Question about Intel 160GB X-25M SATA II 2.5IN-MLC34NM W/CLONING K - SA2MH160G2K5 SATA II Solid State Drive (SSD)
Date code 7j1080 - Intel 160GB X-25M SATA II 2.5IN-MLC34NM W/CLONING K - SA2MH160G2K5 SATA II Solid State Drive (SSD)
What year was MED5600TQ0 Maytag electric dryer produced?
Check the date code on your unit against the chart below to get the mfg date. Maytag Date Codes The breakdown for Maytag Serial Numbers is:
1st Alpha Character (9th position) = Year Manufactured
2nd Alpha Character (10th position) = Month Manufactured
or go here: Maytag Date Codes
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
Nov 05, 2014 | Maytag MED5600TQ Electric Dryer
Vision battery date code
ALL VISION BATTERY MODELS
Date code stamped on top of battery container
X1 X2 X3 X4
Where X1 denotes year of manufacture A = 2001 B = 2002 etc.
X2 denotes month of manufacture A = January B = February etc.
X3 X4 denotes date of month of manufacture
Eg AH27 = battery manufacturing date 27th August, 2001.
Dec 12, 2013 | Exide Chloride Power Station (EXP2000) UPS...
Bulova watch, SN 316342
Boliva Watches dated after 1949 have a 2 digit date code on the outside backcase (usually below the serial number), whilst watches dated pre 1950 usually contain a date code symbol on the inside movement.http://www.mybulova.com/bulova-date-codes
Nov 30, 2013 | Motorcycles
Always in test mode i have a wf860
Here are the instructions to clear the 'test' depending on the date code:-
Date code 39 March 2005
Press start/cancel until ALL LEDS are lit
Press both start/cancel AND on/off together until 'dOFF' is displayed
Date code 39 March 2005 to date code 42 June 2005
Press the cancel button and the machine should return to norma
l
Date code 43 July 2005 onwards
Press both start/cancel AND on/off TOGETHER with top left option button until 'dOFF' is displayed.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Oct 21, 2011 | Hotpoint Ultima WF860 Front Load Washer
Test mode keeps coming up
l
John C
Jul 31, 2011 | Hotpoint Ultima WF865 Front Load Washer
Imei 35454001633758 i need security code
Nokia 3110 Secret Codes
Press the following warranty code
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
6232 (OK) : Displays the Month and Year of Manufacture (0997)
This code is able to check, activate or remove SIM card restriction (SP-lock)
Use the * key to get the p, + and w chars
Jun 28, 2011 | Nokia 1110i Cellular Phone
Switch on it shows "test" and cannot programme
It depends on what date the machine was manufactured. The date should be on the plate which is probably in an awkward position on the back ;-0(
Press the cancel button and the machine should return to normal
John C
Mar 22, 2011 | Hotpoint Aquarius WD640 Front Load...
My hotpoint aquarius wf630 digital display shows TEST
I cannot take credit for these instructions- they are from the UK Whitegoods fault code guide.
Check the date code on the plate.
I hope one of these helps.
John C
Mar 13, 2011 | Washing Machines
How to read date codes
date codes are usually only 4 characters long so this one is the 48th week of 2007 the last 4 maybe the day of the week.
Dec 14, 2009 | Seagate Barracuda 7200.10 ST3160815A -...
Date code or time code
date & time is already stored in EXIF header. If you want them to appear visible, there're a lot of software will do that. Use QImage Pro to print, and i can print date & time on it, or save to files. If you use Linux, you can write simple script to put date & time stamp on JPG files.
Sep 07, 2005 | Olympus C-3000 Zoom Digital Camera
Intel 160GB X-25M SATA II 2.5IN-MLC34NM W/CLONING K - SA2MH160G2K5 SATA II Solid State Drive (SSD) Logo
37 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
