouts of flickering. I was under warrenty and sent the TV back. After 3 months I am still waiting for a repalcement.
Jan 12, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
36" CRT Toshiba has that vertical issue mentioned on here a bit
Your problem is most likely caused by a cold solder joint in the vertical circuit. Normally this is easy to find and correct. The problem will only get worse over time, but not likely for more damage to occur.
Sep 17, 2006 | Toshiba 36A41 36" TV
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
111 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
