Question about Hitachi Saws
Electric brake - Hitachi Saws
Trailer electrics problem. 7 pin plug wired correctly I think. Brake and tail lights work as does left indicator. However right indicator doesn't work but tight brake light flashes instead!
Does the vehicle have electric trailer braking ability? IF it does then you may have tapped that instead of the brake lights. If it does not we need the make model and year of the vehicle.
Feb 18, 2017 | Cars & Trucks
Tip
Trailer Wiring Cheat Sheet
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, grd is white, +12vdc is black, etc), this is for you.
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are: Color, Function, Mark on the plug.
Seven wire Trailer plugs:
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
on Sep 23, 2009 | 1998 Ford Explorer
Tip
Hello all,
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 19, 2009 | 1987 Jeep Wrangler
Tip
Trailer Wiring Standards (Color Codes/Plug Marks)
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, ground is white, +12vdc is black, etc), this is for you.
This will show you how to wire trailers with seven, six and four pin connectors
Seven wire Trailer plugs (Large trailers with a battery and electric brakes):
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 09, 2009 | 2004 Dodge Ram 2500
How to change a master cylinder
a Master rates about a 5 out of 10 with 10 being the hardest
you may find the hardest part is the actual bench bleeding of the master
and/or
the replacement of the reservoir
These are the instructions from my service manual, but I do not remove the fluid prior to service steps 2-6
  1. Disconnect battery ground cable. Disconnect electrical connector from filler cap.
  2. Remove fluid reservoir filler cap.
  3. Raise and support vehicle.
  4. Remove front wheels.
  5. Remove dust cap and loosen bleed nipple. Connect a bleed tube to bleed nipple and into a suitable container.
  6. Pump brake pedal until all fluid is expelled. Tighten bleed nipple.
  7. Lower vehicle. Install brake fluid reservoir cap. Remove air cleaner and air cleaner outlet tube.
  8. Disconnect central electrical box electrical connector.
  9. Remove central electrical box retaining screw.
  10. Remove central electrical box and relocate to air cleaner area.
  11. Disconnect brake fluid feed tube. Disconnect brake lines.
  12. On models with anti-lock brakes, disconnect brake lines from Hydraulic Control Unit.
  13. On all models, remove brake booster vacuum hose.
  14. Extract master cylinder from vehicle.
  15. On models with manual transaxles, remove clutch hose from brake/clutch reservoir.
  16. On all models, remove master cylinder nuts and remove master cylinder.
To install, reverse removal procedure. Bleed brake system.
May 31, 2010 | 2001 Ford Focus
Wiring towbar for t25 volkswagen
Hi Paul,
This should help,
Columns are Color, Function, Mark on the plug.
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
Sep 15, 2009 | 1986 Volkswagen Wagon Camper
Adding trailerbrakes to a 24 volt truck
Are your electric brakes rated for 12 volt or 24 volt, that is the question. YOu have to supply the voltage at whatever the brakes are rated for.
Apr 15, 2009 | IBM LENOVO 24V POWER SUPPLY 42L0085 Power...
Saws Logo
49 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
