Simpson topload error code hc - Washing Machines
Hi,i have a Simpson EZI Sensor 6 kg top load it has PU error code, any one knows what this code reflects? Thank you in advance Mike
It means pump error. Water is slow to drain or not draining at all. May be a blockage or could be a faulty pump.
Dec 06, 2016 | Simpson Washing Machines
Hi All, I have Simpson Toploader SWT704 7.5kg washer. Its a 5 years old machine and recently it started thumping noise like an earthquake at the end of the washing cycle.
Try utube there is some videos there of similar machine designs that are very helpful or you can download a repair manual for your model through Simpson/Electrolux....hope this helps gl
Mar 15, 2016 | Simpson Washing Machines
My Simpson eziset 950 keeps coming up with error HC.
No water flowing in to machine. Check taps are fully open & filters on end of hoses are clean & not blocked. If all good then you probably have a faulty inlet valve.
Dec 14, 2015 | Simpson Washing Machines
My washing machine goes fine until half way through wash then comes up with error code PU and beeps until I turn it off...will not drain out the water? Simpson encore 556
simpson encore pu Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/simpson_encore_pu
Unsolved problems for simpson encore pu question. Get free help ... My simpson encore 757 shows PU error code. What is this? ... Simpson encore 556. Aug 22 ...
Sep 10, 2015 | Simpson Washing Machines
Swt955sa simpson topload washers but wont spin
i would suspect the motor brushes or something related too the motor
silly question but you do have spin switched on
i dont know your specific machine
but most modern spin speed adjustment knobs
have a setting 'no spin'
ive fixed four last week same thing the wee old lady and three familys .. same issue spin simply switched off
Mar 09, 2015 | Simpson Washing Machines
My Simpson toploader Eziset 750 will not start, the power point is ok.
Maybe the lid inhibitor switch is faulty,or not being pushed in when lid closed
Sep 20, 2014 | Washing Machines
My Simpson eziset 650 won't complete a cycle it
The machine has detected that it's taking too long to fill, check the hose filters in the inlet solenoids (remove the hoses and you will see them) make sure your taps are turned up, If all seems ok then you have work inlet solenoid(s) and will need to replace 1 or both of them depending on if it does it on both hot and cold cycles.
Mar 05, 2012 | Samsung Washing Machines
Error code HC
I recently started getting this message as well. I found out that I accidentally switched the hot and cold water lines into the washer. After switching so hot goes to hot and cold goes to cold the 'hc' message has stopped.
Apr 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
