Question about Tablets & eReaders
Nextbook nx007hd Will not connect to Internet
How do I set up an internet connection on my nextbook using an existing accoung?
Unless you have a network cable plugged in that is the only way it will work.
Dec 06, 2014 | Nextbook Tablets & eReaders
How to unlock a PUK tablet nextbook with a model named Premium 7 SE and model numbered : NX007HD ?
Call your service provider and they will give you your PUK code once you have it enter it into your device and it should be ok then to turn the wifi back on
Nov 25, 2014 | E FUN NextBook Premium NX007HD8G 8 GB...
How do I connect my Nexbook 8 to the internet on my laptop
You connect your Nextbook to YOUR WiFI HOME NETWORK (not the Internet) FROM THE NEXTBOOK, not from the laptop. On your Nextbook, go to Settings then Wi-Fi. If your Nextbook is already connected to your WiFi home network you will see the network's name there and you are done. If it is not connected, a list of available WiFi networks appears. Tap on the name of your home network and it will connect to it. If your network is password-protected, you will be asked to enter it.
Sep 13, 2014 | Nextbook Premium 8 Se Android
Nextbook 8 cant get wifi to work now - worked before??
Hi there
You have checked that you are joined to the network via the router?
The laptop most certainly is.
Try disconnecting the router and turning the Nextbook off for a few seconds, connect the router on again and open Nextbook.
Join the network again and put the password in.
This way of connecting has worked for me. Hope it will for you.
May 06, 2014 | Nextbook Premium 8 Se Android
Nextbook nx007hd
try restart maybe it needs to reresh its storage devices and doesnt support hot swap
Apr 18, 2014 | Tablets & eReaders
How to root nextbook nx007hd
  1. Google and download Cydia Impactor (First result on Google) Extract it (desktop, wherever you prefer)
  2. Enable USB Debugging on your Tablet (Settings > Developer Options > USB debugging)
  3. Plug up your Tablet via USB, do not turn usb storage on, let windows try (and most likely fail) at installing drivers.
  4. Launch Impactor and select USB Driver Scan from the top menu (under USB). Let it do it's thing, reboot your PC after.
  5. Verify your tablet/android device is showing up on the start-bar as being plugged up/in (bottom right area)(this may not be needed depending on your setup)
  6. Relaunch Impactor (if rebooted ) and hit the Start Button
  7. Let it do it's thing.
  8. You should be rooted now go install SuperUser!
Dec 17, 2013 | HTC PG41200 EVO View 7in LCD 4G Tablet
Tablets & eReaders Logo
15 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
