Question about Dell 725 InkJet Printer
My printer will not communicate with the computer?
When I print, I get a message that says there is a communication problem.  I have power and I bought a new USB cable, but both do not seem to work.
  • 1 more comment
  • Anonymous Mar 25, 2008
    yes i have the same problem
  • mycul_p Nov 09, 2008
    hi i have the same problem and it's not a problem with the printer as i have tried another printer that i know works and there is still a communication problem. i have tried several USB ports and cables. Another thing that is anoying is that it dosent give me any prompts to test printer communication it simply says there is a probelm but not letting me fix anything! also i have checked the firewall setting too! any ideas?
  • neils001 Apr 04, 2009
    I have the same issue on Dell 725. It is not the printer as it works connected to my other laptop not running vista. Is not usb port as the laptop sees the 725 and installs the driver. All is ok except when something is attempted to be printed and it fails with a communication failure.
  • 96 Answers
Try connecting the USB cable directly to the computer not via a HYB.
Try another USB port on the computer.
If that doesn't solve the problem there is most likely a problem with the printer.
Posted on Feb 09, 2008
SOURCE: Lexmark X 1270 Can not Print
try reinstalling the driver
Posted on Dec 20, 2007
latinmcgyver
  • 208 Answers
SOURCE: Printer unable to communicate with computer
most easiest fix for this.. make sure in the properties of that printer.. under the PORT tab. make sure its set to usb not LPT. this is very common error.
Posted on Oct 10, 2008
acdr
  • 1913 Answers
SOURCE: Lexmark X1240 will not communicate with my laptop computers.
check your usb cable.
Posted on Nov 15, 2008
  • 144 Answers
SOURCE: COMMUNICATION NOT AVAILABLE LEXMARK X1150
Hi
This kind of issue might occur due to many reasons, like:
the previous installation files creating a glitch for new software.
PORT settings
Resolution:
goto devicemanager by following:
start->run->devmgmt.msc (type in the box)
check if you have printers with exclamation mark or any special symbol showing a problem with the device.
try updating the drivers,
a more feasible solution could be removing the usb composite device entries from the tree under usb section but this should be done only by a skilled technician.
Thanks & Regards,
Amit Verma
HP AIO printers support
more than 3 years of AIO printer troubleshooting expertise.
Posted on May 11, 2009
  • 85 Answers
SOURCE: Dell Color Printer 725 - Communication Not Available
I have seen that in most of the cases (with lexmark and dell printers) it is fixed by reinstalling the printer software. Be sure that you completely remove the older drivers using the cd or using add/remove programs.
Posted on Jul 29, 2009
"Communication Not Available" message is displayed
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Unplug and re-plug the printer into the power source to reset it.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at . Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 16, 2011 | Lexmark X2670 All-In-One Printer
My Lexmark Platinum PRO905 does ot print it gives me the message " Communication Not Available, The Printer cannot communicate with the computer"
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if usb-connected), reboot your computer and unplug/replug your printer into the power source to reset it. When the printer turns on, reconnect the printer into the computer. Try to print again.
You may also refer to this article (for Wi-Fi connection issues): How to identify a Wireless Communication Problem and Resolution Tips
Aug 09, 2011 | Lexmark Platinum Pro905 multifunction...
Problem communicating with printer message when printing. printer says offline
This could be just a slight communication issue. Try to unplug your printer from your computer. Unplug and replug the printer into your power outlet to reset itself. When the printer powers on, reconnect it into your computer. Doing this usually fixes minor communication issues. Thanks.
Feb 21, 2011 | Lexmark X73 All-In-One InkJet Printer
Is offline how can I bring it online
It could be just a minor communication issue. Try to unplug your printer from your computer. Unplug and replug your printer into the power source to reset itself. When your printer turns on completely, reconnect it to your computer. If problem continues, you may refer to these articles for further troubleshooting:
- 'Communication Not Available' Error Message and Print Job Stalls in Print Queue - Error: "Problem communicating with the printer" or Bogus Error Messages
You may also contact Lexmark technical support for additional assistance. Thanks.
Feb 17, 2011 | Lexmark Color JetPrinter Z54se InkJet
Printer wont comunicate with Computer
Try to unplug your printer from your computer. Unplug and replug your printer into the power source to reset itself. When your printer turns on completely, reconnect to your computer. Try to print again. If problem continues, you may refer to these articles in the Lexmark website:
- Communication Not Available' Error Message and Print Job Stalls in Print Queue - No Communications Error When Trying to Print or Scan
I hope these help. Thanks.
Feb 16, 2011 | Lexmark P4350 All-In-One InkJet Printer
My computer is'nt comunication with the printer
It could be just a slight communication issue. Try to unplug your printer from your computer. Then unplug the printer from the power source. Replug after 10 seconds. When the printer turns on, replug it into your computer. Doing this usually fixes minor communication issues. If error continues, you may refer to this article on 'Communication Not Available' Error Message and Print Job Stalls in Print Queue for troubleshooting steps. You can also contact Lexmark technical support for additional assistance. Thanks.
Jan 21, 2011 | Lexmark X2600 InkJet Printer
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    Printer not communicating with computer
    (1) Try a power cycle: Try turning the printer off, then unplug the power supply from the printer, then unplug the USB cable from the printer then the back of the computer; wait 30 second; then plug the USB cable back into the computer, then back into the printer then plug the power supply back into the printer and turn it on – run a test print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
    (2) Update the USB drivers
    Jan 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
    Lexmark 1200 Series
    unplug your usb cable,uninstall printer then reinstall
    Nov 09, 2008 | Lexmark X1270 All-In-One InkJet Printer
    With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
    To fix a fouled install:
    (1) Uninstall the Lexmark drivers in Add Remove Programs
    (2) Shutdown the computer
    (3) Disconnect the printer from the USB port
    (4) Restart the computer
    (5) Run the Driver Installation software
    (6) Cancel ALL attempts by windows to auto install the printer
    (7) When the software asks for the printer connect it and continue
    Sep 10, 2008 | Lexmark Z735 InkJet Printer
    Dell 725 InkJet Printer Logo
    311 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
