Question about Crayola Melt N Mold Factory
Unplugged but still clicking and unable to open
My son loaded the crayons wrong and wax melted out the back of the machine. He unplugged it but its still clicking and we are unable to open it. Should we plug it back in even though its wrong?
4 Suggested Answers
  • 2841 Answers
SOURCE: melted crayon on clothes My granddaughter had 2
http://www.ehow.com/how_2038301_remove-crayon-stains-clothing.html
Posted on Apr 12, 2011
eugbug
  • 479 Answers
SOURCE: How to remove melted wax crayon from car
  • Firstly scrape as much of the wax from the upholstery with a plastic scraper, try not to rub it deeper into the material.
  • Place brown paper or other thick absorbent paper (not glazed) on the crayon. Using a clothes iron set to low heat setting, press down on the paper. Be careful or you may melt the upholstery. This will remove the excess wax. Keep checking the paper and replace it as it becomes saturated
  • Spray some WD40 on a paper towel , cotton wool or cloth and rub this into the stain. Repeat this with more towel until you have removed all the color.
  • Finally scrub the area with detergent and warm water to remove the WD40 and allow to dry
Posted on Apr 28, 2011
  • 1082 Answers
SOURCE: a crayon melted in my back car seat, how can I
Try this..
??¦Use a dull knife to scrape any of the debris off.
??¦Apply WD 40 to the stain and let it stand for five or so minutes. (Spray lubricant /oil)
??¦Use a stiff bristle brush to loosen the crayon.
??¦Wipe off with a clean terry cloth.
??¦Reapply as necessary.
??¦Apply liquid dishwashing detergent to the area with the stain.
??¦Work into the stain.
??¦Wipe clean with clean terry cloth.
??¦Rinse with a damp sponge.
??¦Allow to air dry fully.
Posted on May 13, 2011
Melted crayon all over my car upholstery
To remove melted crayon from upholstery:
1. Scrape away melted wax from the upholstery as much as you can using a blunt knife. 2. Put a brown paper, or butcher paper (glossy side down) on top of the affected area then using the tip of a hot flat iron, melt the crayon until it stick to the paper. 3. Let the paper cool then lift it away gently from the upholstery. 4. Dab a small amount of denatured alcohol to remove any remaining stains then finally clean the affected area with sponge and water.
Hope this help. Goodluck!
Jul 19, 2011 | Crayola Classic Color Pack Crayons...
How do I remove crayon wax that melted in the sun onto my wrought iron deck table
There are a few methods. You can take ice cubes and place them on the crayon wax until it freezes. It can then be easily removed. You can also place a paper towel on the wax and use an Iron to heat the wax until it melts. The paper towel will absorb the wax. Then use a dryer sheet to remove anything left over.
Jul 10, 2011 | Garden
How to remove melted wax crayon from car upholstery
Apr 26, 2011 | Crayola Classic Color Pack Crayons...
The control lock buttton is on. How do I remove it?
Handyman here-
I had a maytag neptune that did a similar thing. Door would close, but not lock. On the maytag there is 'wax motor' that closes the door lock. Mine melted and would not close. When the repairman came out I noticed a 'wire' that he pulled to make sure the locking mechanism was retracted before he pulled the 'motor'. Perhaps you can find a similar release mechanism to open your door. Note that your machine will not work properly until its replaced.
Good Luck!
Apr 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Back to problems with my 2000 Buick La Sabre. I noticed this last year and now it's happening again. Sometimes when the heat is on there is an odor that smells like melted candle wax, the smell can be so...
I don't really know what could be causing a wax smell specifically, but if crayons made their way into the duct-work then that could be your problem. Other wise you may want to inspect the heater-core, could be clogged (for debris or mold) and cabin air-filter (IF APPLICABLE).
Dec 10, 2009 | 2000 Buick LeSabre
Help getting crayon out of dryer.
If they are globs you can freeze them by rubbing with an ice cube and scrape them off. If the residue is thin like a coat of paint use denatured alcohol or paint thinner to rub them off. Make sure you leave the dryer door open several hours after using solvent inside to air it out. Do not use the dryer immediately after using solvent or there could be a fire hazard.
If the crayon residue is on the clothes, you can put piece of absorbent paper (like a paper grocery bag) over the stain and iron it. The heat will melt the crayon wax and the paper will absorb it. You may have to do it several times to get it all out. Denatured alcohol or paint thinner might be needed to get the final stain out.
Jun 29, 2009 | Dryers
Orange crayon melted all over the drum of drier and I cannot get it cleaned. Any suggests?
You now have hot melted wax coating EVERYTHING, I bet.
First, unplug your dryer, for safety.
Now take some turpentine or wd-40 and dampen a cloth with it.
Scrub, scrub away.
once it's clean(will take a LOT of elbow grease), you'll want to clean up the solvent.
A wash-cloth, dampened with soapy water, will do a pretty good job here.
Finally, leave the machine OPEN for a good solid day/night.
This lets any fumes remaining from the solvent escape.
this is important, if you don't want to blow up your dryer when you next start it up.
Jun 01, 2009 | Whirlpool Dryers
Crayola Melt N Mold Factory Logo
382 people viewed this question
Top Crayola Home Experts
Donni Steen
Tom Chichester
Are you a Crayola Home Expert? Answer questions, earn points and help others
