Panasonic viera black screen
The screen was on and then there was a click and it went back. After powering off and back on, the power light was blinking red. Still no pictured.
  • 12 Answers
SOURCE: LOST POWER ON A VIERA 42 INCH PANASONIC PLASMA TV
Take the unit in to be serviced.
Posted on Jan 21, 2009
SOURCE: power led blinks but no picture or sound
Had the same problem myself. Took some doing but I managed to find a service bulletin that I downloaded. The problem is with the siene module and all you need to do is unplug connector JP63A from the main board and your TV will work again.
Take the back off the TV (there are a lot of screws) and look on the left hand side of the main circuit board that is mounted in the center of the TV. You will see a small white connector that is labelled JP63A, simply unplug it. Plug the TV back in and let it reboot. That's it, should be able to watch immediately.
Posted on Mar 15, 2009
  • 3 Answers
SOURCE: stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
Posted on Jun 06, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic Viera TH-42PV7HS Plasma does not turn
replaced su or sd board and check sc board
Posted on Nov 10, 2009
  • 418 Answers
SOURCE: Panasonic plasma th42ph10uk power red light blink twice
Manual says problem with SC, SS, or C boards. SC is large board at left when facing rear, SS is large board at right, and C is small long board at very top. You could check fuses on SC and SS. Also, SC and SS should make a buzzing noise(not too loud) if operating. If a fuse is blown, suspect that board is bad not just bad fuse. Search parts at encompassparts.
Posted on May 09, 2010
No power to set no led lights blinking
Could be an open internal fuse or power supply failure
Sep 06, 2016 | Panasonic Viera TH-42PX80U Plasma TV
Black screen blinking red light Viera TV 42ld24
First try resetting the unit by unplugging for 30 seconds to 1 minute. plug back in to see what happens. I red light still blinking may be power supply or Main PCB. check voltages from power supply to verify its OK. of all those voltages OK, check the Main PCB.
TZRXN01PTUUS $250.00
http://www.ued.net/ued/viewItemAction.do?itemCode=MSCTZRXN01PVUUS%2FDUD
N0AE3GJ00007S
power supply $72.31 http://www.shopjimmy.com/catalogsearch/result/?q=N0AE3GJ00007S
Apr 02, 2014 | Panasonic Consumer TC-L42D30 42"Viera Full...
Switched of when watching tv never came back on
Power supply or a resistor in power supply went bad you could open it up and check with multimeter or a bad resistor will some times have black stuff leak
Jan 24, 2014 | Panasonic VIERA TH-65PV500 65 in. Plasma...
My Panasonic Viera TH-50PZ80U went out.
It sounds that the main digital board has damaged. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 16, 2012 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic TH42PZ80U one minute it was working next minute it went to a white screen with black lines scrolling on the screen. The menu will come up on the screen.
Before making voltage tests etc---Unplug the set, a box or receiver if in line----leave them disconnected from power for a while and plug back--allows the unit/s to try to reboot.
If you have OSD it if the set could be the main board or even the power board causing this.
Jun 11, 2012 | Panasonic Viera TH-42PX80U Plasma TV
50" panasonic. how to fix
after loading facebook the welcome screen does not appears
Jan 15, 2012 | Panasonic Viera TH-50PZ80U Plasma TV
My Panasonic Viera 42" Plasma, 2 yrs old, Model # 42PZ80U, screen just went black and I cannot bring it back. The red light is blinking 10 times.
Typically this means you've got a power supply that went bad. I've been doing research for a potential class action lawsuit on these "blinking lights of death" problems that the Panasonics are having and that is usually why the tv will show 10 blinks. Occasionally another component inside the tv can be what caused the tv to shutdown and show the 10 blinks.
I'd like to hear more about your experience with the television and any contact you've had with Panasonic in an attempt to get the television repaired. If you're inclined to share your story with me, please contact me at kiaeger@levjen.com.
Oct 12, 2010 | Panasonic TH-42PZ700U 42 in. Plasma...
No picture or sound
Make sure that there is actualy power going to the AC power source where the TV is plugged in. You can re-set the TV by disconnecting the power for about 10 seconds and then connecting it back again. If the set still does not start it will require service.
If the set is dead it is most likely the main power supply board that failed. The service tech would replace the power supply and also investigate to find the cause of the failure. Sometimes another board could have a failure and cause the power supply to be damaged.
If the set will not start up, it will require shop service. You can call Panasonic tech support to find out the authorised service rep for your area. Check to see if the set is still under warranty. If not, it will be expensive to service.
Jerry G.
Dec 01, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
