Question about LG Refrigerators
Gc-p197wfs not making ice - LG Refrigerators
My windshield pump stopped working....no noise when I turn it on. Where is the fuse located? 2006 jeep Cherokee. Thanks!!
use a test light and check for power and ground at the electrical connection at the pump as if you have these then the pump is bad and needs replacing.
Feb 06, 2015 | 2006 Jeep Grand Cherokee
Lg fridge Model GC-p197WFS
Sounds like you need a new one
Jul 18, 2013 | Max-Fridge Refrigerators
There is ice buildup on the unit behind the fan and its causing the fan to rub on the ice. Why is this happening and what do i do to fix it?
Your unit is NOT frost free according to the specs so it will required periodic defrosting to keep the ice build up from affecting the fan.
Aug 14, 2011 | LG GC-051SS Compact Refrigerator
Problem ICE Water
This is a far shot but want you to try something with the freezer door switch. Call my number and iI will try to help you solve this, Sea Breeze
864-812-1887
Aug 29, 2009 | Admiral 26 cu. ft. Side-By-Side...
Water filter lg refrigerator GC-L197NFS
I have bought this fridge yesterday all plugged in working well got nice cold water but its not filling the ice try inside to make ice? Dont know why
Dec 23, 2008 | LG LSC26905TT Side by Side Refrigerator
Ice, drips and soggy peas!
never buy a fridge with an ice box! the freezer compartment is not cold enough for long term storage and all of them build up ice. however, check door seals carefully as you may have an air leak past them. "4" is a reasonable setting and the stat controls both sections. also check that the compressor stops and starts regularly. if it is constantly running, you could have a compressor fault
Apr 27, 2007 | LG GC-151SA Compact Refrigerator
Refrigerators Logo
26 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
