Question about Bowflex Revolution Home Gym
Bowflex spiral flex cable is loose and just hang out
What causes cable throttle to stick mower won't move
Because its a cable that runs through a metal jacket coated on the out side .
But the in side is a spiral wrapped metal jacket like BX cable .
It ether gets corrioided in side the jacket or the cable can fray a few strands is all it takes because to hang up is the spiral wrapping of the jacket.
Just replace the cable.
Jun 19, 2016 | Cars & Trucks
Why would my bowflex tc3000 not calibrate?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 14, 2016 | Bowflex Nice Tc3000 Treadclimber Bow Flex...
Why is my bowflex tread climber creaking?
I would be contacting bow flex customer service. That product hasn't been out that long
Jul 23, 2014 | Bowflex Treadclimber
Start shuts down machine and blows circuit breaker
see the video attached. and proceed according. However you must test the power cord for short circuit. some wires is touching each to another. Or the outlet wall the wires are loosing touching each to other and blowing the c.breaker, or call some electrician for to fix it.
God bless you
Oct 17, 2013 | Bowflex Tc5000 Climber Treadclimber...
Bowflex TC5000 won't start! Lights on circuit board show power.
see the video and proceed according and fix it. God bless you
Jan 08, 2013 | Bowflex Tc5000 Climber Treadclimber...
How to solve a flickering screen for toshiba satallite m200? as i open my laptop its hang and the screen is flickering...
@crisanne_21
Most of the time, that cause of that flickering screen is a defective LCD flex cable or sometimes called LVDS cable (this is the cable that attaches the LCD panel to the motherboard - it can be caused by a loose connection or simply, it just may have worn out due to opening/closing the lid). The only way to fix that is to replace disassemble the computer and check if there's a loose connection on that LCD cable. If disconnecting / reconnecting the LCD cable doesn't fix the issue, you might need to replace it Disassmebly guides can be found here.
Good Luck
Sep 05, 2011 | Toshiba Computers & Internet
I just got a bowflex extreme 2 from someone used. It is from 2006. There doesn't seem to be enough resistance? How can I make more tension in the rods? Seems too loose?
The nice thing about the Xtreme 2 is the fact that you do not need to change cables for different exercises, but it does mean numerous cable position adjustments depending on the exercise you are doing.
To alleviate the slack problem in the cables you can either have the cables that run under the seat remain attached to the leg extension attachment or move the sliders attached to those cables as far forward as possible thereby pulling the cables as far out as they can go. This will both increase the resistance provided by the rods and keep the floating pulleys from hitting the lat pulley housing.
Jan 24, 2011 | Bowflex Xtreme 2 Se Gym
1999 toyota avalon horn works intermitely
I would suggest to you to have the spiral cable (or 'clockspring') replaced. This is the electrical unit that transfers power to the air bag, the horn and the cruise control.
It is located right under the seering wheel.
Your description of the issue indicates to me that your spiral cable is loose, and making intermittant contact. If the vehicle had an air-bag deployment, this cable-device should have been changed.
Nov 11, 2009 | 2004 Toyota Avalon
U600 dropped and in half :S
Simple . . . buy a new phone.
Jul 02, 2008 | Samsung SGH-U600
Bowflex Revolution Home Gym Logo
20 people viewed this question
Top Bowflex Sport & Outdoor - Others Experts
Jerry Greenberg
Jerry Greenberg
Bill Boyd
Are you a Bowflex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
