Question about Saeco Coffee Makers & Espresso Machines
Intuita flashing cal/ clean light
Machine indicated needed clean. carried out but calc/ clean light now flashes fast. when press clean button, goes to slow flash and water dispensor button fast flashes. Tried pressing water button and only dispenses water till reservour empty.
SOURCE: red water light is flashing
I read through many old posts and found the answer I was looking for. I turned the hot water nozzle on for 45 seconds and the problem went away.
Posted on Apr 11, 2009
SOURCE: how to clear the flashing light indicating unit needs cleaning
I posted earlier with a similar question, I fixed it by doing this. First unplug the unit for at least 30 seconds to clear. Second, and you'll have to be quick, press the Program, Set and On buttons all at the same time. This should set back to default settings. Hope this helps.
Posted on Sep 20, 2009
  • 81 Answers
SOURCE: Both the top alarm light for empty grounds in
When you press the coffee button , and the top and bottom lights are flashing, that means the grinder is either jammed or out of order. If the machine is less than 2 years old, the service center will replaced it under warranty.
Posted on Sep 16, 2010
SOURCE: I have turned the machine on and all lights are
Suggest you try to re-seat the filter in the water container and make sure the water container is seated firmly. I had the same reaction until I did the above.
Posted on Nov 17, 2010
SOURCE: My Keurig Brewer is flashing the add water,
Perhaps more than one problem people are dealing with but here's what I found. The round float in the tank is magnetic so it's either activating some crappy mechanical switch or more likely a hall effect sensor. Remove the tank and dump the water so the float will rise from the bottom when you refill it. Take a good strong magnet and slide it around the side of the unit where the float would be, tapping it as you go. Put the tank back on and fill it. One try and I was back to making coffee.
Posted on Sep 01, 2012
I have an american style hotpoint fridge freezer MSZ902DF which has had a water filter change as blue light on but despite following process the light has now turned to orange. Can anyone advise what we...
Refrigerator - Water Filter Indicator Light Will Not Shut Off After you change the filter the RESET WATER FILTER must be pressed and held until the red light goes off.
Note: If you do not hold the pad in, the light will stay on. Also, if you hold the pad in for a long period of time, the light will go off and then come back on.
If this does not turn the light off, having it checked by a service technician is recommended
Here is a list of refrigerator manufacturers and how to reset the filter change indicator light:
Amana- Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire- Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric- Press and Hold the Reset Button for around 8 Seconds.
HotPoint- Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air- Press and Hold The Water and Lock Buttons until the Water Filter light flashes.
Kitchen Aid- Press and Release the Light Button 5 times Quickly.
Maytag- Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung- Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool- Press and Release the Light Button 5 times Quickly.
Mar 04, 2015 | Hotpoint Refrigerators
Nespresso U - the lights keep flashing but doesn't work
have you done descaling try pressing the two buttons at the same time but keep holding them for 5 second tell me is it flashing fast or slow?
Sep 08, 2014 | Krups Nespresso U Xn250a40 Coffee Machine
Saeco intuita- performed clac/ clean, and now calc/ clean fast flashes. Pressing only goes to slow flash and water dispensor light fast flashes.
Use a paper clip to clean the Needle that penetrates the Kcup. If it still happens call 1-866-901-2739 for direct assistance.
Dec 29, 2013 | Keurig B60 Coffee Maker
Intuita coffe machine not working
Needs a service take it in let them replace the seals,If the seals go faulty this happens
Dec 29, 2013 | Coffee Makers & Espresso Machines
Calc-clean function light keeps flashing
Press the reset button
Nov 12, 2013 | Irons
Delonghi coffeemaker dcf6214t clean light won't stop flashing after descaling how do I reset it to default ettings?
Hi, Cathy,
Most of the above solutions do not address your DCF6214T drip coffee maker. I had this problem, also. The manual is useless on this subject. The support telephone did help somewhat, but, also referred me to the website where I found the same useless manual.
Try this:
1. fill carafe to the 14 cup mark with warm water. (aprox 2L)
2. mix in 2 tablespoons of citric acid (a white powder available at Indian supermarkets) mix to dissolve completely.
3. pour acid into the coffee maker. and mount carafe in the machine and close the door.
4. with the on/off light off, and the clean indicator flashing press the clean button. The machine will fill the carafe over the next 3 hours, giving the acid lots of time to dissolve deposits.
5. After the on/off light goes off discard the dirty acid, rinse and refill the carafe with clean water. Fill the machine with water then mount the empty carafe in the machine.
6. With the on/off light off and the clean indicator still on, again press the clean button. This time the carafe will fill in about 6 minutes, as this is just a rinse to remove the acid.
7. Repeat 5 and 6 two more times. (I did it 3 more times, for a total of 4, but I believe 3 should work, according to the manual and the telephone support line.) (That is one acid clean followed by 3 rinses, all without pressing the on/off button.) (After all this, the darn clean indicator will still be on and the on/off light will be off.)
8. Now, make a pot of coffee and breathe a sigh of relief as you notice the clean indicator finally, turn off.
I hope this helps supliment a total failure of the manual to explain how to perform the clean operation.
Oct 20, 2012 | DeLonghi dc Coffee Makers & Espresso...
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Jul 26, 2010 | Miele W1926A Front Load Washer
Miele W1926 check inlet light flashes at the end of rinse fill. When the fill ends, the light goes off. I cleaned all 4 filters at the intake hoses. The problem still exists. What does it mean?
Hi dear.It sounds like you'll need to change water inlet valve very soon.Because,machine waiting water level to be reach,in specific time frame in chosen program parameters to be get completed.If that does not happen,then it starts giving fault indication.Indication stops after fill,because task been competed & computer disregards the fault.If that won't happen then machine going to get stop completely & indication will carry on.Chage the water inlet valve if you can.I hope that helps. Thanks.
Jul 25, 2010 | Miele W1903A Front Load Washer
Coffee Makers & Espresso Machines Logo
61 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
