Question about Seth Thomas Pacconi Turntable
My museum thomas series record player runs slightly too slow. How can I fix this??
I have looked online and found that replacing the motor and belt don't help. It is running just slightly too slow. I opened up the bottom of the record player and searched for a "white dial" that people described in blogs, but I think they were referring to a slightly different model than mine. Hoping to find some guidance. Thanks, Levi
  • Levi Messner
    Levi Messner Dec 29, 2013
    Exact Model: TPC-767 O
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
Try changing the needle which runs on the record this is to do with clarity , makes a big difference and you get many types of needles
Posted on Dec 29, 2013
2 Suggested Answers
  • 3 Answers
SOURCE: Thomas Pacconi Model TPC-MSE-800 turntable
Pjam,
Had the same problem & checked around on the net. Several people tried replacing the belt, but it had no effect. Spoke w/ several repair shops around the country and they concur with what I'd read on the net - bad motors. 3 or 4 repair/supply shops told me getting a motor would be impossible. Since I only listen to 33-1/3 LP's, I messed around w/ it a little and found a solution. Take the turntable out of the unit & you will find a small circuit board attached to the bottom. On that board is a small square blue fixture w/ a white circular "dial" in the middle (has grooves to accept a small straight blade or a phillips screw driver). This controls the voltage to the motor, which in turn controls the motor RPM's. If you set the selector switch to 78, you can experiment /w turning that white circular "dial" to slow the motor down. It isn't very hard to get the speed set properly. The down side is that you will only be able to play 33-1/3 LP's, but they are probably the most common anyways. I assume you could do the same to set the speed for a 45, rather than a 33-1/3. Down side is that you will only be able to play 1 size LP on the 78 speed setting, but it's an easy adjustment that can keep an otherwise in-op turntable functioning. Good luck!
Posted on Jan 21, 2011
How do I fix a turntable used for playing records from being slightly slow
Try replacing the drive belt. Look under the platter for a 'rubber band' that would connect the platter to a drive motor. I bet it's loose. My other idea is crazy, however, they do sell an item called a "variac" which has a knob to control the voltage to the player. It's big and bulky and not worth the trouble. I'm a musician so I have to have a player up to speed or slightly detune my guitar. Good luck..
Jan 13, 2015 | Audio Players & Recorders
I had my speed queen about ten years it washes properly when it come to spin it go very slow and with jurking movements what can be wrong please
Open up the front panel by unscrewing the three screws at the bottom of the panel and lifting the panel up and out. Please disconnect the electrical power supply first. Look inside the machine for the van belt between the electric motor and the big pulley underneath the drum. Check the condition of this belt as it might need to be replaced. ( badly worn over all, inner rubber area cracked badly, rough sides ect). TAKE NOTE: Replace with genuine Speed Queen part as a normal vehicle v-belt will not work. Pressing against the belt will be a small pulley attached to a swing arm under tension of a spring. Slight shortening of the spring might help but only as last resort.
Aug 12, 2014 | Speed Queen Washing Machines
Dryer just stopped working
not much to go on here, but if you hear anything that sounds like a motor running, then I would suspect a broken belt. There is a belt that actually runs around the drum that makes it turn. If you don't hear a motor running then you need to check your controls and cable(with a volt meter(just start at the motor and work your way back).If you hear a motor then its probably the belt that gos around the drum and motor( a little tricky to replace but not hard)
Jan 12, 2012 | Amana Dryers
My kenmore HE2 dryer is squeaking. I replaced the belt, pulley, and wheels, what should i try next?
g'day, i found an old dryer recently that someone was throwing out because they said the motor was on its last legs - it wasn't. It was making a bad noise for sure but motor was fine. I looked at the axes of rotation... There's no bearing at the front because you put your clothes through the door. so instead the drum rotates on pads around the inside of the door. Obviously due to gravity and people putting in large loads, the pads at the bottom were more worn than those at the top - which had done no work. For a very simple fix, i turned the dryer upside-down and it worked a treat. I've been looking at your dryer online and i don't think that this is an option for you. It looks like you have a new machine which has weights and suspension struts and the like. You seem very mechanically minded, so maybe look in these areas with some wd40... hope this helps let us know how you get on
Aug 18, 2011 | Kenmore Dryers
The belt has snapped and when i opened the back up the belt is nowhere to be found so i dont know the belt number to be able to get a replacement can you please help?
Think that is the same belt used on all of haier washers. if you take it to a spares place they should be able to match it up or order online from Haier spares direct. If the motor is on the bottom then it is a matter of hooking it first around the spindle of the motor and then putting as much on as possible around the big pulley then turn the pulley slowly holding the belt on at the same time till it stretches over. Its the only way. Hope this helps
Mar 12, 2011 | Washing Machines
My washer tub nor the agitator spin or rotate you can hear a whining n grinding noise
whining and grinding most likely mean belt or coupler is binding or broken away unplug unit and open access panel or [remove water first]lay on side and access motor from bottom if belt driven check belt if frayed or broken replace-if has coupler [looks like a star shaped hard rubber /plastic piece between motor and trans] if broken pieces on floor or shredded replace- part's can be bought online-appliance stores coupler not expensive and both parts easy replacement good luck
Nov 08, 2010 | Washing Machines
Have a bissell easy vac 3130-B and the brush on the bottom stopped turning i never looked before so i don really know if it turned in the first place
Behind the brush will be a metal thing that spins when the vacuum runs. That's what the belt loops over with the other end around the brush. You can sometimes find the belts a places like wal mart.
Aug 31, 2010 | Vacuums
My aquarius wma40 hotpoint did not/will not run a spin slow/fast
Sounds like a belt. I would proceed to take apart whatever is needed to get to the pulleys and replace the belt. Did I address your question?
May 07, 2009 | Hotpoint WMA40 Front Load Washer
Squealing while in spin cycle
normally, slow then build up of speed is a sign of the motor brushes wearing. this may cause squealing under load. the pump pulley may be hard to turn due to hard water calcifying or a build up of dirt... you may want to check the pump out before it becomes another problem. also,are the bearings in the drum dry? the belt also does not need to look as though it is about gone before it needs replacing... it could be that the belt is slipping whilst under a faster loading... try some belt grip spray to see if this cures the noise.if it does,then you are certain you need to replace the belt(s)
regards
Dec 08, 2008 | Admiral AAV7000A
My hopoint bwd 129 drum is not turning. Could it be a problem with belt. I so how do a replace the belt?
There is an access hatch on the back of the washer.
Do some basic troubleshooting first:
  1. Open the door and spin the drum by hand. Does it move OK? i.e. it isn't jammed.
  2. Does it spin really really well like there is no resistance at all? Possible snapped belt.
Pull the washer out carefully and make sure there's enough slack on the water hoses and mains cable to get access to the back without causing a problem. Look at the back panel, there's a large oval panel approx 16" tall by 12" wide. It is held on by five or six screws. Using a cross head screwdriver of the correct size remove these screws. Grab the bottom edge of the panel and tilt it up slightly to slide it out.
You'll be looking at the back of the washer drum. The motor is at the bottom slightly before 6 o'clock. It should be obvious if the belt is attached or not.
Replacing the belt is straightforward. Just make sure it lines up with the grooves on the motor pulley.
Aug 22, 2008 | Hotpoint Washing Machines
Seth Thomas Pacconi Turntable Logo
827 people viewed this question
Top Seth Thomas Audio Players & Recorders Experts
Dennis Key
Dennis Key
Vito Vacirca Jr.
Are you a Seth Thomas Audio Player and Recorder Expert? Answer questions, earn points and help others
