Question about Bunn Margarita Machine Ultra 2 Slush Granita Maker
My slush machine freezes to big of chunks
This machine does not freeze evenly. It freezes on the drums and makes big chunks of ice
2 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: I have an Ultra 2 bunn slush machine. One hopper
make sure it's mixed properly. if there is toomuch water, it'll freeze solid. if the mix is too rich, ice will form on the outside of the bowls. you may also have a low refrigerant level.
Posted on Feb 13, 2011
I make alcoholic slushys with my Bunn 2 double hoppers. I have 4 machines. 1 works great. 1 freezes well but gets a huge amount of ice build-up on the outside, and the other freezes but thaws out a
the ice buildup is from the brix level being too high. the mix is too rich to freeze fast. it freezes based on torque, not temp, so it'll just keep getting colder and colder until it's thick enough. once it gets below 24 degrees, the condensation on the outside will freeze. the other, check the defrost time.
Apr 22, 2014 | Kitchen Appliances - Others
I have bunn slush ultra 2. 1 side freezes 1/2 way, like slushy a little bit but still watery, other side is only chill. both are set to 16 thickness.
make sure both say "ICE" on the display. press the snowflake buttons on the front to get it there. also, make sure you are mixing the product properly. if still an issue, you may have a small refrigeration leak that should be looked at by a professional
Aug 26, 2013 | Bunn Margarita Machine Ultra 2 Slush...
Bunn won't freeze the drink, the drum freezes and ices over but 3 hours later no slushy.
clean the filter and condenser coils, leave at least 6 inches of space for it to breathe
Aug 02, 2013 | Bunn Margarita Machine Ultra 2 Slush...
In slush machines, how come the slush does not get completely frozen?
slush is made from sugar and water bonding together. the sugar is used as an antifreeze and then the mixture is constantly spun by the machine in order for it not to freeze.
Jan 24, 2013 | Kitchen Appliances - Others
I have a bunn ultra II double hopper. neither side is freezing as well as it use to be, they both get chunks of ice in them, however the augers tend to **** instead of run smooth from time to time. i have...
go into the menu (hold down the "gourmet" button) and select reset all. then check your mix to make sure it's the proper ratio. too lean will cause it to freeze too fast.
Jun 12, 2012 | Bunn Margarita Machine Ultra 2 Slush...
Parrot ice slushie machine Compressor comes on,
Liquid gets very cold but won't freeze
Jun 10, 2010 | Freezers
I have a 2 hopper bunn slush machine.One hopper freezes the second one does not
May 22, 2010 | Bunn Margarita Machine Ultra 2 Slush...
The bin on my ice maker forms big chunks of ice
check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice, OR cause the thaw-freeze cycle resulting in chunks. Check your door seals and thermostat, repair/replace as necessary.
May 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Open Questions:
See all Bunn Margarita Machine Ultra 2 Slush Granita Maker Questions
Kitchen Appliances - Others Logo
74 people viewed this question
Top Bunn Kitchen Appliances - Others Experts
jasbo
jasbo
Jerry Greenberg
Jerry Greenberg
Steve
Are you a Bunn Kitchen Appliances - Other Expert? Answer questions, earn points and help others
