Question about GE Profile WPRE6150KWT Colossal Capacity Washer
My Ge Profile hydowave washer will not spin or agitate
It will fill and drain but not spin or agitate. the green light is blinking on the motor
MNTECH
  • 1543 Answers
SOURCE: GE Profile WPRE6100G Top Load Washer
The most likely cause of your problem is the lid switch.
Posted on Oct 27, 2008
  • 5 Answers
SOURCE: ge washer is not agitating or spinning
change the timer.
Posted on May 28, 2009
  • 512 Answers
SOURCE: GE washer no main motor run so no agitate or spin
This is the electronic washer. Unplug for two minutes, plugin then open and close lid 7 times. This will reset motor. Also make sure belt is not broken.
Posted on Jun 12, 2009
mgprice
  • 744 Answers
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Posted on Jul 19, 2009
hiltonjug
  • 612 Answers
SOURCE: ge profile washer WPSR3100W1WW won't agitate
I see this pretty regular. You have a bad transmission. This is very common with the older GE's. To replace the transmission will run around $340 / $400. Not sure about your area. Just be glad you got this much use out of it, you are one of the very few that have. From 1998 till 2007 I owned my on repair company where I did GE's warranty work in my area for them. During that time period. When I found a GE washer under warranty doing what you are describing. GE would warranty the whole machine. They would have me destroy the machine after I would deliver the customer a band new one. GE knows they had a bad transmission and it cost them a lot of money. It was cheaper for them to replace the washer than have me repair it. The transmission list price was $298.00 back then. A word of advice, when you replace it. Buy a Whirlpool, Kenmore, Maytag. These brands hold up the best. I have the least service calls for Whirlpool and Kenmore. Both are made by the same people. Kenmore is made for Sears. Good Luck.
Please rate this solution if helpful. Thanks
Posted on Aug 21, 2009
GE PROFILE MODEL NUMBER WPRE61000 SERIAL NUMBER TL958436G Washing machine doesn't spin or agitate
Did you check to see if the motor is receiving power? Is the motor good?
Sep 10, 2015 | GE Refrigerators
Ge washer will agitate or spin it will fill and drain water. have change lid switch and timer
If is is a top load model, check the motor's LED light. It will blink a series of blinks. there is a tech sheet located behind the control panel. it will tell you what the blinks mean and what to check and or replace. Probably motor or mode shifter.
Feb 18, 2015 | GE Washing Machines
GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
My GE Profile WPRB8050D fills, drains and spins but won't agitate. It makes a sound, but doesn't move. What could be the problem?
These washer have a motor that runs clockwise and counter clockwise...for agotaion it runs one way and for spinning it runs the other...check if the motor is still getting power, but not running in the one direction...motor is probably bad...
heatman101
May 02, 2010 | GE WPRB8050D Top Load Washer
GE top loading washing machine drains and fills but does not agitate or spin. Wiring around lid switch resolved problem for one load only. Flashing green light on motor circuit board seven flashed each...
7 blinks DOES indicate a problem with the lid switch.
Replace the switch, and inspect the wiring for cracks/wear.
Can you hear the motor spinning?
Is there black plastic chunks under the washer?
What is the model #?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 25, 2010 | GE Washing Machines
GE profile washer not spinning model number wnsr3120w0ww
Do you hear the motor going? If you do, I am sorry to say it is your transmission on your washer. The website link below will confirm this if you hear a motor going. If you don't hear a motor then it could be your motor. It is very expensive to replace, I am sorry to say. The expense of the transmission is $260 plus or minus with labor. http://forum.appliancepartspros.com/washer-repair/13251-ge-profile-washer-fills-drains-agitates-but-wont-spin.html
Dec 06, 2009 | GE Washing Machines
I own a ge hydro washer. It won't spin or agitate
If you hear the motor go through the stages, but nothing is happening in the tub, the motor belt may be broken or off.
Aug 31, 2009 | Washing Machines
Does not agitate or spin
Let me make sure I hear your symtoms right..
The washer fills...sound like the motor is running but it doesn't agitate or spin.. then when it tries to drain it bascially gravity feeds out until there is no longer enough water to force it out?
Sounds like the belt is off, or broken.. I am not all that familiar with your model, but I think most GE's are belt drive.
If it were the agitator coupler, the washer would probably still drain..
Pull the front cover off of the washer, you will see the belt and pulleys, make sure it is A: still on the pulleys, and B: tight.
If not, loosen the four bolts on the moter, put the belt on and then slide the motor towards the rear to tighten it.. then tighten the four bolts. They may simply have not tightened the bolts on the motor from factory and the motor slid back loosening the drive belt.
GOOD LUCK!!!
Jun 20, 2009 | GE Washing Machines
Jun 07, 2009 | GE WBSR3140DW Top Load Washer
GE Profile WPRE6150KWT Colossal Capacity Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
