Question about Sylvania Televison & Video
Sylvania lc320ss8a.power button wont stay on.co said i need a remote.got 1 today,still comes on for a second then goes off again,tv made in 2008,help!
Never had remote.on off switch worn out per co.said i need a remote,.got 1 today .still stays non for a second then goes off right away,2008 model lc320ss8a.help
zjut
  • 106 Answers
SOURCE: Sylvania 42
Check the fuses on YSUS & ZSUS boards, if found the fuse blown on that board, just try to replace the board.
Posted on Jan 01, 2008
macgroovy2
  • 52 Answers
SOURCE: Cox Cable Remote wont program to my Sylvania LC320ss8 tv.
there are different codes for the devices that you are using. When you want to insert the code for the tv. > Switch tv on and then switch all the other devices off. Insert code. For digi box > switch on and all other devices off. Insert code for digibox. You must then switch between tv and digi box using the buttons on the top of the remote. Toggle between tv/ digi box.
Have a go with the codes below with the tv and the digibox both on, you never know you might get lucky as these are new codes, if not revert back to 1st solution.
Universal Codes (both should work using these, i think!!!!! try 'em)
002,
008,
155,
198,
227,
231
Here are the codes for the 1st solution.
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
Posted on Jun 18, 2009
  • 136 Answers
SOURCE: LG 47LC7DF LCD TV turns off with a pop then turns back on.
Sounds like a overheating issue. Try facing a large fan blowing across the back of the unit and see if this changes anything. If it does, it might help to blow the back out with compressed air as dust might be helping it overheat.
Posted on Aug 08, 2009
  • 4 Answers
SOURCE: Powers up then goes off in about 10 seconds
Transistor Q601 (K3869) is over heating. This is obviously a design flaw in the power supply. You can either extend or modify the heatsink or have some genious wire in a colling fan in the back cover.
I found the problem after running a common house hold fan on it with the back off. TV continued to run. Unplug the set before touching the heatsink after the problem occurs.
Posted on Oct 08, 2009
  • 102 Answers
SOURCE: my sharp tv wont stay on, it flashes green
Hi i have seen this before sharp hdtv's are known for having the internal power supply go faulty
Posted on Feb 01, 2010
Sylvania LD320SSI when turned on goes through a series of different colors and will not stop.
The way it can be brought back to normal is by pressing the "Standby" button on the tv and wait 5 seconds. Then press it again and as the TV was turning on, press the "Menu" and "Source" buttons on the tv simultaneously and when the tv was on it was on the menu. Turn the tv off with the remote turn it back on again with the remote. Should be back to normal. Hope it helps someone, it worked for a friend who had the same problem.
Apr 22, 2016 | Sylvania Televison & Video
My flat screen Sylvania TV is flashing different colors what's wrong
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Jan 20, 2016 | Sylvania Televison & Video
How do you program a universal remote to a model 6420FF Sylvania TV?
Code search. Hold down code search button until on-off light flashes then stays lit. keep pressing the on-off button until the power to your tv goes off, then hit the enter button. your remote should be set to your tv!
Nov 24, 2013 | RCA Universal Remote Control Transmitter...
I have a Sylvania LC320SS8 32 in. LCD Television I need the universal remote code for my DishNetwork universal remote that goes with this TV, Do you know the correct code?
Try these codes:632, 569, 556, 506, 525, 536, 566, 568, 573, 600, 610, 652, 654, 656, 659, 660, 664, 665, 666, 671, 672, 674, 677, 723, 724, 729, 733, 756, 764
If you have no luck still try a Power Scan the steps are listed below:
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network Customer Service
Nov 30, 2010 | Sylvania LC320SS8 32 in. LCD Television
New TV 9 mos old, Won't stay on after power up? Remote or manual turn on, set keeps turning off after 1-2 second green on and brief screen flash.
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
Jun 01, 2009 | Sylvania LC320SS8 32 in. LCD Television
Need remote code for Sylvania 32" LC320SS9 for Dish controller
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
We cannot guarantee our remotes will work all other devices. If this does not correct the issue, unfortunately our remote will not work for that device. We apologize for any inconvenience this may cause.
Let me know how it goes and please rate this solution
Lone99star
Feb 24, 2009 | Sylvania LC320SS9 32 in. LCD TV
Insignia TV code for RCA Universial Remote Control (RCR450)
If its a four digit code remote. I may be able to help.. Try these...0171, 1204, 1326, 1517, 1963, 2002..
Good luck
Nov 11, 2008 | RCA 4-in-1 Universal Remote Control
Dish network remote
i would suggest trying power scan again...
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
if this doesnt work try addressing your old remote to the receiver by pressing record from system info screen
Jul 06, 2008 | DISH Network IR Remote Control
Ge 94948 universal remote instrutios for progaming t.v.
Hiya this is how i got mine to work.Manually turn on the tv.
Press and hold setup on your remote till the light comes on and stays on.
Then press the tv button then release. The light will flash then continue to stay on.
Now press and release the power button waiting 2 seconds before you press it again until your tv switches off.. you may have to press it for awhile.
Once your tv cuts off press the mute button and now your remote is set for your tv.
Feb 19, 2008 | GE RM24948 Remote Control
Televison & Video Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
