Question about Seagate (ST3160203U2-RK) (ST3160203U2RK) 160 GB Hard Drive
External hard drive wont stay connected to computer
I have a Seagate external hard drive (160 gb) It is about 2 years old and have never had problems with it. It froze up on me earlier today and now when I turn it on light goes green i hear the sound on computer that it is connected and immediatly the light goes off and sound chimes that it is disconnected again but i can still hear and feel the fan running. Is there anything I can do about it or is it just lost??
  • 696 Answers
This depends where the failure is.
If your controller board for the external casing or your power supply have failed the drive can be removed from the casing and placed in a new one($30-$40), then it should work fine. If the circuit board on the hard drive or an internal circuit for the drive has failed then you may require the help of a pro.
Reply back if you need a recommendation for a pro, include your location.
Chris
Posted on May 19, 2009
My external hdd segate 160 gb sata not show in setup. its only some sound inside 'cut-cut'
Try connecting this USB hard drive to another computer.
The clicking sound is known as the "click of death" the read write head is banging back and forth and is a sign the hard drive is faulty.
May 19, 2011 | Seagate 160GB 3.5" External USB Drive 160...
I have a Assembled Computer with Processor Intel Dual Core (R) @ 270 GHz, 3 GB of RAM equipped with Microsoft Windows XP Professional Edition version 2005 service Pack 3 with Wi-Fi Netgear 108 Mbps Lan...
yah you must buy a Y-USB cable for your external hardisk. this is connection both ends are one is for hardisk and the other two cable is for USB slot of computer. why it two wires connection to usb because one wire is for Data and the other is for Power. If doesn't work..it might be a problem in your Operating system. i recommend to you to reinstall your Windows OS.. theres a 4 reasons why it happen appear the error... deffective USB cable..corrupted driver of USB device for seagate, virus infected of your systems..and maybe your hardive is deffective. Please rate if this is HELPFUL..thanks
Aug 22, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Beeping external hard drive
ITS G-FORCE ACTIVATION BEEP .... I AM TRYING TO FIGURE OUT REALLY WHATS GOING ON HERE I CANT FIND ANY ANSWERS BUT I AM SURE ITS VERY FIXABLE
May 15, 2010 | Seagate (AU-80GBSATAHD) 160 GB SATA Hard...
Reduced Hard Drive Capacity with Internal to External Kit
Problem can be tricky.. though i offer my two cents.
1. some BIOS have upper limit of hard disk capacity. check that out. try connecting IDE device to IDE connector in same comp and see if it is being detected properly.
2. seagate guys are true .. IDE to usb conversion can be tricky ... a lot depends on card convertor.
my advice would be if you have precious data on it ... first take a backup of it, if possible connecting the disk to nomal ide connector.
Aug 06, 2009 | Sabrent 1 Bay USB 2.0 External Drive Case
Wont stay connected
You need to isolate the problem. Based on the info that you have provided, it could be the FireWire port of the computer, it could be the hard drive itself or it could be the FireWire cable.
1. Try connecting the HD into different FireWire port.
2. Try other computer.
3. Try another FireWire cable.
Doing these steps would give you an idea which is giving out the problem.
Aug 04, 2009 | Seagate (ST3160203U2-RK) (ST3160203U2RK)...
I don't have an instruction manual for my Seagate 160 GB External
Well, if it is a USB Drive, you can locate the drive on your Computer. and using Windows explorer would be a lot easier, click on start, all programs, accessories, Then click Windows explorer, and on the left hand panel, you can then search your drives and located the data that you want to copy and paste. For example, I am going to copy my documents from my (C:) drive, and I then will paste onto my USB flash Disk Drive (J:)..you will see the files go from (C:) to (J:) drive once you start the process...thats it!
Apr 01, 2009 | Seagate (ST3160203U2-RK) (ST3160203U2RK)...
Usb seagate 160 gb hard disk
Your hard-drive is crashed and unreadable by win32.dll what you can do is try kick starting by using your friend computer it just might do it. I had same problem and I asked my son to using my hard-drive on his PC. It worked and still working. good luck
Jul 26, 2008 | Seagate 160GB 3.5" External USB Drive 160...
External hard disk unreadable
Seagate (ST3160203U2-RK) (ST3160203U2RK) 160 GB Hard Drive Logo
232 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
